Question about Dewalt DC616kn 18 - volt 16 - gauge straight finish nailer
De Walt DC 618 only firing nails in about half inch what causes this
  • 313 Answers
SOURCE: de walt de9118 charger
when charger is plug in to ac it will blink once.normal voltage out for the unit in between 36v to 55 volt. the reading u have is normal.
Posted on Aug 08, 2008
  • 122 Answers
SOURCE: De Walt Power Shop DW125. Cutting problem.
Sounds like a dull blade or not enough teeth on the blade. Go with atleast 40 tooth.
Posted on Feb 02, 2010
  • 15 Answers
SOURCE: de Walt DW988 XRP 18v 1/2" Hammer Drill have
Depending on how much play, thats normal. The hammer feature causes that.
Posted on Jan 25, 2011
kendji9
  • 111 Answers
SOURCE: De Walt DC 945 K8 Battery charger BC 9135 model
replace with battrery
Posted on Feb 08, 2011
  • 304 Answers
SOURCE: can't engage drill or hammer settings on de walt dc 925 xrp
Try turning the ring to 2 or 3 and run the drill holding the chuck so the clutch slips then try turning it to drill setting. Also try to do it in different speed settings. If not it sounds like a fault in the gear module. It might just be a metal clip just under the clip in side. Undo the 4 screws holding the gearbox onto the housing and carefully remove it, you might see the fault or loads of dirt that needs cleaning. Go to http://www.2helpu.com/world/map.aspx for a drawing.
Posted on Jun 02, 2012
My DEWALT DC 618 angled finish nail gun won't fire When switch is moved from single fire to sequential fire the yellow light just stays lit Without trigger depressed
Could be one of several things - first, check the contact element (part that touches the wood) make sure it is not bent & moves up and down with the linkage freely.
These are also very sensitive to volt/amps - if your battery is not up to par you can also have malfunctions like this.
Last, open the front metal cover (3 screws) and inspect to see if the return bands are in place and not broken. These are located at the top on either side of the driver blade. This is the most common repair on this tool.
Let me know if this helps.
Nov 21, 2014 | Air Tools & Compressors
My dewalt dc 618c won't fire out nails when nailing doorstop heads. But I does nail the uprights??
Most nailers have a pressure sensitive safety feature surrounding or near the nailer head. This is so that they won't fire unless pressed against a surface. You may not be holding the nailer against the doorstop head board with enough force to release that safety.
Nov 05, 2014 | Air Tools & Compressors
My bostitch bt1855 nail gun worked fine, until it started to dry fire 2inch nails. No problem with firing quarter inch nails. Any ideas?
Have you serviced it recently? and is the gas in date? The pistons do dry out and have to be oiled with special oil.
Dec 24, 2012 | Stanley Bostitch Nail Gun
De Walt DW988 XRP 18v 1/2" Hammer Drill have
Jan 25, 2011 | Dewalt Drills
Feb 02, 2010 | Dewalt Saws
Nail comes out another hole
are you using the right nails and are they inserted properly if this is an angle gun? Also look for a jammed nail that might be causing this. look at the magazine bolts to make sure they are tight. You can go to Paslode.com for the owners manual and troubleshooting guide.
Sep 10, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Dewalt dc618 nailer is not firing
I have both the DC616 and 618 and have used them sucessfully for about three years. Two main things go wrong. There is a drive belt that breaks (drives the spool that give the energy to drive in the nails), second are two small rubber bands on either side of the drive head that break. The bands can be accessed by taking off the front silver cover, the drive belt is access by spliting the case. Make sure you are using the correct nails or the drive pin may become bent and will jamb repeatedly. Hope that helps!
Nov 18, 2008 | Dewalt DC616kn 18 - volt 16 - gauge...
De walt de9118 charger
Aug 07, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Dewalt DC616kn 18 - volt 16 - gauge straight finish nailer Logo
161 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
