Question about Brother MFC-8440 All-In-One Laser Printer
Error 7A brother mfc-7360n - Brother MFC-8440 All-In-One Laser Printer
4 Suggested Answers
  • 1218 Answers
SOURCE: ERROR 7A
For the error code "7a" to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition.
If the error code is caused due to malfunctioning of the main motor, then you need to check the whole setup by connecting it with another motor.
In this case, make sure that there is no mechanical load present on the main board.
While fixing this error code, you will notice that the motor runs slowly initially and then picks up the speed later.
http://www.fixya.com/support/t5660619-7a_error
Posted on Sep 22, 2010
  • 1218 Answers
SOURCE: Brother MFC-8820D Machine Error A
uxair shah
  • 812 Answers
SOURCE: Brother MFC-8440 Machine Error Code 7A - tried to
Hello thanks for using FixYa
Error code 7A occurs in different forms and they are linked directly to errors caused due to calculations as detected by GPU, however, it is still doubtful what exactly cause these GPU errors in hardware and the errors in WU. Keep in mind that this error code could also suggest that the main PCB is broken.
For the error code 7A to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition. If the error code is caused due to malfunctioning of the main motor, then you need to check the whole setup by connecting it with another motor. In this case, make sure that there is no mechanical load present on the main board. While fixing this error code, you will notice that the motor runs slowly initially and then picks up the speed later.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Posted on Feb 14, 2011
How to repair head laser brother 7360
you do not repair them-- just replace
you can reset the error code if needed
Feb 16, 2015 | Brother MFC 7360N - Multifunction fax /...
Mfc 7360 unable to print 7a
Error code 7A
A synchronized signal of the main motor cannot be detected.
Turn the power off and then back on again.
1 Flat cable connection failure of main motor
Check the flat cable connection of the main
motor and reconnect them.
2 Main motor failure Replace the main motor.
3 Low voltage power supply PCB failure
Replace the low voltage power supply PCB ASSY.
4 Main PCB failure Replace the main PCB ASSY.
Jan 14, 2015 | Brother MFC 7360N - Multifunction fax /...
My MFC-7360 says NO PAPER, but there is paper.
Most probabply will also say Please put paper in the MP tray ?
Sep 23, 2014 | Brother MFC 7360N - Multifunction fax /...
Why does my Brother MFC-7360n Does Not Pick up paper?
Leave the machine and attend to it at a later time repeating all you initially did.
Aug 28, 2014 | Brother MFC 7360N - Multifunction fax /...
Brother manual feed insert paper
I am a Brother employee working for the software technical support department.
We have a solution for your printing issue posted on our solution site.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=200000016347
Description of Problem 100000012720
When I try to print from Microsoft Word or another program, I receive a message stating: Manual Feed, No Paper, or Load Paper XX. What can I do?
Brother Software Technical Support
Jun 29, 2014 | Brother MFC 7360N - Multifunction fax /...
Outlook won't print to Brother MFC7360N AllInOne Laser Printer
Must be set on Brother MFC-7360N series. Set on PC-FAX will not print with all programs, as it is printing with an output through the fax. Go to control panel, select devices, printers to change to pc-7360 series. This should print on all programs.
Mar 17, 2014 | Brother HL-5240 Laser Printer
Machine error 7A
Brother printer error code 7a occurs when the main motor fails to synchronize properly with the reference clock. for more information and help........
Mar 04, 2010 | Brother MFC-8440 All-In-One Laser Printer
When i turn on my brother mfc 8440 it is saying
Oct 01, 2009 | Brother MFC-8440 All-In-One Laser Printer
ERROR 7A
May 07, 2008 | Brother MFC 8820D All-In-One Laser Printer
Brother MFC-8440 All-In-One Laser Printer Logo
56 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
