Question about Vizio VHT510 Theater System
Sound quit working
Sound started getting static, and then quit working altogether. Tried unpluging, and other input, but still no luck. Lights still work, and changing input appears to work. Just no sound.
My magnavox crt is about 10+, worked great.Last night,the screen remained black, and sound was static. Tried unplugging, held the power button, ran a new cable line from working tv.No lights in back.
I hope I can help. I would first try another outlet.
  1. another power outlet
  2. check the cable from the TV to the wall or cable box
  3. Check the TV Input channel, make sure you go through each source input to verify which tv/video input is the correct one.
Jul 28, 2016 | Televison & Video
Mazda3
Replace it . I have found to repair it costs more than a replacement.
Apr 22, 2014 | 2006 Mazda 3 1.6
Picture is frozen onto the screen. Tried powering off tv and cable box that did not work. Next unplugged TV and that did not work
Sounds like a burn in, this is common when some still image is left on the tv screen for sometime, the only hope is to get to a white screen or static screen and let set for awhile, like the old days when you didn't have cable or any input and the tv just frowns.
Jan 23, 2011 | Vizio VW32L 32 in. LCD HDTV
My Sharp LED LC-52LE820UN HDMI ports are not working. I tried powering off the cable box, TV and PS3. Unplugged the HDMI cables, then booted all three devices. Afterward I power everything off, plugged...
This is a known problem on Sharp Aquos TV's. The HDMI inputs connect to their own sub-processor board right at the ports. This board is VERY prone to failure with just the SLIGHTEST static electricity problem - it usually starts acting up after a storm, will only go out for a couple hours, you turn the TV off, come back the next morning, and it works again. You think "OK, random problem, whatever". Then it does it again a couple months later, then it starts happening more and more until the board completely stops working altogether. The board is about $150 and is easy to replace yourself - if you've ever replaced a card in your PC computer, it's not much more difficult, just more screws. These tend to go out right at the 11-13 month point, which is awesome as far as a warranty is concerned. In short, get the extended warranty or buy with American Express which automatically doubles manufacturer's warranties with ANY electronics purchase, then replace it before the warranty is up. Good luck. (and P.S., Sharp will argue that this isn't a known problem but just do a Google search, it'll pop up all over the place).
Dec 17, 2010 | Televison & Video
When I plug in my speakers, they make a constant static sound. It can become quite loud at times and I've found that turning the input chord around can sometimes work, or unplugging the charger for my...
if your speakers are near to some electronic devices you'll get theses static noises try to keep them away from electronic devices which solves it very easily..
Sep 30, 2010 | Audio Players & Recorders
I have a JVC Model # HD-56G787 and while i was hooking up Dish box the screen went black. Now when anything is plugged into the inputs (correctly) the screen is black. I have tried using Other Cable,...
Static discharge can destroy electronic components. Since your TV became defective when you were connecting an external device, it is very likely that a static discharge killed the first active component inside. It is a good idea to have a tech check the input select IC is functional or not.
Nov 17, 2009 | JVC HD-56G787 Television
Turn signals work intermittantly
multifunction switch? I think so.
Jan 29, 2009 | 1999 Ford Explorer
HP All in One printer F4280 shows an Error code ''E''
The lights flash in special sequences to inform you about various error conditions. See page 136 of the user manual which you can get here: http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Nov 11, 2008 | HP DeskJet F4280 All In One Printer InkJet
Sound is just static
Don't understand why, perhaps rca contracted microsoft for their programming, but when I unplugged the TV and it rebooted, everything is fine. I still am concerned about the warning on the back.
Apr 20, 2008 | RCA P52930BL 52" Rear Projection...
Occassional sound from surround right channel
If under warrenty please return. This seems to be a internal problem with this device
Feb 11, 2008 | Harman Kardon AVR 630 Receiver
Vizio VHT510 Theater System Logo
18 people viewed this question
Top Vizio Audio Players & Recorders Experts
Matthew Spark
Matthew Spark
Are you a Vizio Audio Player and Recorder Expert? Answer questions, earn points and help others
