Question about Dryers
Kenmore elite model 11068062801
Dryer suddenly started flashing F 40 code and sopped working. what does this mean?
  • 146 Answers
SOURCE: kenmore elite eletric dryer model 8708
I've never heard of an F70 I have heard of an F07 which is possibly a motor controller error.
Posted on Dec 22, 2007
qpoint
  • 69 Answers
SOURCE: kenmore elite oasis dryer model #110.6708 will not operate
F40 = thermal fuse blown.
If the fuse is OK the error points to a communication problem between the machine control board and motor control board (check connectors).
Posted on Mar 19, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Oasis Elite gas dryer,beeping, flashes OF
This symptom indicates a stuck key on the user interface control board.
Replacing this control board would most likely fix this type of problem.
The part number for the user interface for this model is 8564374.
You can order this part from SearsPartsDirect.com, RepairClinic.com, PartSelect.com etc.
The procedure for replacing this control board is shown in the images below.
Before buying any parts I suggest you access the interface ribbon and disconnect it and then connect it back and see if there is any improvement.
You might also remove the interface from the console and check the console for any stuck buttons.
Remember to unplug the washer first.
http://media.fotki.com/1_p,wkgbsdrbswtkdqwxgtqsskgwtqkq,vi/ksgtwdgrtxkrrffsdss/1/1303472/5961857/image29464img-or.jpg
http://media.fotki.com/1_p,sqrbbsbrrbwrbdtxgtqsskgwtqkq,vi/kbqtdwdswxkbswddwbg/1/1303472/5961857/image23056img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Dryer Kenmore Elite HE5 show the Code F70...
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 28, 2010
i4get75
  • 39 Answers
SOURCE: what is an F2 code
http://www.managemylife.com/mmh/questions/231650-my-dryer-is-displaying-f2-whats-wrong-1
Posted on Jul 24, 2011
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Elite Oasis. What does the F-40 code mean?
F-40 is a communication error between the main board and the motor control unit, or it could be a bad inline fuse between the two in the wire harness on the l-1 side.
Oct 23, 2015 | Kenmore Elite Oasis 6808 Electric Dryer
Have kenmore elite oasis electric dryer model 11068062701 gives us code f, have misplaced manual
Hi and welcome to FixYa, I am Kelly
Your model number appears to be in error: 110.68062701 is what you posted but the manuals are 110.68062800 and 110.68062801.
Parts list:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Dryer-Parts/Model-11068062801/0583/0151200?searchedModel=110.68062&blt=15
The onwers manual is linked off of this page:
http://www.managemylife.com/mmh/owner_manuals/6396/KENMORE-ELITE-Residential-Dryer-
and uses this link:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0801316.pdf (6.44 mb)
The F code is usually followed by another number F1, F2, F20 etc. I can help you but really need to know what the other number is. When the dryer shows an F code it is telling you that there is a failure. Without the number following the "F" there is no way of knowing what that failure is.
If there are any other symptoms can you please post them here?
Thanks for choosing FixYa,
Kelly
May 30, 2011 | Dryers
Kenmore elite oasis dryer model #110.6708 will not operate. flashes f-40. what does f-40 mean?
Mar 19, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
My Kenmore dryer is flashing a code F23 what does this mean?
F33 Possible Cause / Procedure 1.-Unplug washer or disconect power  2.- Check for wire harness condition to the pump and Central Contral Unit (CCU). 3.-Plug in the
http://www.scribd.com/doc/7075573/Whirlpool-Kenmore-HE2-Plus-Troubleshooting-Tech-Sheet-8540259
Was this helpful?
May 12, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite Oasis Steam dryer runs but gets a F 40 code and stops. Just plugged it in to do my first load. Tried pulling out and checking lint in vent. It seemed to over heat the first time then sat a...
After just now calling the service center it seems that unplugging the machine for 30 seconds or so will reset the control panel. The F 40 code means the signal wasn't working in the machine and resetting it solved the problem. Kind of like when you have to unplug the computer sometimes.
Dec 31, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE5 Electric Dryer
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
May 07, 2008 | Kenmore Elite HE4 Electric Dryer
Need help with OLD dryer
IF YOU MEAN THAT THE DRYER STARTS BACK UP WHEN YOU CLOSE THE DOOR, THE PUSH TO START SWITCH IS SHORTED. CHECK TO SEE IF THE PUSH TO START BUTTON IS STUCK PRESSED IN AND NOT SPRINGING BACK OUT.
IF IT IS STUCK, TRY WD-40 TO LOOSTEN IT. OTHERWISE, REPLACE THE SWITCH.
IF THE DRYER KEEPS RUNNING WHEN YOU "OPEN" THE DOOR, THE DOOR SWITCH IS SHORTED. REPLACE THE DOOR SWITCH.
Mar 31, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite
It should just mean "Power Failure". Restart your dryer. Does your house loose power a lot? Or just the dryer. Check your power to the dryer.
Nov 18, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Dryers Experts
