Question about Skil Saws
How do i change the blade on a skil 4240 jigsaw
I have a 3.3 4240 skil jigsaw and I need to change the blade. I can't figure out how to lock the blade in correctly
5 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: need to change the blade
Page 7 of the link below will tell you how to change the blade.
http://dl.owneriq.net/0/0f6b7805-7308-4ff5-98c5-ccfa42203189.pdf
Posted on Aug 28, 2011
  • 14 Answers
SOURCE: change blade
depending on how new the saw is there are only 2 ways to change out the blade. the older saws have a allen head screw that you must loosen or remove to take te blade off. this screw is located on the shaft at the top of the blade. shed some light on it and look for a slot above the guide.the screw will be either on the right side or the left side. Newer models will have a quick release on one side or the other,it will look like a little lever,you just flip it out with your thumb the old blade drops out then you install the new blade flip it back and your back in business.
Posted on Jan 18, 2009
  • 211 Answers
SOURCE: cant change a blade on 500watt pendulum jigsaw fmtc500js
Hi
There is a click mechanism to replace the blade at the top of the blade.
best regards savumihai71
Posted on Feb 12, 2009
jyackle5
  • 8197 Answers
SOURCE: don't know how to change
Top of page 7 on link below will tell you how to put the blade on.
http://dl.owneriq.net/2/2013c3c3-d273-ce04-8910-1c3687c84980.pdf
Posted on Apr 17, 2011
How do I change the blade in a Skil Jigsaw 4390
To remove blade, lift tool-less blade change cover up with index finger and thumb and
remove blade.
For use with both T or U shank jigsaw blades
Sep 04, 2017 | Skil Saws
The blade broke off inside and I can't get it out. Please help me figure how to get it out.
moden jigsaw blades are held in with a taper chuck system
disconnect the unit from the wall socket
push the spindle all the way in
now press on either side of the blade holder and that should move down releasing the blade
now while holding that section down turn the unit right side up and the broken bit should just fall out
Oct 13, 2015 | Skil 4495-01 6 Amp Orbital Jigsaw
How do you change a blade on a Skil 4280 jig saw?
It is REALLY easy, when you know how. There is a black piece, the larger one, near blade insert...lift it and VOILA, you can insert or remove blade easily. I lost manual and spent forever trying to put blade in. Hope this helps.
Sep 22, 2013 | Skil 4280-01 4280 Variable Speed Jigsaw...
Oil leak from my Skil Jigsaw and it keeps Jamming when I cut wood
get a nail file and sharpen the blade till you can see your face in it
May 07, 2013 | Skil Top Handle Jig Saws Variable Speed...
I have an old bosch 158IVS uh, what do you call a little reciprocating saw? jigsaw? anyways i can't for the life of me figure out how to change the blade. i've undone every screw. opened up the motor...
well the sawzaw will be drastically different from the jigsaw, but the jigsaw will have either a round twist lock that needs to be turned a little to remove the blade, or two screws that hold a flat plate that clamp the blade. and as for the sawzaw, it will be a twist lock, or a latch lock, the latch lock will look like a lever that needs lifted to remove the blade, and the twist lock is the same as the jigsaw.
Dec 30, 2010 | Saws
I have a skil jigsaw model #4380 and 3.7 amps.trying to change blade.any idea?
if it's the kind I have 4380 3.7 amp behind the safety bar (kind of looks like a v ) there's a black boot behind it just lift that boot and old blade will drop out then lift the boot again and install new blade pull on blade to make sure it's locked in. that's all there is to it
Dec 12, 2010 | Skil Saws
I do not know how to install blade and have no manual
Most of the skil jigsaws have a plastic piece with a spring and catch behind it. Just push your blade into the tool and it should lock. When you want to remove it you need to press the plastic lock collar up and it will release the blade. Some of the earlier models weren't as easy to set the blade in and you have to press the lock collar up insert the blade and let the collar down around the blade to lock it.
Sep 09, 2009 | Skil Saws
Saws Logo
341 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
