Question about New World 70TC Electric Single Oven
How to swiutch off air - New World 70TC Electric Single Oven
The fan in main oven only blow out cold air
The fan does not produce hot air. It just circulates it. The thermostat turns on the heating element and the fan moves the hot air around. Unless you have an odd working machine. Baked bread for years an it only moves air for even heat.
Jan 31, 2015 | Ovens
Jenn-Air W241-C wall oven
Unless you can find one in a used oven, I don't know. Jenn air website says they are discontinued and offers no substitute part.
Jul 17, 2014 | Jenn-Air Ovens
I need the Start Amprege for a Jenn Aire #WW30430P
phone jen air tech support daytime Eastern Standard time:
1-800-JENN-AIR (536-6247)
Dec 20, 2013 | Jenn-Air WW30430P Stainless Steel Electric...
I have a problem with a Baxter OV300g Oven. The Automatic Ignition System keeps Flashing 1-flash Air flow problem, can you help me with this. Thank you.
Check to see if your draft inducer (exhaust fan) is running, if it is then you could have a dirty/bad air switch, the component with the small black hose running to it and the two wires on the face. To check an air switch using a multi-meter set it to 40 VAC and place a lead on each terminal, if you are getting a voltage reading over 1 volt, replace the air switch, if you have zero volts, the air switch is closed and working. Aside from a bad exhaust motor or air switch there could be many things causing that error.
Jul 30, 2011 | Baxter OV300E Stainless Steel Electric...
Convection oven blowing cold air
If your fan is blowing cold air, it's the air inside the oven that circulates. It has nothing to do with the fan. Convection circulates the existing air in the oven. Sounds like you might deselect the convection setting if this continues to happen. We have parts, so please let us know if we can help any further. :>)
Aug 24, 2009 | Ovens
Jenn Air JMW8530CAB time/temperature light don't work
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 18, 2008 | Jenn-Air JMW8530C Electric Double Oven
Jenn air combo wall oven/microwave
Bend over, pull down pants. They Got you....
Jan 01, 2008 | Jenn-Air JJW8230D Electric Double Oven
New World 70TC Electric Single Oven Logo
Top New World Ovens Experts
Paul Carew
Oloyede Monsuru
Are you a New World Oven Expert? Answer questions, earn points and help others
