Question about Hitachi Drills
Hitachi hammer drill stoped working - Hitachi Drills
  • 2712 Answers
SOURCE: hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Posted on Aug 27, 2008
SOURCE: Matika hammer drill - bit stuck
The spade bit sold with the hammer drill was actually too large for the hammer drill. We found that the spade bit had over heated (not from overuse or heavy use as only two ladies were using the hammer drill) but because the bit was too large it put too much weight on the drill. The bit had to be removed from the chuck using a hammer and force causing a bearing to come out and the chuck now needs repair. Solution repair the chuck on the hammer drill and buy a lighter spade bit. Then continue jackhammering the cement out of the shower cubicle.
Posted on Mar 27, 2009
  • 48 Answers
SOURCE: Jaws of my Hitachi 18V cordless drill are locked shut
Other than two quick squirts of WD40 and nice new chuck key?
Posted on Apr 07, 2009
  • 211 Answers
SOURCE: Bosch GBH 2-20 SE hammer drill stopped working
hi
check the cord and the switch to have continuity,the wires,the brushes,the rotor and stator.
regards savumihai71
Posted on Dec 16, 2009
  • 211 Answers
SOURCE: my hitachi drill is working funny
hi
try to charge the battery at full level and see what happens then.
regards savumihai71
My drilling machine 26mm active pro brand. i am using drilling one hrs ok after running problem hammering mode stoped only running not working for machine not proper working in hammaring mode.what...
Sheared hammer pin, stuck hammer or failure of a bushing or washer. A sharp tap with a rubber mallet in an area not likely to be damaged can sometimes free stuck hammers, if not it's a disassembly.
May 10, 2014 | Drills
I have a hitiachi DH38ye drill and it won't accept the Bosch spline bits. they go in ok but the chuck won't lock. The drill accepts the hammer bits fine but won't accept the drill bits
you have me stumped on this one. The tool you have is a spline shank hammer and it should accept all standard spline bits and also hammer iron that is made for these. Is it possible that the Bosch bit has a burr on the splines not allowing it to lock? I have checked the Hitachi site and found no reason it would not work. I will continue checking though.
Apr 23, 2011 | Hitachi Drills
HI,my Hitachi 18v DV18DL Hammer drill will only run in reverse,any help?TKS Rob
the triger contacts could be fouled. clean the contacts if it doesn"t work you can order a new trigger assembly from hitachi---ACE hardware may even carry this
Dec 30, 2010 | Hitachi Dv18dl 1/2 18v Hammer...
Have a hitachi cordless drill that the chuck has become stuck and cannot remove drill bit
Soak it with WD-40 and let it set so the lub runs down into the chuck and then try...
heatman101
Mar 21, 2010 | Hitachi 18V Lithium Ion Cordless Hammer...
I have a 18v Hitachi 3ah battery which works fine in my saw, lantern & torch but will not work in drills
Batterys are not necessarily universal even withing voltage ratings by make and model. A bone of contention for many users for many years.
Rigid and Ryobi are two companies that have use standard batteries for their tool line. Consider this when making future tool purchasing decisions.
Thanks for your interest in FixYa.com
Feb 14, 2010 | Hitachi Dv18dl 1/2 18v Hammer...
My hitachi drill is working funny
hi
regards savumihai71
Dec 13, 2009 | Hitachi 18V Lithium Ion Cordless Hammer...
I have a three year old hitachi dv18dl cordless hammerdrill. The low gear is stripped and the trigger is intermittant. I tried taking it apart but saw nothing obvious. Any ideas on what to do or where to...
http://www.ereplacementparts.com/hitachi-dv18dl-18v-30ah-lithium-ion-cordless-hammer-drill-parts-c-7927_13467_13346.html
Here is the diagram for the drill. I would replace the gearbox and dc control switch. But it may be cheaper to buy a new drill.
Nov 25, 2009 | Hitachi Dv18dl 1/2 18v Cordless Hammer...
No hammer effect, motor work OK
First try the switch for hammerdrill/drill action. If it feels loose, then its internal. if it feels ok, then your hammers on the cage are stuck, frozen or worn.
Jul 17, 2009 | Hitachi DH38YE 1 1/2" Spline Rotary Hammer
Hammer drill will not hammer.
Need a new clutch/tranny. You can find it online - look up tool parts on Google. Tool Parts Direct is a good source. Please rate me
Jun 03, 2009 | Hitachi 18V Lithium Ion Cordless Hammer...
Drills Logo
43 people viewed this question
Top Hitachi Drills Experts
John Trevino
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
