Question about Nordic Track C900 Pro
Belt making noise - Nordic Track C900 Pro
Tip
Squeaking of belt noise
A use tip for all car owners. no specific model/make.
The Belt of the a/c to the solenoid pulley or the main belts can create a lot of squeaking noise.
Start the car to hear the noise now pour some water into the belt and the noise will subside off . You have the noise confirmed of a belt as sometimes it will trick you to think of water pump bearings, alternator bearings or even engine noises.
Stop the engine and check for play in the belt if so tighten the belt If not use some chalk power or candle wax to be rubbed into the belt that was making the noise - the a/c drive belt - or the main belts..
Now start and check . the nosie would be reduced or gone.
You can have the belts changed sooner or later.
on Aug 31, 2010 | Ford Fusion Cars & Trucks
What making my belts whine its a 1986 pontiac parisienne
High pitched whining noise, usually means the belts need changing. they are slipping a bit, on the pulleys. Good-Day!
Jun 21, 2014 | Cars & Trucks
When do i replace the timing belt on my seat inca van 2004
Those belts are usually supposed to be changed every 60,000 miles. Behind the timing belt cover is your water pump. They can make noise when going out, but usually a timing belt makes no noise, just breaks. If you ever have to change the water pump, it is always suggested to change the timing belt as well. VS. If your timing belt gets stretched, it will make a bit of a noise, but your car will start running poorly at the same time. Hope I was helpful
Jan 08, 2013 | Cars & Trucks
Screeching noise coming from the drive belt is this common
When your drive belt becomes old and stretches so it is no longer tight enough the belt will make a loud squealing noise and will need to be replaced. While the drive belt is off during replacement, you or the mechanic replacing the belt will need to turn each pulley in the system that can be turned by hand to see if any of those are making a metallic noise also. If they make a metallic noise, they are worn out. It is common for a drive belt to wear out and cause this noise.
Jul 25, 2010 | 2001 Mazda 626
Belt makes noise, like it is scrapping something!
Do you have a three year old in the house?? Our ProForm 795 treadmill started making noise when the belt was rotating. Come to find out, he had hidden a plastic clothes hanger inside where the drive roller spins the belt. That was our scaping noise.
Otherwise, is your belt tensioned correctly? If not, it could be tracking to one side or the other.
Nov 17, 2009 | Proform Crosswalk 500 Treadmill
Noise from area of serpentine belt.
The best way I have found to locate a belt noise is to take a can of WD40 and spray it on the belt when the engine is running. (be careful of the fan) If the noise goes away, you know that it is a belt noise and not a bearing. When serpentine belts dry out they make funny noises. Hope this helps, cheers
Apr 08, 2009 | 1993 Volkswagen Passat
2004 alero making loud screaching noise by tire brakes are fine
It's the belts. Quick fix is spray some kind of silicone lubricant on them, like tire shine. You should really replace the belt or belts that are making noise, also check the belts tension. Too loose and they'll make noise
Apr 05, 2009 | 2001 Oldsmobile Alero
Serpintine belt making noise/ or belt tensioner
change serpintine belt I had one that it made noise changed belt noise went away
Mar 11, 2009 | 2003 Toyota Matrix
Accleration problems 1998 ford f150 v6
probably the belt making noise , very common .
WHen a belt gets old it gets dry and cracks start to appear , the non-ribbed side of the belt may get dry & glazed also make noise . common problema are also tensioners that make the belt get out of line with the rest of the pulleys , look carefully because just a little miss-alignment can cause a belt to slip on the smooth side of pulleys and make noise . Misting water onto the belt may also help you determine what is making noise.
Good Luck and Watch your Fingers !!!!
Dec 20, 2008 | 1998 Ford F150 Regular Cab
Nordic Track C900 Pro Logo
62 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
