Question about Swingline 48209 Optima ® 45 Electric Stapler
Optima 45 stapler will not staple - Swingline 48209 Optima ® 45 Electric Stapler
3 Suggested Answers
SOURCE: We have a Swingline 690
I had the same problem with my 690. This is what worked for me.. I simply pulled out the staples from the cartridge a little further than the suggested tear-off point, and the machine was able to start working. Hope this helps!
Posted on May 10, 2011
  • 1583 Answers
SOURCE: how do I make the Optima 20 electic stapler model 48208 work after putting in the staples. I put the paper in as usual and it does not work. I have put the staples in correctly as I normally do, but
Unplug it, take it apart and examine the switch actuator and switch to see why they don't trigger the stapler. There's a good chance you'll find the actuator is broken or jammed by a foreign object, or the switch is worn out. Metal-filled epoxy works well for repairing ABS plastic parts.
Another possibility is a broken power cord. You can test the electrical parts for continuity with an ohmmeter (unplugged, of course!).
Posted on Nov 10, 2011
The auto stapling for my Optima 45 won't staple, can it be fixed? It will manual staple, but not auto. Kinda like the motion sensor went out. Any ideas??
Try to take all the staples out then put a small amount of "Two in one oil" as it is very fine oil. Once you have done this wipe off the excess oil if you have a lot spill out wipe with a rag & use the rag to wipe over the underside of one row of staples.
leave overnight & try to use this again with the slightly oiled staples this should remove any oil left then see if this does the trick. (Note I hope you have the correct staples for the machine of course.) Best Wishes Malcolm
Feb 23, 2015 | Swingline Optima Electric Stapler 45 Sheet...
Swingline Optima 45 Stapler - cannot slide tray back in stapler, no staples jamming
Sometimes the rectangular insert where the staples sit on, gets dislodged. On the underside of channel insert is a spring and when correctly seated is in between the tabs of the bottom piece. If the insert isn't in between the tabs, it sits too high and makes it difficult to open and close the staple tray. The staples will jam.
Jun 13, 2014 | Swingline Optima Electric Stapler 45 Sheet...
Staples will not come out of the stapler.
Did you use Optima brand staples? If not, the stapler will not work correctly. You must use their brand of staples or it will continue jamming, and giving you problems. The staples typically found right next to the Optima staplers in the office supply stores. They come in a rectangular metal box and are labeled Optima staples.
Sep 18, 2013 | Swingline Optima Electric Stapler 45 Sheet...
No staples coming out of machines
The Optima line of staplers do not work without jamming continuously unless you use the Optima brand staples. They can be found in the store next to the Optima staplers in a rectangular silver box, and will solve you problem instantly. There is no other brand of staple that will work in this line (I tried numerous), but once you purchase the Optima staples, problem solved, and you'll love it!
Someone loaded regular staples into our Swingline 45 Optima now it will not work when loaded with the correct staples.
Using the wrong or style ofstaples, overfilling the machine and stapling through too-thick materials can causeOptima to jam. Now follow these steps: 1. Holdthe base down as you lift the top of the Optima stapler to access the stapletray. 2. Removeall the staples from the tray so that you have access to the jammed staple. 3. Turnthe stapler upside down and shake it to clear out staples you can't reach withyour fingers. 4. Gripthe jammed staple with the needle-nose pliers and, while holding the staplersecurely, pull it up. 5. Twistthe staple until it breaks into two pieces if it will not pull straight out.Pull out the two individual pieces. The Optima stapler line bySwingline is designed to be jam-free when Optima premium jam-free staples areused. Using another , style or brand may cause frequent jamming. Hope thiswill help you. Good Luck.
Jul 21, 2011 | Office Equipment & Supplies
I did not receive manual with the Optima 45 electric stapler. How do i get the slid to open to add staples?
The slide tray is on the bottom of the unit.
to open, you just press the very front button on the bottom.
it should open right up.
newimage.aspx?sku=s7048209&h=200&w=200&u=px&d=72&c=&f=jpg&char=9&p=1&o=&imageid=
Hope this helps
Good luck
Please rate FIXYA
May 20, 2011 | Staples Swingline® 36115 Staple Guns Tools...
How do you open the optima powerease stapler to add more staples?
Push the black half-oval button at the hinge to release the staple cartridge. Extend the staple cartridge from front of the stapler, add staples, push back in.
Jun 25, 2010 | Swingline 87850 Optima PowerEase ? Full...
Swingline optima 45 electric stapler cartridge won't reset
call gbc 1-800-541-0094 it has a 5 year warranty. they will send a new one.
Mar 10, 2010 | Office Equipment & Supplies
Swingline 48209 Optima ® 45 Electric Stapler Logo
21 people viewed this question
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Stitch85
Level 1 Expert
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
