Question about Pool & Spa
Aquadrive 1500 model 7252stda25x
Hi my pool pump capacitor has melted and i need to wire the new capacitor , but don't how to install the new cap please help my find a wiring diagram . thanks
  • 77 Answers
SOURCE: Problems with Intex Krystal Clear Model 635 Pool Filter Pump 1500
No, the pump should not be noisy. It sounds like you have picked up a foreign object in the pump housing. you may have to pull the face off to determine. OR the pump/motor is indeed defective and should be returned.
Posted on Apr 28, 2009
  • 323 Answers
SOURCE: Wiring Hayward pool pump
John what you have is a 240 volt motor on that pump. It will not connect to a 120 volt cord. You'll have to get a different pump.
Sirwriter
Posted on May 15, 2009
erpaalai
  • 999 Answers
SOURCE: wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Posted on Jun 17, 2009
john224
  • 1378 Answers
SOURCE: Need to get diagram to wire gould century 1.5 h.p.
Email me at john@arrowmotor.net and I'll reply with the .PDF from AOSmith. You need to move a couple of wires but as they say, a picture is worth me typing a thousand words.
Posted on Aug 27, 2009
  • 128 Answers
SOURCE: Need wiring diagram for Hayward dual Super 2 speed
You need 4 wires to wire the 2 speed pump. You will also need a 2 speed time clock.. Tightwatt or intermatic. The wiring diagram is on the motor.
Posted on Aug 30, 2009
Need diagram for Aquadrive 1100 speck pump swimmingpool
Aquadrive is a possible source of the diagram
Sep 21, 2016 | Pool & Spa
Where is start capacitor in Jandy FHPM?
The cap can reach end of life with out any signs of physical damage on the exterior. The cap should be replaced, confirming the issue or non-issue of the cap condition. Your description of your problem is consistent with a cap failure.
Jul 27, 2016 | Jandy Pool & Spa
Aquadrive 1100 manual
I need to know what size Capasitor must be used on the Aquadrive 1100 ?
Apr 16, 2013 | Pool & Spa
I need to hook up a new capacitor & need to know how to hook it up!
the two yellow wires go to the one side of the cap the red/whit goes to the other terminal . there is no pos or negative.. so say its like a car battery the two yellow go on one post ant the one red/white go on the other post .. Leave feedback for your favorite fixya guy.. that would be me the pool pump motor repair guy in longwood Florida.. don't forget to prime your pump after a repair !!
Mar 27, 2012 | Sta Rite Max E Pro 2 Hp Up Rate Energy...
WhisperFlo Model WF8 2 HP - It was working fine, next day I turned it on and got in pool but noticed no water was moving. Pump was making a low humming sound, but had no prime in "bubble bucket"...
hay Kay Kay .. there is a capacitor on the top of your motor and is most likely the problem, search your area for your local pool pump motor repair guy with free testing .. cap cost about 20$ it's a cool easy fix..if you look at it and the ends are puffy it's bad .. jay in longwood florida
Sep 07, 2011 | Pool & Spa
I need to know where the wires attach to on the capacitor. I have 2 yellow wires and one white/red tracer. my bro in law took them off and I dont want to blow up the capacitor installing it the wrong way.
The two yellow wires stay together on one pole of the cap and the white/red wire goes by itself on the other pole. It does not matter which pole is which so long as you keep the yellows together on one and the white/red on the other.
John
Aug 16, 2011 | Hayward 3/4hp Super Pump Inground Pool...
Hi my 3/4 hp 230/115 centurian is buzzing and i smell burnt electrics.....what do i need to order to fix?
If the motor can be turned easily by hand then sometimes the starting or run capacitor can be replaced with the same value device and the pump will run. If a new capacitor is installed and it doesn't run then the motor needs to be replaced. If the motor does not turn easily then usually the bearings are bad and the motor needs to be replaced. I hope this helps. The burned smell is either overheated wiring in the motor or a bad capacitor, etc.
Aug 05, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
Low pressure from pool pump
bad start capacitor or dirty start switch.. wire from capacitor goes to the switch switch has 2 1/4 inch screws use fine sandpaper to clean..motor OFF SHORT THE TWO WIRES OF THE SWITCH , the cap may be charged
Jul 23, 2010 | A.B.S ALADDIN GO-KIT #7 ANTHONY POOLS 2"...
Need Intex Pump model #635 impeller
You know, I have made some amazing repairs on plastic items using nothing more than a soldiering iron! If you have the piece that broke off, you can carefully melt it back together. You can add more to the weld if you match the type of plastic but not too much or you imbalance it. In this case it looks like PVC. To repair it without the missing piece, form it out of epoxy putty, roughly shape it just before it sets up solid, & sand to finish.
Aug 30, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Pool & Spa Logo
184 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
