Question about Oreck Touch Bagless Upright Vacuum, BU10010
Motor makes noise, reduced suction power - Oreck Touch Bagless Upright Vacuum, BU10010
MOTOR RUNS WITH NO VACUUM PRESSURE
Sounds like the belt should be replaced. It maybe turning the brush, but if you smell burning rubber, its slipping and not turning the brush with as much force as it should. Changed the belt. Check the air suction path. If the suction is reduced, something is blocking it. Check the bag (if it has one) and all filters. If the machine picks up any liquid, it will reduce the air flow through the filters and bag. Change the bag and filters. If this is an upright, you may find caked on dirt under or in the area of the brush.
Nov 28, 2011 | Hoover Vacuums
Since I replaced the bag in my Eureka Rally 2 (this was the first time) the suction has not been working well. Could you please tell me what I could have done incorrectly. Thankyou
The dust bag holder is an important part of this vacuum. Make sure the bag is installed into the holder sliding bag collar into slots to secure.
Make sure the bag is tucked into cleaner. or the bag cover will not latch securely.
Also, the motor and exhaust filters should be cleaned at each bag replacement.
REPLACING THE FILTERS
Filters should be cleaned or replaced when they become visibly soiled or suction power is reduced. Always operate the cleaner with the filters installed to avoid motor damage. The dust bag must be changed and the filters cleaned or replaced if the window of the Clean Filter Indicator changes into red when the cleaner is operating at maximum power and the nozzle is raised from the floor.
Mar 28, 2011 | Eureka Vacuums
My Kenmore bagless intelliclean vacuum is making a loud noise mainly when it is vacuuming on the highest setting (when the light is red). We have taken it apart and cannot find a clog. It has also lost...
This might help, it was posted on a previous problem but is the same issue you are having it seems: "Here is a possible solution. If the vacuum sounds normal when the green light comes on, then the issue is a suction bypass. Kenmore built a suction bypass in to help cool down and protect the motor should someone either never clean the filter, empty the canister or somehow manage to clog the hose. There is a spring holding the bypass closed and is overridden by vacuum suction. I guess the spring becomes weak, allowing high suction to pull it open which in turn reduces suction so it closes again. It can do this several times per second making a loud racket and slightly affecting performance until the sensor goes green, then the vacuum suction is too low to overcome the spring tension thus why it sounds fine then. The trick? The very hard way (what I did) was to open the vacuum, open the casing where the spring is and pull it apart slightly to increase the spring tension. The easy way is to put tape over the hole where the bypass is. The inlet is under the hose track on the back on the right side as you're looking at it. The hole is about the size of a quarter and you'll see fins across the hole. The tape would keep the suction. The motor would still pull back the bypass but since tape is applied, there would be nothing to reduce the suction thus keeping performance and reducing the noise. However, this circumvents the intended design so you do so only at your own risk."
Dec 27, 2010 | Kenmore Progressive Bagless Upright with...
Eureka Rally 2 had great suction the first two times I used it and now faint. No blockage and new bag and clean filter. What coud it be?
Dec 25, 2010 | Eureka Vacuums
My kirby sentra won't **** up anything. I've changed heads and bags to see if something was stuck inside but couldn't find anything.
Your inferance proves that the fault could be with the vacuum pump. Since the rest has been checked and there is a drastic reduction of the suction rate of the pump, I think the motor must be checked. Please remove to see if there is accumulation of dirt in the motor or the rotary vanes. If there is a shift in the position or wearing then the suction can reduce. Make sure that the vanes sweep very closely and there is no gap with the sweep. If the motor bush/bearings are faulty, the suction can be reduced as there will be loss in vacuum produce.
So check this out to confirm the fault.
Aug 20, 2010 | Kirby G6 Bagged Upright Vacuum
My Miele capricorn has started making an odd noise. It seems like something is blocking the engine. I've turned if off and on, and reset it and it still have the odd, almost loud barking noise. The power...
Greetings,
This is a major problem. The Miele vacuums motor should never make a loud noise, period. The way the motor is designed, it's quiet and should be quiet for the life of the motor. There are two motors on your Miele canister. One of the motors controls only the suction of the vacuum, while the other motor controls the power brush. Which one of your motors is making this horrible noise? You can tell this by removing the wands and power brush so that you just have the handle of the hose by itself. Now turn on the vacuum, do you still hear this noise? If yes, then this is a problem with your suction motor, and you need to bring this in to have an authorized Miele repair center take a look at it. The reason I say that is because you have a 7 year warranty on that suction motor, so if something is wrong with that motor, then this will be covered under Miele warranty. If it's the power brush motor that's causing the sound, this probably will not be covered unless the vacuum is under 1 year old. If it is the power brush, please just use the clarificaiton request here on Fixya and let me know, I'd be more then happy to try and walk you through diagnosing the power brush motor with you.
I hope this was helpful to you. If you did find this helpful, please be sure to click the thumbs up icon in the repair. I really appreciate it.
Chris J.
Mar 21, 2010 | Vacuums
I have unscrewed all the screws and can't get bottom off.
Mar 10, 2010 | Kenmore Progressive Bagless Upright with...
Loud noise from Kenmore Progressive Bagless Inteli-Clean
Jul 04, 2009 | Kenmore Progressive Bagless Upright with...
Vacum won't ****
Do you have good suction right out of the canister without the hose attached? If so, AND your hose isn't plugged, you must have a pretty good sized hole somewhere in the hose. If you don't have suction at the canister, pull the filter cover off the top-back of the machine and remove the filter. This is where all of the air that the machine pulls in is exhausted. If something is plugged here, it will greatly reduce your suction. If you still haven't found the problem, you could have a problem with the fan assembly on the motor. But usually this is accompanied by some noise from the motor, but not always. Good Luck!!
Jan 03, 2009 | Electrolux UltraLux 2000 Bagged Canister...
HOOVER FLOOR MATE WILL NOT SUCTION WATER
There are no belts. If it makes the noise with the brush assembly removed the motor drive assembly is bad. It ia a complete assembly that can easily be replace by a repairman or ypouself if you are cleaver with tools. Good luck.
Kirk Thompson
San Juan, PR
Oct 17, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Oreck Touch Bagless Upright Vacuum, BU10010 Logo
48 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
