Question about Fossil Watches
CHANGING BATTERIES ON FOSSIL WATCH ES-9873
MODEL ES 9873-CHANGING BATTERIES
escapement
  • 2334 Answers
SOURCE: remove links from fossil metal band
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 07, 2009
  • 373 Answers
SOURCE: Replacement battery for Philippe Starck Fossil watch
can you check on web site
Posted on Jan 31, 2009
SOURCE: Fossil Kaleido Watch LI22248 replacement
The Li2248 is the original kaleido watch and takes a single flat round inexpensive CR2016 battery. It is worth replacing it as they usually last for many many years, unlike the newer Kaleido two watches that take two batteries that together only last about a year. Walmart will usually let you borrow their tool to remove the watch. This one is very easy to remove with the tool. Walmart will likely not remove it for you since they did not sell it to you but I have been to many Walmarts in many states to readily loan the tool for you to use at the counter. IT is a special adjustable wrench that will set in the indentations on the back of the watch and then rotate counterclockwise to unscrew the back off. Once inside, you do need a very tiny screwdriver to LOOSEN, do not remove, the screw that holds the bracket against the battery. Once the screw is lightly loosened the bracket slides out and away from the screw and you can then easily remover the old and place in the new battery. You then retighten the tiny screw and then screw the back of the watch back onto its case by hand at first and then with the watch tool to tighten it. There is little chance of damaging the watch or loosing your waterproofing if you can get access to the watch wrench.
I have just opened a blog site devoted to answering questions about Fossil and gametime sports watches especially the sport logo watches. The blog site is sport logo watches blog at http://sportlogowatches.storeblogs.com/ I am putting together a pictorial on how to replace the batteries in the Kaleido II watches but this is quite a bit more challenging than yours. Good Luck!
Posted on Sep 30, 2009
digritz
  • 530 Answers
SOURCE: changing the date
Which Fossil do you own?
Analog Date Watch:
Date Setting
  1. Pull the crown out to position 2.
  2. Turn the crown either clockwise or counter-clockwise and set the date for the previous day. The direction that moves the date varies on different watch models.
Analog Automatic:
Time and Date Setting
  1. Pull crown out to position 2 and rotate clockwise to set time.
  2. Pull crown out to position 3; date will advance automatically. To set to required date, continue to rotate crown between positions 2 and 3.
  3. Push crown back to position 1.
Analog Digital:
Time and Calendar Setting
  1. Press and hold pusher A for 2 seconds to enter setting mode. Year will begin flashing.
  2. Press pusher A to select year, month, date, hour, minute, second, and then exit setting mode.
  3. Press pusher B to adjust digit.
  4. Press and hold pusher B to adjust digit automatically.
  5. If no pushers are operated for 30 seconds, setting will be returned to Normal Time Display.
These are the three most common Fossils. If yours isn't here please let me know which model you have and I'll get you the instructions.
Hope this helps.
Posted on Dec 12, 2009
escapement
  • 2334 Answers
SOURCE: time changing on fossil jr9120
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please
Posted on Apr 15, 2010
I have a fossil ES-1355 watch and it running slow. I installed a new battery and still running slow. Is there an adjustment I can make.
most batteries that run of a battery are controlled by a frequency crystal or electronic setting and is not adjustable
however take it to a watchmaker or jeweller as it may be adjustable using their instruments
May 15, 2016 | Fossil Watches
Fossil AM-3539 The watch has 2 batterys. one operates the changing face the other the watch movement. I replaced both batteries and now the face doesn't change. How do I re-set it?
Please note that many Fossil kaleido watches, especially the sports variety actually have THREE batteries. Two run the animation and one runs the time. The time one lasts much longer, usually a few years, but is smaller and buried a little deeper so you could overlook it if not paying attention. The two kaleido batteries are very visible and usually placed side to side. Pay attention though as for some of the watches those two batteries are set in the same way ( both positive sides up) while others, especially the sports variety have one battery positive side up and the other negative side up. It is important to replace them the same way or the watch will not work
Aug 12, 2011 | Watches
Changing the battery in my AM3696 Fossil watch
first you had to take off the band of your watch by detaching either of the spring bar, then you will see the case back, probably you had to use small screw tools with its caseback. note: your watch has two batteries. i hope i had been helped you.
Jul 25, 2011 | Fossil Animated Leather Ages AM3696 Watch...
Plastic band broke at the end where pin goes ,is f...
Go to their web site http://www.fossil.com/en_US/shop/customer_care/static/fossil-orderlinks.html and you will arrive at a page with ordering info. on how to buy new bands.
May 14, 2010 | Watches
Lost the battery for Fossil ES 8949 could you please tell me what battery I need for replacement
Link
Please refer to above link for the replacement of your Fossil Watch.
Suggest to contact the authorized dealer.
Thank you.
Dec 24, 2009 | Fossil AM3425 Wrist Watch
I have a fossil watch with ES-1426 3000601 model number. Wanted to know if it's fake or genuine. Where can I find the authenticity of this? A friend just gave it to me.
Be sure it is genuine as the Fossil watches are not in that league to make fakes. Even fake watch manufacturing needs a significant money investment,so, expectations for quick turnaround and investment recovery are common. This would not be possible with fake Fossil watches as the average price is about £70 for original and this is comparably low price in watch market.
Don't be scared away by this- Fossil is good brand: they just using cheap labor and parts, at the same time offering good looking and quality watches to masses.
Rate me, please.
Aug 22, 2009 | Fossil CH2473 Watch for Men
Changing battery
Generally, there's a small clip that can be held out of the way with a screw. You may need to hold it back, and tighten the screw in order to insert the battery. It may be enough to hold the clip out of the way.
Nov 01, 2007 | Fossil ES9825 Wrist Watch
Fossil JR8096 - Display Not Working
hi i have a watch very simalar. They run on two seperate batteries. sounds like one of them is dead. get the digigtal one replaced
Aug 21, 2007 | Fossil JR8096 Wrist Watch
Watches Logo
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
