Question about Hotpoint WMA58 Front Load Washer
Change the motor brushes - Hotpoint WMA58 Front Load Washer
Brushes do not work
if the old brushes does not work (there is an activated autostop from inside the brush to protect the armature collectors to get the spring after the brush between it . 1 look at the color of the fieldcoil of the motor and also the commutator (all collectors of the armature)
in 60% of cases with motors between 1200 and 1800 watt in many cases it is not worth the brush exchange. field coil is dark colored then the bearings are dry
Often the engines in a number of operating hours built and only has one collector to stabbing something and within a week you lose your brushes again, have you a motor in a Vacuum below 1000w then is the change to make 1 succesfully change of the brushes much higher . in most cases there are several equivalent motors for vaccuums The brand fixapart is one of the very good motors to use for equivalent . its good in Festool Protool Starmix and many more
Here an example
Fixapart Stofzuiger motor AB86 1000 W Miele Fixapart Vacuum cleaner motor AB86 1000 Miele W7 18501
Nov 09, 2015 | Vacuums
Bissell Proheat 1383 removing brush motor to replace it with a new one.
May be a burned out collector of the armaturebetween the brush holder and armature ballbearings are maybe poor change the motor , and replace allways 2 brushes if its possible because 1 fieldcoil stator of the motor should have a problem if 1 brush is shorter than the other brush there is a disbalans with 1 long and a short brush , in the early years 50 60 or the more expensive vaccuums like Kirby 600 W motors
it is useful to change brushes buit in 60% of the cases you lost the brushes again in 1 month .
Oct 29, 2015 | Vacuums
Where are the brushes located on an asko washing machine ??? I'm fairly handy, can I replace myself ???
hi, I used to fix asko's when I was as work and found the motor brushes really easy to fix on the older machines. I found it best to drop the motor down and change the brushes at the back of the motor on the bench. hope this helps. remember to change both brushes though.
Mar 25, 2013 | Asko Washing Machines
How to change the brushes on the motor in a flymo 340 compact
There are no brushes available for this model, if the brushes are worn that bad the motor will be just about worn out as well, new motors are available.
Jul 21, 2012 | Electric Garden
How to change brushes in dewalt 716 miter saw
look on the motor body there may be two screws over the brushes undo the screws and the brushes are under them if not remove the motor end cap to change the brushes
Mar 25, 2010 | Dewalt Saws
HI; How do i change the brushes in an electric
Motors with carbon brush can be detected due to the two brush access at two opposite sides. Open this up,
and you can already change the carbon brush.
However, if your motor doesn't brush access, the probability is your motor is a capacitor motor. Replacing
the capacitors will restore your motor proper speed.
Oct 27, 2009 | Coleman Powermate 4 Gallon Air Compressor
Hotpoint BHWM129. Cannot change brushes.
there are no brushes in that kind of motor
Aug 16, 2009 | Washing Machines
How do i change the brushes on my wma35 hotpoint washing machine so that it'll spin?
unplug first then remove top cover motor should be there remove motor 2 bolts then u can change brushes
Jun 30, 2009 | Hotpoint WMA30 Front Load Washer
Changing bushes on bosch classixx1200
To change brushes in Bosch motor.
Remove rear panel of washer, undo 2 screws that secure motor at front end, remove motor plug, lever motor back with a screwdriver or similar, and remove motor retaining a hold on it,\ so as not to drop it .
Replace brushes fitted at rear end of notor.
Refit motor and belt.
Plz rate my solution.
Thanks.
Jan 08, 2009 | Bosch WFK 2401
Changing the brushes when the motor is off
Remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if they are any shorter than 1 cm replace brushes.
Nov 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Hotpoint WMA58 Front Load Washer Logo
14 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
