Question about Linksys SE1500
Slow or droppped connection
I have a linksys se1500 for a small business network. it has two computers connected to it. we are having trouble with consistent connection. the signal will either be slow or just drop out completely. when we turn the power off then on for the switch we regain connection for a while then the problem will repeat.
5 Suggested Answers
fossilruins
  • 114 Answers
SOURCE: linksys nh1005 ver. 2.1
first make sure that you are getting lights on all of the devices at the hub, and also that all four are getting ip addresses. if the 4th device is not getting an ip address but does show connected to the hub, then the problem is more than likely your router is not serving enough ip's for all of your devices. also make sure that everyone of the devices are not assigning a static ip that could possibly knock out one of your devices, or if they are all static ips, that one of them is not set to the same ip as another.
Posted on Jun 21, 2008
SOURCE: SD 2008 linksys switch slow
Same problem here - switch appears to revert to 10MB on some ports and 100MB on others. Tried to force 1000 from NIC, but that just lost connectivity - had to reset back to auto to get any connectivity at all
Posted on Nov 11, 2008
ucdpdiddy
SOURCE: LINKSYS SWITCH
No. You will create a bridge loop. The only way to do this is if you have a smart switch capable of aggregating multiple ports into a virtual trunk.
Posted on Nov 24, 2008
  • 4348 Answers
SOURCE: my network is slow while
It is difficult to have havy network traffic and not show anything. The stacking should not be a factor, it is the actual file movement that is causing this, and there may not be a way around it. One possibility is to limit the bandwidth of the file transfer, but that just makes IT take longer....
It is difficult to repair around factual reality.
Posted on Jan 23, 2011
Laptop won't connect to net through the switch
After connecting your pc or laptop to the switch to network and sharing center in your pc or laptop and from the network check the ip and dns entered properly or if you are using dhcp connection check obtain ip automatically is checked
if again the problem persist get the ip of ur gate way and ping it with your pc
or contact the network providers
thank you
Apr 07, 2014 | Cisco Linksys Se1500 5-port Fast Ethernet...
When I try to access my cisco e1000 router on firefox or google it keeps saying that it is busy and will not connect
Are you trying to access the setup page of the router?
Did you install the Cisco connect software on your main computer?
If you have cisco connect software installed then open Cisco connect.
Go to Router settings. Click on Advanced settings. It will open the setup page of your router.
If the cisco connect is not installed then try to power cycle the router. Unplug the power to the router, wait for 30 seconds. Plug in the power cable. Wait for 30 seconds.
Now try to access the setup page.
If that is also not working then I will suggest you to reset the router and reconfigure it manually.
Watch video.
How to reset Linksys router.
Watch Video:
Linksys router setup
Feb 24, 2012 | Cisco Linksys E1000 WirelessN Broadband...
I currently have 2 sony computers connected to my Linksys WRT310N Router. I just bought a new Dell Laptop for my home business and I can't get it connected.
I'm assuming your new computer uses Win 7, so try opening Control Panel, Network and Sharing Center - then elect to set up a new wireless network. You should 'see' your wifi network - if not, then come back with that info & we'll take it from there...
May 03, 2011 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Having trouble with initial connection to an existing wireless network wireless router is a cisco wireless-n broadband router and we have 2 laptops and a printer on a wirelss network already
Follow these instructions to connect to a wireless network using the Linksys Wireless Manager.
Step 1:
Launch the Linksys Wireless Manager. To learn how to access the Linksys Wireless Manager, click here.
Step 2:
In the Connect to a Wireless Network screen, locate the name of your wireless network in the list.
NOTE: If your wireless network is not in the list, click here to learn How to Connect to a Hidden Wireless Network. If your wireless network supports Wi-Fi Protected Setup kb17673-005_en.png, click here to learn How to Connect Using Wi-Fi Protected Setup.
Step 3:
Select your network. Then click Connect.
Nov 01, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Network setup questions.
You could program the MAC addresses of only the computers you wan't to be able to connect to the router. It seems like you could add the MAC of your girlfriends computer your business computer and any other specific computer you wan't to allow to connect and this would leave all your current securities in place. Here are instructions if this solution sounds like what you need. http://www1.linksys.com/support/troubleshoot/wireless/wireless_router_config/wireless_mac_filtering.html
Nov 21, 2009 | Linksys Wireless-G WRT54G Router
How do you connect a Linksys NH1005 v2 hub and whats the difference between a hub and a router?
A router takes an Internet connection, routes it to several other computers and provides each of these computers with their own IP address.
A Hub, on the other hand, will split the Internet, but the various ports on the hub will all have a single IP address. Makes it hard to use a computer for much of anything, if it is the second computer, you'll have trouble getting access.
Nov 13, 2009 | Linksys (NH1005) 5x10/100 Mbps Networking...
I need help to connect my Linksys WRT54GS router.
you connect your caple from your provider and all connections to your station then start setup by going to the browser and typing 192.168.2.1 for setup you can download a step by step instruction from LINKSYS
Nov 07, 2009 | Linksys Wireless-G WRT54GS Router...
Want to have wireless with my Limksys Sr2016 switch
Go to: www.speedtest.net with a laptop on your network.
Find your speed. now repeat on same laptop plugged directly into the cable madem.
Do the settingsa change much?
If so, your network is at fault. If not, Comcast is lying to you.
May 12, 2009 | Linksys SR2016 16x1000 Mbps Networking...
Wireless problems with windows vista
You just need to remove the preferred networks on your vista, follow this.
Right click the wireless icon>network and sharing center>manage wireless network>remove all preferred networks.click OK.
Then connect again to your network that should solve it.
Jun 13, 2008 | Linksys Wireless-G Broadband Router
Linksys SE1500 Logo
32 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
