Question about Compaq Presario sr1111nx 2.53GHz Celeron Computer (SR1111NXRB) PC Desktop
Computer after dusting out the inside of my computer I put it back together & I turned the computer on & the screen was black & read at the top (insert disk & press Enter) . what can I do to fix the problem?
Turn on computer and nothing have check out poewer supply it good montior good so what could this be?
Posted on Jul 19, 2008
  • 363 Answers
Check that the hard drive connectors have not become loose on the board or the drive. Also check you havent lost a little black jumper off the back of the drive.
Posted on Oct 27, 2007
My computer is beeping when I turn it on. It beeps two long and then two short followed by two more long. What could be my problem?
You need to check the RAM[s] on your desktop.Open the top cover and inside on the motherboard are some long [maybe 2 or more] slots with something like flat chips attached.Remove them by pressing the two holders on both ends down.Wipe the slots off dust and re-insert the RAM[s] making sure they properly and firmly sit on the slots.Also check the hard disks power supply and make sure its properly fixed.Probably disconnect the hard disks power supply and reconnect again.Put the cover back and start the machine.
Hope this helps.Thanks!
Dec 22, 2011 | Dell Computers & Internet
I do not know what to do says Please insert PlayStation or PlayStation 2 format disc. Please read it if you write to me with otgovor.A'm desperate.
if the disk is a Blueback, most modern PS2 consoles won't touch it. bluebacked disks still have their data stored in CD format rather than in a Data DVD
to play a Blueback
1. turn on the unit without a disk in
2. press Triangle on "browser"
3. scroll up to the top item and press triangle again
4. turn "Diagnostic Mode" ON
5. back out with circle, and start the browser
6. put your disk in with the browser on. is should read the disk
some disks will still cause the red screen (like cheat devices) occasionally
Aug 28, 2011 | Bandai Digital Entertainment One Piece:...
Hp pavilion a1210n disk boot failure, insert system disk and press enter. how do you boot in save mode
Turn your computer off, turn it back on, as soon as you do that, start pressing F8 repeatedly until you get to a screen where you can access safe mode. If it's saying disk boot failure, you most likely have a dying/dead hard drive.
Jul 24, 2011 | HP Computers & Internet
Everything has been working okay on this compaq until this morning. Upon powering up a Red and White HP screen pops up that turns into a black screen which reads quite simply: "Disk Boot...
The computer could not read your copy of Windows from your disk-drive.
* there is no electrical power getting to the disk-drive (check the power cable)
* the "data" cable between the motherboard and the disk-drive is faulty or not-connected (check it)
* the power-supply in your computer is not supplying power to the disk-drive (try different power-supply)
* the disk-drive itself has "failed" (maybe, the motor that spins the disk-drive has failed)
Take your computer to a professional technician for trouble-shooting.
Jun 12, 2011 | Compaq Presario S6300NX PC Desktop
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
When my daughter turns on her system it goes to a "Browser / System Configuration" screen and we don't know what to do?
Is it stuck at this screen? If so, try shutting down the PS2, then remove the power cord for 5 minutes. Plug the power cord back in and turn the system on.
Also, if the PS2 is having trouble reading the disk it will do this. You can try another disk because maybe the one you are using is scratched up. The system may have to much dust and dirt inside causing disk read problems. Try a can of compressed air and see if you can blow some of the dust out from inside the disk drive!
May 07, 2011 | Sony PlayStation 2 (PS2) Console
My computer, a lenovo y510 laptop malfunctioned. After inserting the recovery, and attempting to boot from the disk, the screen simply goes blank instead of opening the normal vista install center.
Hi lightning_ha,
Based on your situation, I suggest trying the following steps:
1. Turn on the system then insert the recovery disk inside the ODD.
2. Now turn off the computer while recovery disk is inside.
3. Turn on the computer, the moment you press the power button, immediately tap the F12 key and press it continuously.
4. Now you have the boot option. Select CD/DVD/ODD by pressing enter then continuously tap it until you see the Windows is loading a file.
5. Wait until it goes 100%.
6. Now it will ask you on what partition you will put the operating system. Just select the partition that has a large capacity or size.
7. Just wait until it completes the whole installation.
8. Restart the computer.
Hope it helps,
Thank you for using FixYa.
Oct 06, 2010 | Lenovo IdeaPad Y510 Notebook
Black screen saying no signal
turn off the computer and get a can of compressed air blow out all the dust and make sure everything is tight put back together and see iff it works. geek squad charges 99.99 to do this in store.
Jan 28, 2009 | AOC LM729 17" LCD Monitor
"Disc Boot Failure" upon powering up the compaq
your harddisk is not detected.
open your cpu case.
then reattch the power code and datacode to hard disk.
Nov 03, 2008 | Compaq Presario S6300NX PC Desktop
2 disks stuck in ps3
You are A ******, try beating yourself with a hammer
Aug 22, 2008 | Sony Playstation 3 (PS3) Console
Open Questions:
See all Compaq Presario sr1111nx 2.53GHz Celeron Computer Questions
Compaq Presario sr1111nx 2.53GHz Celeron Computer (SR1111NXRB) PC Desktop Logo
43 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
