Question about Whirlpool GHW9100L Front Load Washer
Washer will not drain or spin motor making clicking noise
My whirlpool washer GHW9100L washer will not  drain or spin the motor that the drain hose is attached to is making a clicking noise... Please help
  • bocam May 12, 2008
    what size ratchet are those screws on the bottom access panel. Can't get them off the machine, any hints? Thanks
  • dmsk Jul 27, 2008
    Thought I had that problem solved by removing a bra wire from tub drain but it was only temporary. There's a plastic ball in the head of tub drain hose & heavy wire in tub drain. Can't find a schematic to see if they belong??
  • 1,554 Answers
Likely has debris in the filter.
Open the bottom access panel (3 screw on bottom front lip)
open the filter access and be ready for some water spill ,have towels.
clean and check the pump impellers for freedom of movement.
if you still have noise after this you may have to go deeper past the pump and remove the hoses as the debris can be past the pump now.
Or take the machine outside and run water up the pump using a water hose to clear it. be inventive
Posted on Feb 03, 2008
My whirlpool duet washer front loader wont wring out the clothese properly. We have replace the drain pump and cleared all the hoses and filters. It also doesn't seem to go in to real fast spin.
First, make sure your machine is not overloaded. Overloading will not allow the machine to spin out properly. Also, make sure its fairly level. Next, make sure that all the shocks on the drum are properly attached and in working order (after you pull off the access panel, the shocks are readily visible -- there are typically 4 of them, 2 in front, 2 in back). Their heads slip into a slot and then twisting them locks them in. Finally, I would pull of the drain line leading from the drain filter to the tub basin. Once its off, stick your hand up into the basin. All kinds of yuck tends to collect there, semi-obstructing the drain line, which permits more water to remain in the basin, which doesn't allow your machine to spin as quickly as it otherwise would.
Feb 24, 2013 | Whirlpool GHW9100L Front Load Washer
GHW9100LW2 Whirlpool front load washer does not drain or spin
use a wet dry shop vac and remove all the water from the unit then check or remove all the hoses from the drain pump and loock for any obstructions in the pump or hoses.
Sep 08, 2010 | Whirlpool GHW9100L Front Load Washer
Door won't open
If you can drop down drain hose to floor level then drain into bucket this will allow you to open the door . Sounds like coin in the pump /remove the filter and clean check pump blades are free...Good luck
Apr 28, 2010 | Whirlpool GHW9100L Front Load Washer
I am getting a code f-02 on whirlpool duet washer. I run the diag routine and the pump motor runs but begins to make a chattering noise after a few seconds. I checked and have 120v at the motor connector...
The noise is probably debris or objects stuck in the pump filter.
Undo the pump hose and check out.
If the hose is clear, and noise is from the pump, then replace the pump.
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Washer not drain, with clicking noise
If it has a filter, clean it out and start again
Mar 15, 2017 | Whirlpool LSR7333 Top Load Washer
No spin cycle on Whirlpool duet model ghw9100
If front loader, take top off (dissconnect plug) check the beltmay be broken- the motor may be spinning on its own
Also spin the drum round to make it has'nt seized
Jul 22, 2009 | Whirlpool GHW9100L Front Load Washer
Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
Mar 29, 2009 | Whirlpool Washing Machines
Front load washer won't spin
not so much hte switch , but perhaps the hose that attaches teh tub to the switch, usually it rubs a gainstrear of machine and gets a hole in it, look to the hose first
Mar 28, 2009 | Whirlpool GHW9100L Front Load Washer
Whirlpool top load washer LSQ9610LG0 wont spin but makes noise
HI thanks for your question. the part that failed is called the motor coupling. it s located on the motor and the transmission. if you need help to replace come on back. but that's the part you need to change. thanks
Oct 14, 2008 | Whirlpool LSQ9610L Top Load Washer
Water flowing back into washer after wash
There is a back flow valve attached to the outlet port of the drain pump. It is just a small rubber flap. This sometimes comes loose or remains open due to debris and allows the water in the drain hose to flow back into the machine after the drain pump shuts off. It can be checked by removing the drain hose from the pump inside of the machine. You will lose all of the water in your machine (about 1/2 gallon)when you do this so be prepared with a bunch of towels.
Feb 14, 2007 | Whirlpool GHW9100L Front Load Washer
Whirlpool GHW9100L Front Load Washer Logo
207 people viewed this question
Dan Webster
Dan Webster
Sal De
