Question about Black & Decker EC475B Extra Tall Electric Can Opener
I can't snap in the magnet on the can opener
LThat's it above. I aligned the openings, press hard but it does not click into place
How do i put new ink cartridge in
The printer must be ON. Open the Front Access Door of the Printer. You should see a Carriage ( the part that holds the cartridges ) move from left to right. Wait for the Carriage to Stop ( usually in center ).
Open the packaging tape from the cartridge and slide the cartridge inside the Cartridge slot. Insert the cartridge from below and Push the cartridge upwards to snap. You will hear the snap sound.
Close the front access door and wait for the Cartridges to be aligned. After the printer has printed alignment sheet, Place it face down on the Scanner glass and press OK button.
The alignment will be complete.
Regards,Suhail
Dec 02, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
WE ARE GETTING "MEM TEST FAILURE REPLACE DIMM 1" M: 98240 19614
1. Turn the device off and disconnect the power cord.
2. Disconnect all interface cables.
3. Remove the right side panel by sliding it towards the rear of the device until the side slides from the device.
4. Open the access door by pulling on the metal tab.
5. Remove the DIMM from the antistatic package.
6. Hold the DIMM by the edges, and align the notches on the DIMM with the DIMM slot.
(Check that the locks on each side of the DIMM slot are open.)
7. Press the DIMM straight into the slot, and press firmly. Make sure the locks on each side of the DIMM snap into place.
NOTE To remove a DIMM, first release the locks.
8. Close the access door, and press firmly until it snaps into place.
9. To replace the right side panel, line up the alignment arrows and slide the panel toward the front of the device until it latches into place.
10. Reconnect the interface cable(s) and the power cord.
11. Turn the device on.
144-pin dual inline memory module (DIMM)
here's the memory part number/numbers you'll need also:
144-pin 133MHz DDR2 DIMM
Boosts the ability of the device to handle
large or complex print jobs.
32 MB CB420A
64 MB CB421A
128 MB CB422A
256 MB CB423A
Hope this helps and if so please mark fixya
Jun 25, 2010 | HP LaserJet P3005n Printer
Error 3 (E3) on Schwinn 240 recumbent bike. How can I fix it?
No speed/RPM reading, Console displays "E3" error code
Check data cable integrity All wires in cable should be intact. If any are cut or crimped, replace cable.
Check data cable connections/orientation, insure cable is connected securely and oriented properly. Small latch on connector should line up and snap into place.
Check magnet position (requires shroud removal) Magnet should be in place on flywheel. If no magnet is present, replace the flywheel or the entire base unit (if unable to replace flywheel).
Check RPM Sensor (requires shroud removal) RPM sensor should be aligned with magnet and connected to data cable. Realign sensor if necessary ( 1/8" clearance between sensor and flywheel) if still error 3 then check the sensor with a multi meter unplug sensor leads attach meter to sensor connectors. Have someone by hand rotate the pedal while you observe the multi meter opening and closing the internal sensor circuit if no change in meter readings then replace the sensor.
May 23, 2010 | Schwinn Exercise & Fitness
The Disk Trey gets stuck now almost all the time and takes many times clicking the open button to get it to finally come out what can i do to fix it?
Two problem cause this first the eject motor is not
strong enough to break the magnetic seal holding the
CD firmly in place , second is dust and grime build
up on the gears will put more friction ,making eject
a struggle for the drive.
Short term solution is to press the eject button
wait 1 sec and then slap to top of the box
over CD rom drive HARD. this will break the magnetic
seal and the tray should open.
The permanent solution is to remove the drive open
it up and clean it and re-lube the mechanism.
If you have any questions feel free to ask.
Rob
Jan 28, 2010 | Microsoft Xbox 360 Console
How do i install ink cartridge for HP 4355?
To install the ink cartridge
1) Press the On button. After you press the ON button, wait for the print cartridge prompt before continuing.
2) Open the print cartridge door. Lift the print cartridge door. The print cartridge moves to the right side.
3) Remove tape from both cartridges. Pull the tab to remove the tape from both print cartridges.
Important : Do not touch copper-colored contacts or retape the cartridges.
4) Insert the tri-color print cartridge.
Caution : The device must be On before you can insert the print cartridges.
a) Slide the tri-color print cartridges into the left slot.
b) Push the top part of the cartridges firmly up and into the slot until it snaps into place.
5) Insert the black print cartridge.
a) Slide the black print cartridge into the right slot.
b) Push the top part of the cartridge firmly up and into the slot until it snaps into place.
c) Make sure both cartridges are secure, Close the print cartridge door.
6) Align the print cartridges.
a) Press OK to print the alignment page, (Make sure you have loaded plain white paper in the bottom tray,)
b) Remove the alignment page from the output tray.
c) Place the alignment page face down into the document feeder.
d) Press OK to scan the alignment page.
