Question about Frigidaire FAFS4473LR Washer
Ef2 error Affinity paused ef2 error suds
2 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: Pause Error - Frigidaire Affinity LTF6000ES0
If you just paused the washer and now displays a error try draining any existing water all out of the machine.Before re filling it see if you still get the error message.I'll be happy to guide you through this.
Posted on May 21, 2008
Affinity washer flashing EFO
Good Morning Friend,
I understand that your Frigidaire Affinity washer, model# ATF7000E, is flashing an EFO code. I do not show an EFO code for your appliance.
I do show an EF1 code, which means the drain pump is clogged. In this instance you would unclog the drain pump.
I also show an EF2 code, which means too much soap was used. All you would do for this would be to try using less soap.
It could also be a false error code. I suggest resetting your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Affinity ATF7000E Front Load...
Sud error code
I found that mine was having a sud error. I removed the lower front panel and removed the filter. It was full of lint and loose change. I reinstalled the filter and haven't had a problem since. On a side note I found something interesting laying inside. A service tech guide wich stated to do exactly what I had done.
Nov 27, 2012 | Maytag EPIC MFW9700S Front Load Washer
Frigidaire Affinity showing EF2
Ef2 could mean the vent hose is blocked or has come off.Slide it out from the wall and make sure the hose is ok.Hope this helps.
Sep 07, 2012 | Frigidaire Affinity ATF7000E Front Load...
Fridgidair affinity washer paused with error code EF2
According to SearsPartsDirect.com ( http://www.searspartsdirect.com/washer-repair/error-codes/frigidaire-front-load-washer-error-codes.html ) : EF2 Condition Too much suds Check/Repair Reduce the amount of high-efficiency (HE) high-efficiency detergent being used in the washer.
Aug 31, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
My atf8000fsi washer keeps pausing. It will not complete any cycle. I have to sit right by it and keep hitting start. It seems to keep restarting the cycle but never spins or completes the cycle. The last...
EF2 on a Frigidaire washing machine indicates too much soap which could mean the pressure chamber is blocked or the pressure switch is held closed for some other reason. Try removing the small bore hose from the pressure switch and listen for a click when you do so, if there is a click it will indicate you have a pressure chamber blockage. The chamber will need to be removed and cleaned out don't just blow into it via the attached hose because it will block again after a few washes
Mar 29, 2017 | Frigidaire Affinity ATF8000FS
Giving E20 error
Could be a clogged pump but it is almost always oversudsing due to incorrect amounts or kind of detergent being used. If the artificial intel monitoring the motor's amp draw gets a slight current change, then it determines it needs to get rid of suds. If it can't resolve the issue it goes into a suds lockdown and declares an error.
AFFINITY WASHER SERVICE MANUAL
May 24, 2010 | Frigidaire Affinity ATF8000FE
May 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FAFS4473LR Washer Logo
19 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
