Question about Bosch 24 in. PIE675T01E Electric Cooktop
How do I stop a flashing E on bosch cook top - Bosch 24 in. PIE675T01E Electric Cooktop
I have a Bosch model 8054 gas cooktop and the decals under the knobs are worn away, any ideas for replacements , called Bosch. They said they don't have replacement decals
Hello -
I found some suggestions in an answer to a similar question for a different make of gas cook top. One of the suggestions here may be one you would wish to follow:
http://forums.whirlpool.net.au/archive/1772463
Best wishes.
Jan 11, 2018 | Bosch Cooktops
My clients ceramic hob has small scratches appear on one of the pan areas it's only a week old how can this happen the pans seemed clean underside .
ceramic tops are not made for sliding pans or skillets on . as on GAS ranges. give them a bottle of cook top cleaning creme
Dec 22, 2015 | Bosch 233331 - GLASS CERAMIC HOB TOP
Bosch NET9652UC STOVE TOP shows Er 42
Er42 constantly slashing on my stove top, sometimes lasted for hours. When that happened you can't use the stove top until it stops. What should I do to stop the slashing?
Feb 20, 2013 | Bosch 30 in. NET7452UC Electric Cooktop
My cook top model PGL98xUC striker won't stop sparking. What can I do to fix it?
Hi madpottery,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 14, 2011 | Bosch Cooktops
Clicking of igniters continues non-stop unless I unplug the cook top.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
Sep 25, 2010 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Bosch 500 Glass Cooktop discoloration
DeBruce Polish will remove the discoloringin the cook top, also use it on pans to remove any deposits that may transfer to cook top. debrucepolish.com
Jan 04, 2009 | Cooktops
Discoloration of cooking surface (darkened) on Bosch stove
I'm Bruce of DeBruce Polish, our new polish is non-toxic and odorless and non abrasive, should take care of your problem. We designed it for stainless steel, and have faboulous results on ceramic stove tops, and chrome and many other uses. Even removes permanent magic marker. web site will be up soon debrucepolish.com. Phone 612-220-2236.
Jan 02, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Bosch 24 in. PIE675T01E Electric Cooktop Logo
Top Bosch Cooktops Experts
Paul Carew
Jay Finke
Jay Finke
Narinder Chhina
Narinder Chhina
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