After the page has scanned, alignment is complete.
Hope this helps. Please rate my response.
Thanks
Have a good day.
Dec 01, 2009 | HP Office Equipment & Supplies
How do I change the ink cartridge on my Dell 810 printer
Ink Cartridge Maintenance Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridge:
  1. Load plain paper. For more information, see Loading Paper.
  2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
In Windows 2000, click Start® Settings® Printers.
  1. Right-click the Dell AIO 810 icon.
  2. Click Printing Preferences.
The Printing Preferences dialog box opens.
  1. Click the Maintenance tab.
  2. Click Align Print Cartridge.
  3. Click Print.
A blue and black alignment page prints.
  1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
  1. Press the Scan button scanicoa.jpg .
The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
Hope it helped.
Nov 22, 2009 | Office Equipment & Supplies
Replaced lexmark carttridge for printer problem
here you go the instructions out of the user guide this should help
Aligning the print cartridges
Load plain paper.
2 Open the Solution Center.
3 From the Maintenance tab, click Align to fix blurry edges.
Maintaining the printer
52
Click Print.
The alignment page prints.
5 Open the top cover of the printer.
6 Place the printed alignment page facedown on the scanner glass in the lower right corner, and then close the
top cover.
1 2
7
Press .
After a few seconds, an Alignment Success dialog appears on your computer screen.
8 Click Close.
9 Click Exit.
If you aligned the cartridges to improve print quality, print y
Oct 23, 2009 | Lexmark X2500 All-In-One Printer
How do you change ink
To Change the ink Cartridge please follow the instructions as under:
  1. Turn on your computer and open the front cover of your printer.
  2. The Cartridges will automatically come in center.
  3. Pull up the holder lid and carefully remove the print cartridge on a 60 degree angle.
  4. Press the ink cartridges into the slots and listen for a clicking noise after the insertion
  5. Remove the tape from your new print cartridge and carefully put it in on a 60 degree angle, snap the lid back in place. close the printer.
  6. Open the printer software in your computer, click the tab maintenance and click install a new cartridge and click the number. Print an alignment page.That's it !
Thank you for using Fixya
Oct 08, 2009 | Lexmark X4550 Multifunction Wireless Color...
Door well not stay closed.our door hinges replaceable
If your machine is a Hobart LX series, changing the hinges will probably not remedy your door closing issue.
I'd start at the door magnet. It's located under the handle at the top RH side of the door. Verify that it is there. Next I'd check to see if the other magnet is in place at the top front RH side of the top interior 'ceiling'. It's held in place by a bracket that runs the entire width of the unit.
When the door is closed, these two magnets attract to each other with a firm "snap" and that is what keeps the door closed.
If your door wants to spring open slightly or lazily rest closed without the above mentioned "snap" then you'll need to visually inspect the bottom edge of the door for any cracks or deformation, particularly in the corners. This deformation will cause the bottom of the door to bind against the lower threshold of the machine and keep it from closing. You'll have to remove the door to properly inspect and reform it.
Sadly, my money is on the door being deformed in some way. Hope this helps.
Jul 27, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Have just unpacked new HP Photosmart C4200 All-in-One Cannot get machine to accept cartidges which werre supplied with the printer
NOTE: The product must be on before you can insert the print cartridges.
  1. Open the print cartridge door. Figure 7: Opening the print cartridge door c00880893.jpg
  2. Make sure the print carriage moves to the right. If it does not move to the right, turn the device off, then turn it back on again.
  3. Open the packaging and remove the tape from both cartridges. Figure 8: Removing the tape c00880894.jpg CAUTION: Do not touch the copper-colored contacts or re-tape the cartridges.
  4. Hold the cartridges with the HP logo on top.
  5. Insert tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot . Figure 9: Inserting the print cartridges c00880895.jpgc00880896.jpg
  6. Push the cartridge firmly into the slot until it snaps into place.
  7. Close the print cartridge door.
Step eight: Align the print cartridges When a new print cartridge is installed, the product aligns the cartridge. Align the print cartridges at any other time by using the software installed with the product. Aligning the print cartridges ensures high-quality output. NOTE: If a print cartridge is removed and reinserted, the product will not prompt for an alignment. The product memory retains the alignment values for that print cartridge. Follow these steps to align newly installed print cartridges.
  1. When prompted, make sure that plain, white letter or A4 paper is loaded in the input tray, and then press the button next to OK . The alignment page prints.
  2. Lift the lid. Place the top of the alignment page face-down on the front, right corner of the scanner glass. Figure 10: Placing the alignment page c00880898.jpg
  3. Close the lid.
  4. Press the button next to OK . When the On button stops flashing, the alignment is complete and the page can be removed.
Nov 18, 2008 | HP Computers & Internet
Black & Decker EC475B Extra Tall Electric Can Opener Logo
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
