Question about Home Security
Sentry safe reset instructions
I have a sentry G1055C gun safe that I need to change combination on. It has been comprimized. I have the my combination but just need to change it
  • 9 Answers
SOURCE: Forgot Digital Combination of Sentry Safe Model #SO500
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
They should be able to help. I would try calling first, to avoid paying the $12 to retrieve the combo, but with the serial number of the safe, they SHOULD be able to help you over the tele.
Posted on Feb 08, 2008
frcs68
  • 1605 Answers
SOURCE: we just moved and lost combination to our sentry safe
goto SentySafe.com
register and request the combination base on the serial number.
they should be able to send you the combination keys
Posted on Nov 25, 2008
SOURCE: changing the combination
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You must have the factory combination in order to change the combination that was added to the safe and the factory combination can not be erased if that is the combination you are trying to erase.
All you have to do is press program & type in the factory code 2 times & that will erase the number you created.
Then to add a new combination all you have to do is: press program followed by 5 new numbers. Then to see if they new number works, just type in the new combination & the green light should come on & you have 4 seconds to turn the handle
SOURCE: know combination, but cannot open sentry safe 1250
If you know the combination:
1) Turn the dial to the left a few complete rounds, then stop on 1st number.
2) Turning the dial to the right, pass up the 2nd number once, then stop on it on the next round.
3) Turn the dial to the left directly to the 3rd number then stop.
The handle should open now.
Posted on Mar 18, 2009
SOURCE: sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Posted on Apr 09, 2009
How do I change the combination on a sentry gun safe
Try the user manuals for your model on the sentry webpage
http://www.sentrysafe.com/CustomerCare/Product_Manuals
Apr 02, 2015 | Sentry Fireproof Security Lock 1/2 Hr Home...
How do I open my Sentry Safe when the batteries have gone dead?
Some safes come with a key to open it with when this happens.key hole is cancelled under or near the keypad...not sure if yours is one of them.or there maybe a slot to plug in a battery pack .good luck..hope I have helped.
Oct 03, 2014 | Sentry FIRE-SAFE Combination Safe DS3431,...
I missplaced combination
refer to the manual that came with the safe it will have a master code included or instructions on how to reset the unlock code or you can contact a lock smith or the manufacturer and they will be able to assis
Mar 25, 2014 | Sentry Fireproof Security Lock 1/2 Hr Home...
Need factory code for sentry gun safe
All you have to do is find your owners manual the sentry safe combination was posted in. Unless you locked it the safe as happens all the time. After all that is the safest place for it right. Or you can just call a locksmith service tech
Dec 21, 2012 | Sentry Fire Safe 24-gun Safe Combination...
Forgot combination to sentry so100
hi foustulia you need to use your kay to open the safe and reset your combination to a new one
Dec 09, 2010 | Safe International Digital Electronic Safe...
Need to know how to reprogram the combination number to a Sentry G5343 Gun Safe
the instructions are located link above.
mj
Aug 30, 2009 | Sentry Fireproof Safe
Need to open a Sentry keyless combination safe
First, has the factory combination been changed? Sentry has the code for the factory combination that they can supply you.
If the factory combination has been changed to something else, then Sentry won't have it.
In that case you need to ask Sentry for a 'reset' code combination. There is (at least) one back door to your safe -- a reset code.
The reset code will not tell you what your combination is, it will simply reset the combination to the factory combination.
You can take it from there.
Now, this isn't as hard as it may sound. There is an actual department that handles this at Sentry because you aren't the only one that cannot open his safe.
They'll want some proof of ownership, some $$ for the service, the safe serial number, and probably a notarized form claiming that the safe is yours.
Get 'hold of Sentry on the web and the rest is just process.
BTW -- this is exactly what the locksmith would do.
Apr 10, 2009 | Sentry Fireproof Safe
Changing the combination
These sentry safes dial combinations are not built to be changed as they have no key change hole. Switching the order of the tumblers could be done by a trained locksmith. I would suggest buying the electronic sentry safes as these safes can be reprogramed.
Jan 04, 2009 | Sentry Fireproof Safe
SENTRY SAFE
Locksmiths agree the factory code is burnt into memory and can not be erased. When you buy a sentry safe you have to set a user code to give out as that code can be changed. program instructions
Jul 03, 2008 | Sentry Fireproof Safe
Home Security Logo
172 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
