Question about GE JTP45 Electric Double Oven
All lights lit on control panel
Intermittently show all lights lit, none lit, time shown in dim numbers or time and fan symbols in dim numbers
I have a Bosch oven with the "key" sign constantly lit and the oven won't function at all. Re set it at wall etc.
the key sign shows that the child lock is engaged. to unlock, usually you push and hold the lock button for a few seconds. the correct button is usually a dual function and so marked. if you need more help, go to manualsonline.com and look up your model number for your manual. good luck
Dec 27, 2015 | Bosch Ovens
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
My Kenmore Electric Range model 790.9661 seems to have a control board problem. Before replacing the $200 part, just wanted to make sure it was the problem. The clock works, but the oven temperature side...
From your description it sounds that the board is the problem. I found the control panel you need for a lot less than $200 though.
I found one online from a store that I have bought from many times. Part and shipping is about $153. They sell brand name stuff too and they have great service. I hope that this helped you.
Control Panel
Good Luck from a bored repair man!
Joey
http://www.pricedrightparts.com/products/Frigidaire-Control-Panel-316402715.html
Jun 11, 2011 | Kenmore Ovens
My oven has power but it does not work. When I
Your control panel is faulty and will need to be replaced. You can get another one at repairclinic.com or partselect.com
Jan 13, 2010 | GE JKP15 Electric Single Oven
The control panel light is very dim. It is hard
we had the same problem....my husband removed the panel and I clean the inside glass panel & it resolved the problem. It is a convection oven and steam comes out just below the clock area which I believe causes the problem.
Jul 12, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Lighted clock and controls intermittently not working. Oven still heats
HI thanks for the question. its a common problem with the clocks. first it goes a little dimmer. then a little more till it goes so dim you cant even see the temperature that you have in the oven. the clock has to be replaced. or. buy a cheap oven thermometer. and hang on the middle rack, and adjust the temp setting to match the oven temp . save a lot of money this way. thanks. please rate my answer. thanks
Oct 09, 2008 | Jenn-Air Ovens
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
DIPLOMAT OVEN OPERATING INSTRUCTIONS
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
Display Panel Light
There is a replacement display assembly, i think its around $150-$200. Its pretty easy to change if you are at all mechanically inclined. Good Luck!
Oct 29, 2006 | Jenn-Air W30400P Stainless Steel Electric...
GE JTP45 Electric Double Oven Logo
18 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
