Question about Mitsubishi VS-6043 60" Rear Projection Television
Mitsubishi 6043 tv does not stay on - Mitsubishi VS-6043 60" Rear Projection Television
5 Suggested Answers
  • 3 Answers
SOURCE: no picture
Sound like you lost Vertical Deflection.  Youshould not have a line across the screen because this could destroy the threeCRT Red, Green, and Blue (Picture tubes) if left on to long. There is a protection circuit built in to protect your CRT’s.    Check on the PCB-SIGNALboard (Tuner located on this board) transistors Q-206 Collector should be around 1 Volt Base and Emitter 0V. If the voltage atthis point is greater then 5 Volts the Vertical output IC-401 (Mounted on heat sink 7 pin inline IC) is bad, Part # LA7845.  Pin Voltages should be PIN 1= 0V, 2= 34V, 3= 32V, 4= 3V, 5= 3V, 6= 33v, 7= -6V.  Data sheet located at http://pdf1.alldatasheet.com/datasheet-pdf/view/40357/SANYO/LA7845.html
Posted on Aug 16, 2008
asnowman
  • 788 Answers
SOURCE: Mitsubishi VS 6043 Convergence Help
You can also access the convergence menu from the front panel, but it can be a pain to do so. If the convergence will not adjust, please respond to this post and I can help you further.
If you want a new remote you may want to check out www.remotes.com and see if they have the remote or a similar remote for you.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Sep 17, 2009
SOURCE: I have sound, but no picture on my Mitsubishi
Posted on Oct 02, 2009
SOURCE: 60" MITSUBISHI VS-6043 lenticular screen damaged. cant find one
i have the same tv if want this send a email
Posted on Oct 17, 2009
Sep 17, 2009 | Mitsubishi VS-6043 60" Rear Projection...
How to adjust aspect ratio on Mitsubishi VS-6043 TV?
I have the same problem and the only thing I could do was to change the name of the input on your tv to pc on the menu screen and it should set it to 1080p reduced this will fit the whole picture and set your screen res on your computer to 1920x1080
hope this helps
Aug 01, 2009 | Mitsubishi VS-6043 60" Rear Projection...
6043 6061 parts interchange
Well, you can use most of the parts, except that the shape of the boards are different, so you cant exchange the entire board as such.
May 20, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Mitsubishi VS 6043
That's pretty classic, but for other viewers out there, the thing is nailed together, and most of it is basically one entire unit without removable parts except basically the front panel, the screens, and the internals. So please, if you cannot fit it, sell it and get one that does, don't waste a good TV.
May 05, 2008 | Mitsubishi VS-6043 60" Rear Projection...
TV-Bowing
can you post a pic of your screen so i can properly diagnose the problem as it could be either a pincushion or convergence problem. A picture would clarify it for me.
Apr 16, 2008 | Mitsubishi VS-6043 60" Rear Projection...
60'' 11 year old Mitsubishi Projection TV
HELLO THERE WE ARE HAVING THE EXACT SAME PROBLEM. TURNS OUT THAT IT IS THE RELAY SWITCH mY TV IS ALSO 11 YEARS OLD. HAD THE SAME PROBLEM 4 YEARS AGO
Jan 17, 2008 | Mitsubishi VS-6043 60" Rear Projection...
HOW TO RESET MY TV LOCK CODE
OPTION MENU "MENU 1370" SERVICE MENU "MENU 2357" CONVERGENCE MENU "MENU 2359"
Sep 20, 2007 | Mitsubishi VS-6043 60" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
