Question about Symbol Batch Barcode Scanner P360/460 Memory Scanner
Barcode scanner P360 will not scan my barcode
I use a Zebra printer to priint my barcodes for inventory. How do I change my P360 to scan this barcode ?
SOURCE: Enter function
Hi Lee,
It can be done by programming the scanning the 'Send Enter Key' barcode twice, from the owners manual.
eg
Scan the barcodes -
Send All Data, Send Enter Key, Send Enter Key, Save
Posted on Oct 17, 2007
  • 58 Answers
SOURCE: Symbol Spark LS 1004 Problem
What barcode scanner do you have? USB, SERIAL or ps2.
by the way. the old computer is it like NCR, SIEMENS or IBM because then you need to re-program your scanner.
i found a manual where you can set your pc type with barcode scanner. be careful not to scan reset defaults. because you will loose your settings.
look at chapter 4-9 and 4-10
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3380601bpdf&sliceId=&dialogID=33708056&stateId=0%200%205522749
If you don't know ask me. we don't want to lose al the settings.
good luck
Posted on Dec 07, 2007
  • 25 Answers
SOURCE: Symbol LS 4278 Barcode Scanner - 3 Clicks
Does it beep each time you pull the trigger while the beem is on the barcode?
Posted on Jan 23, 2008
geras2000gas
SOURCE: Barcode scanner scans and beeps, but will not put the numbers in the computer
First:
a) Do you have the scanner connected to an Y cable ?
If yes, you need to connect to the PS/2 port on the computer and you have to connect another 101 keys keyboard
/ PS/2 computer port
scanner ----
\ 101 keys keyboard.
restart the computer and will work.
the system will include the driver in the keyboards.
Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
b) if you do not have the Y cable:
just install the driver : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Good Luck
Posted on Dec 04, 2008
SOURCE: symbol barcode scanner, handheld, cordless, yellow
error code communication error the scanner is not communicating with the cradle. It is important that the synapse cable is plugged into the cradle before the cradle power suply is pluged into a outlet. also could be the scanner did not pair up with the cradle correctly try rescanning the barcode on the cradle.
Posted on Jan 27, 2009
How to Scan 2D barcode on MC55 (mc5574). How to enable Imager mode to scan 2d , as currently my mobile (mc55) only scans 1d barcodes. Thanks
unfortunatley if your device is preconfigured for 1d only you will not beable to scan or decode 2d barcodes. Which configuration of the mc55 do you currently have? if you can provide me with this information i can let you know if it is possible or not.
Oct 13, 2010 | Zebra Symbol MC5574 Wireless Enterprise...
The printer is not feeding the label until the perferated line. it only feeds about an inch and then stops and then feeds another inch. on our other zebra once the feed button is pushed the printer feeds...
Simple yeah. Printer calibration is the problem.
see this video , http://vodpod.com/watch/3948392-how-to-calibrate-zebra-tlp-2844-printer
For over 4 years, Trridev Labels has provided Barcoding solutions and Barcoding equipment to a wide range of large and small companies in virtually every industry sector. Trridev Labels offers more than 10,000 brand name products and services such as Barcode Labels, Barcode Printers, Barcode Scanners, Thermal Transfer Ribbons (Wax, Wax Resin, Resin), ID Card Printers.
Contact Trridev Labelss Mfg Co – If you have requirement of Barcode Labels, Barcode Printers , Barcode Scanners, Self Adhesive Labels, Thermal Transfer Ribbons, Printer Heads, RFID Solutions, Barcoding Solutions. We provide you a complete solutions for barcode.
Call us at +91 – 96000 07995 / 98840 42305 To Get the Best Price Tagged with Best Quality.
Jul 02, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Our company has several Zebra printers that print out barcodes that are scanned using handheld scanners for many things including inventory management. The labels that come from ONE of these Zebras...
Power off printer. Press and hold pause button while power on. This will print dark black line across the entire label. Check for white vertical lines. If you see any in the area of the label where you are experiencing a problem then the printhead should be replaced. Power off and on to exit diagnostics.
Jun 25, 2010 | Zebra 105SL Thermal Label Printer
Unwanted underscores added to 2D barcode scan
are they the same barcode type?
what is the font set at? using Arial or other fonts can make the software send a more complicated image. use the Zebra Triuverate font. this keeps it simple. also, do a print out of the settings on each printer and compare them line by line. change the settings to match the printer that is printing correctly.
Jun 03, 2009 | Zebra Z4Mplus Label Printer
Zebra S4M Lable Printer Not Scanning
You might want to check the barcode ratio, bar width, printer speed and printer darkness. I am assuming that you are creating the barcode in some sort of label design package, correct? You either need wider bars, or make sure you have enough quiet zone on both sides of the barcode, so shrinking it might be the solution as well.
Apr 12, 2009 | Zebra S4M Thermal Label Printer
CAN'T PRINT USING A ZEBRA PORTABLE PT400 PRINTER
Verify that the zebra software is loaded. Depending on the type of zebra printer used, might need special software. Zebra printers use the "zebra printer language" (zpl), not a standardized print language.
Dec 16, 2008 | Zebra Symbol Technologies MC909X-G Series...
Symbol Batch Barcode Scanner P360/460 Memory Scanner Logo
15 people viewed this question
Top Symbol Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Symbol Office Equipment and Supply Expert? Answer questions, earn points and help others
