Question about Texas Instruments TI-Nspire Graphic Calculator
How do i get my ti nspire to convert decimal numbers to scientific notation
  • Texas Instru... Master
  • 7,993 Answers
Choose the scientific display mode.
how do i get my ti nspire to convert decimal numbe - 23459349-wb40nmx23wqw3pcuipuhap2u-5-0.jpg
Posted on Feb 11, 2016
  • 56 Answers
SOURCE: scientific notation
you want to hit mode not menu and then make sure that normal is flashing instead of SCI and hit enter. so just hit mode then enter and it should be normal
Posted on Jan 14, 2008
  • 1572 Answers
SOURCE: how to convert a normal ANSWER to scientific
It's been a while since my TI calculator died, but I think you can just hit EE (may be "exp" on your model) followed by =.
Posted on Aug 28, 2009
  • 7993 Answers
SOURCE: Inputing scientific notation into my calculator
1. To convert a number to scientific equation, use [2nd][Sci]
Exemples 12345 [=] screen shows 12345 Then [2nd][Sci] coverts it to 1.2345 ^04 to the power 4.
2. To enter directly a number in scientific notation (e.g. -1.2345 X10^(-65) a very small number) you use the [EE] key 1.2345[+ /-][EE][+/-]65 shows as -1.2345 -65
1.6X10^(-19) 1.6[EE][+/-]19 shows as 1.6 -19
Hope it helps
Posted on Sep 17, 2009
  • 102366 Answers
SOURCE: Ti-83 plus decimal help?
Press MODE, then navigate down to the display setting and select FIX and whatever number of digits you want to the right of the decimal point.
Posted on Feb 10, 2010
  • 11 Answers
SOURCE: MY TI nspire always rounds
Turn it on, hit MODE then change the FLOAT value from 1 to Float itself. Float allows you to round, and something changed that setting
Posted on Dec 02, 2010
WHAT IS THE E CODE
Does the E code look like 10.8372487489E12?
If so, the calculator is either set to scientific notation mode OR the result was an answer that was too big to display on the calculator, so it converted it to scientific notation. To convert from scientific notation back to regular notation, move the decimal to the right by the number of times after the E. In this case, the number after the E is 12, so we have to move the decimal to the right 12 times. In this case, I get the final answer as 10 837 248 748 900.
Good luck.
Any questions, let me know.
Paul
Jan 27, 2014 | Casio DR-250HD Calculator
How to convert a decimal answer into scientific notation
In main screen press 4:Settings then 2: Document Settings. On the third line Exponential Format, set Scientific. Validate by pressing OK..
See the screen capture below.
Dec 05, 2013 | Texas Instruments TI-Nspire Graphic...
How do i convert a decimal answer into scientific notation
Factorial key
14! is an eleven-digit number. The only way your ten-digit calculator can display that number is to convert it to scientific notation. A twelve-digit calculator such as a TI-89 can display that number, but 23! is a 23-digit number and even a TI-89 cannot display that number.
Oct 25, 2013 | Texas Instruments BA-II Plus Pro...
How do I set up my TI-nspire to show a large answer in scientific notation?
In OS 3.x Press 5:Settings>2;Settings>1:General.
In the screen that opens, use TAB repeatedly until you
reach the line : Calcul Mode. Use right arrow to open
that menu. Select the option APPROXIMATE and press
ENTER. Use the TAB to move the highlight on the OK
button and Press ENTER/OK to save the changes.
All large values will be displayed in Scientific Notation.
Aug 30, 2011 | Texas Instruments TI-Nspire Graphic...
How do I get a large answer converted to scientific notation, such as 3^70?
You can convert a would be exact result into its decimal approximation by pressing [CTRL][ENTER] instead of the [ENTER] button.
Jul 11, 2011 | Texas Instruments TI-Nspire Graphic...
I am using the TI Nspire Cas Graphics Calculator. I have calculated a linear regression that has been copied to f1. When I go to graph the function it is displayed in f1 as 100.x+2000. when the function...
Scientific mode is a display mode. It concerns the display of results. If the number are too small or too large they will be displayed in Scientific mode, because the screen does not have an unlimited number of digit positions.
Regarding the dots. A number followed by a radix mark (decimal mark) is considered to be a floating number, while the same number without a decimal mark is considered an integer (whole number).
The CAS is able to do symbolic and exact calculations, so that distinction between floting and integer numbers is important. Sometimes, to force a result to be displayed in its decimal representation all it takes is to append a decimal mark at the end of an integer.
Hope it answers your queation.
Apr 23, 2011 | Texas Instruments TI-Nspire Graphic...
I have a TI30XA calculator and want to know how to multiply numbers using scientific notation. I have learned how to enter a number (e.g., 1.5 x 10 -6), but when I try to multiply it by something (e.g.,...
Press 2nd [SCI] to switch the calculator to display all results in scientific notation. The results are the same whether you do it in scientific notation or not, it's just how the number is displayed.
Feb 13, 2011 | Texas Instruments TI-30XA Calculator
After working a simple problem adding numbers in scientific notation, I want to convert the answer, a decimal, to scientific notation
For converting answer in to scientific notation do the following steps.
1.click shift key after that press mode key next to on button.
2.From the menu that is displayed in the screen press 7 for displaying answer in scientific notation.
Thank you.
Jun 10, 2010 | Casio FX-115ES Scientific Calculator
Need help on scientific notation using a texas instrumants ti-83
http://www.ehow.com/how_4667397_enter-scientific-notation-ti-calculator.html
still have problem's mail me at thushanth@hotmail.com
Nov 11, 2009 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-Nspire Graphic Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
