Question about Xerox FAXCENTRE PRO 735 745 DRUM 113R298
Xerox pro 745 drum count reset - Xerox FAXCENTRE PRO 735 745 DRUM 113R298
  • 239 Answers
SOURCE: B&W Xerox copier XC23 has code J7 and will not print
This machine has a battery on the main board. The battery might failed, they will last for about 7 years. When the battery fails then so will the NVM.
Some NVM information can get garbled. This problem may be associated with it.
Some of the values can be checked and changed in diagnostics, most cannot.
If you replace the drum and the machine will not reset, replacing the main board may fix the problem. Make sure the connector on the back of the machine does connect to the copy cartridge.
Sometimes the cartridge you recieve is for a different model. (5322 family)
The socets may not match.
I really do not like to see you spend your money on drums if it does not fix the problem on the machine. Hold on to the drum units until you really find the source of the problem.
Good luck.
Posted on Oct 18, 2009
  • 2072 Answers
SOURCE: Xerox DC50 error 9-378 Drum cartridge count
You can order a crum chip or replace the cartridge.
Google a business called The Parts Drop.
Call and ask for Britt. I am sure he will have the crum chip to replace and reset that code fairly cheeply.
Posted on Aug 09, 2010
  • 239 Answers
SOURCE: i need to reset the drum count on Workcentre Pro
I understand you have a situation to reset the drum.
I am still researching this, I forgot the process, sorry.
But If i remember, this might work.
Press and hold these buttons. Menu, 1,3
Power up the machine while holding them.
If you get a messge that says enter code.
It is either 80, 81, or 82.
You can also try to reset the mother board which will defalt all settings on the machine to factory settings. Menu, 1,3, *.
Hold buttons and power up machine, hold buttons for about 15 seconds.
If the star does not work, try the "#" instead.
Your information needs to be reentered in the mahine via the menu button, speed dials, trays sizes you are using.
You may want to print out a reports configuration first before preforming these funtions.
This machine can print out a table road map to show what available menues can be configured.
If this does not work. Then do not try to enter anything else.
It has been so long, I would have to be in front of this machine.
If you are not sure what you are doing, place a service call on this machine and let the service representative handle it for you.
If your machine has been operating pretty good, and you wish to keep it longer, pay the fee and you will have a much better machine to use.
This is a good machine if you wish to keep it longer.
Good luck.
Posted on Aug 12, 2010
  • 2072 Answers
SOURCE: need to reset replace drum message on Xerox
You can replace the chip on the drum unit. Or the drum unir itself.
Google a business called " the parts drop". They will have both the chip and or the drum cartridge. It is not resettable with a diagnostic code.
Posted on Aug 19, 2010
sanimd85
SOURCE: reseting xerox drum chip xerox 5834/vivace 340
canon pixma ip3680 absorber is full
Posted on Apr 07, 2013
How to reset xerox m118 drum counter
Hi Laurynas Straksas,
What very frequently happens with those machines is this. On the drum cartridge, there is a green cover in front. Behind that cover there is a series of gears, one has a flag like tab sticking out. That tab is the drum reset, what it does is makes one swipe past the drum reset switch when you install it and that resets the drum life by swiping a switch one time. That flag has fallen and did not swipe your switch, you can do one of 2 things. You can have whoever you purchased the drum from replace the cartridge, or you can pop off that green cover and manipulate that flag to an Up and to the up position and replace the cover and install the drum in the machine, once the machine runs it will swipe the switch and reset the drum count, turning off the light and allowing your machine to run. Once you take the green cover off you will easily see what I am talking about, Flag will be down, work it until you get it in the up position. That will do it.
Aug 26, 2014 | Xerox WorkCentre M118 Black and White...
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
DRUM LIFE WARNING WON'T GO AWAY AFTER REPLACING DRUM.
find the box that the drum came in. There should be directions to reset the drum light enclosed. Or go to www.xerox.com , then look under support and drivers. Good luck !
Jan 11, 2011 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Need to reset replace drum message on Xerox Workcentre Pro 416
Aug 19, 2010 | Xerox WorkCentre Pro 416DC Copier
Xerox DC50 error 9-378 Drum cartridge count expired. How do i reset this error.
Aug 09, 2010 | Xerox Office Equipment & Supplies
Xerox 657 drum reset instructions
need to replace 1/16 A pick-tale(brown color with strips on it) fuse on blank lamp assembly in drum unit
May 06, 2010 | Xerox WorkCentre Pro 635 Laser Printer
Prize
Have a Xerox DC50 with error 9-378 drum cartridge count expired message.
How do i reset that. Please somebody
Mar 21, 2010 | Xerox DocuColor 12 Printer
I have a Xerox XD125F Workcentre. The J2 toner
1. turn off XD125f
2. Turn on
3. within 4 seconds press, clear, auto, clear, auto. LED Should go blank,
if not try again
4. use copy quantity keys to enter 24, then push start
5. Again use copy quantity keys to enter 7, then push start
6. turn off
when you restart the cartridge count will be set to zero
I have done this twice and never replaced the drum cartridge.
Jul 24, 2009 | Xerox Office Equipment & Supplies
There is a chip on the back of the drum unit that keeps count. It cannot be reset. You may try to find a replacement chip on the internet. I would recomment the rechargerstore.com They have good products. I do not know how long your drum will last, you may end up having to replace it for copy quality problems at some point.
Feb 28, 2009 | Xerox Office Equipment & Supplies
Xerox Docuprint C1618 Colour Laser
Are you certain you have typed the right model number? I can't find a Xerox 1618 anywhere. I would love to help.
Mar 24, 2008 | Office Equipment & Supplies
Xerox FAXCENTRE PRO 735 745 DRUM 113R298 Logo
23 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
