Question about Dell 2230d Laser Printer
I was trying to print and then all of the lights began flashing on the front of the printer and it will not print for me
How can I get my HP Laser Jet 1320 printer to get unlocked from red flashing light that prevents prnter from working? When I printed a three page e-mail report, after the first three were printed, an...
I had similar problems with my Printer also. Believe me, it can happen if the printer driver is corrupted or if your windows installation or windows update caused some conflict issues with the printer. I got online help from TheBestPcDoctors. If you need, you can contact them or call them
www.thebestpcdoctor.com or via 877-407-9229
Sep 27, 2011 | HP LaserJet 1320n Printer
I sent a print job to the printer and it started to print and just stopped. The ink, paper, & power source lights all began flashing simultaneously. There was no paper jam and the ink cartridges are...
make sure there is no pending print job in print spooler if it is there then clear it before giving the print .for clearing In run window type services.msc and the go to print spooler option just stop and restart the service. and also switch off and switch on the printer and try to cancel all the documents form print spooler it will remove all pending jobs.
Nov 21, 2009 | Epson Stylus 880 InkJet Color Printer
My Printer won't print, Amber light won't stop flashing.
Install the new cartridge for permanent solution for this error.
Sep 17, 2009 | HP DeskJet 940c InkJet Printer
Printer makes non-stop clicking noise when plugged in. Had been printing a document, it stopped halfway through, froze, began clicking and the error light began flashing. Doesn't respond to any of the...
The rollers of the printer must have accumulated dust such as sand or something. Try cleaning with alcohol the parts which moves in time of printing. The curcuit may also be damaged. Thanx.
Aug 12, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Error light keeps on flashing blue light at the
These are your possibilities based on your error.
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document. See
Solving print problems on page 97.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document. See
Jun 14, 2009 | Brother HL-2170W Laser Printer
Brother HL-2070N red "paper" light flashes after a paper jam
http://welcome.solutions.brother.com
Try this
[LED Indication]
The Paper LED is flashing.
Meaning of LED Indication
Front cover is open:
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
Print overrun:
Clean drum unit:
The corona wire needs to be cleaned.
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Jan 23, 2009 | Brother HL-2070N Laser Printer
Epson 220 not printing cd labels anymore
Clean the white areas on the tray with a light solvent cleaner like windolene/windex liquid. Also try giving the tray a helping hand as it is started to be fed into the printer
Nov 08, 2008 | Epson Stylus Photo R220 InkJet Printer
Canon i550 printer stoipped printing
My cannon printer no longer responds to any commands. I get 4 yellow blinking lights and then 1 green blinker.
Oct 09, 2008 | Canon BubbleJet i550 InkJet Printer
Changed drum, did the reset but will not print.
I began to check all my plug-ins and realized the USB to the printer had unplugged . . .DUH! Talk about feeling dumb.
Apr 24, 2008 | Brother HL-2040 Laser Printer
I have the above printer
Most likely the fuser unit isn't warming up try shut down and restart of the printer but normally replacement fuser required.
Thanks J
Jan 09, 2008 | Brother HL-2040 Laser Printer
Dell 2230d Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
