Question about Epson PowerLite HC 6500UB OEM Projector Lamp
Optical engine replacement for Epson 6500 projector
Called Epson with magenta bar on the top of our image, and cyan bar on the bottom. They told me it was the optical engine. Cost is $1200 to repair. Is there a way to get this part and replace it my for less?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
USD500
We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Posted on Jan 04, 2015
4 Suggested Answers
tigertail
  • 163 Answers
SOURCE: need to replace the bulb in an epson e71 projector
Hi, this is pretty straight forward. Make sure the projector is off and cooled. On the bottom is the Lamp cover, press the two tabs and lift the cover off. Loosen the two retaining screws and pull the lamp assy upwards to remove. Fit the new lamp and tighten the screws then rfit the lamp cover. You will need to reset the Lamp hours using the "About" menu after turning back on (Not the "reset all" menu).
The user guide can be downloaded from Epson support:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=KBTjt4A8+KgSfbEGuimYvDcGHmpVV+Ko
Posted on Apr 01, 2009
projdoc
  • 2237 Answers
SOURCE: My EPSON Powerlite 730c projector doesn't power up
epson will not sell parts to anyone who is not an authorized service center. sorry. if you can get the part from an asc, then you can replace it.
Posted on Aug 18, 2009
SOURCE: epson t 13 are problem cannot accept the printer (
http://www.epson.com.ph/epson_philippines/printers_and_all_in_ones/inkjet/product.page?product_name=Epson_Stylus_T13
use epson N73 ink carttridge.
Posted on Feb 05, 2011
Printer is not printing yellow, Light Cyan, Cyan, blue lines through Light Magenta & Magenta, What could be causing this and it is also leaking black ink out of the bottom of printer.
Is it under warranty, are you re-filling the cartridges? If yes to first and no to the other two, send it back under warranty. If you use copy cartridges or refill old ones the warranty is vod. This means you need to replace the printer. To be honest, you'd be better off buying an Epson all in one. Even the wireless model start @ sound 40gbp and you can buy good copy cartridges from choicestationery.com
Nov 17, 2014 | HP Photosmart C8180 All-in-one -...
My HP 6500 only prints yellow and black. I refilled all three color cartridges and only the yellow is working. Any ideas?
This printer having four cartridges and two print heads.Each print head having two pens, black, yellow & magenta,cyan. As you said yellow & black are OK.. So replace Magenta & Cyan print head..
Oct 28, 2011 | HP Officejet 6500 Wireless All-in-One...
Epson DX7450 compatible ink problems
Press and hold the data button
Sep 22, 2009 | Epson Printer
We have a Phaser 7400. It continues to give us
If you've already changed out the toner cartridge and the problem persists, then it could be several other parts that are either defective, dirty or blocked.
You may want to contact a certified Xerox technician and have them look at the Imaging Unit Agitator Bar and the Low Toner Sensors for Cyan/Magenta. There could also be a faulty toner supply motor.
Sep 10, 2009 | Xerox Phaser 7400/DT Laser Printer
LCD projector spots showing up on the screen
there are light filters behind each lcd panel that determine the color of light going through it. because of excessive heat and dust, the filter tends to burn and cause discoloration in the image. if the image is bluish (cyan), the red filter is burning. if it's yellow, the blue is burning. if it's purplish (magenta), the green is burning. the filters will need to be replaced. unfortunately, many companies don't sell individual parts of the optical engine, so the entire engine might need to be replaced.
Aug 20, 2009 | Epson EMP S1 Multimedia Projector
My HP 6500 on install will recognize Cyan ink
Solution:
1. Try to determine whether the catridge is at fault. How so? Switch the Magenta with the Cyan catridge. Press OK.
2. If system indicates that the Magenta is not installed, you will know that the Cyan that you put there is at fault.
3. Touch the 9 mm. hole where you can see the sponge. Does the Cyan color transfer to your finger? If not, the catridge is empty or dried up. Replace or refill.
4. If the ink is normal, then use some toilet tissue to wipe the gold contact points clean. If this fails to solve your problem, take it to your dealer and ask for a replacement (if it fails to work in their machine).
5. If this fails, then the problem is within your HP 6500. You need a technician.
www.catherinecollege.net
Aug 08, 2009 | HP Officejet 6500 Wireless All-in-One...
Type of catridge epson stylus R390 uses can't find
You can see the reference on the cartridge itself.
Take it with you when you buy new ones.
Jul 29, 2009 | Epson Stylus Photo R390 InkJet Printer
All I get is a white screen. I replaced bulb, and nothing is different.
open the projector (6 inset screws on bottom) - carefully rermove the top (there are 2 wire sets attached: one for the speaker and one for the control panel) -- make sure all wire sets are properly seated -- i had one loose set -- reseated it, closed the projector and the thing wotks fine now. every repair facility i called didn't want to deal with the projector, and one person told me i ought to buy a new one
May 10, 2008 | Epson EMP S1 Multimedia Projector
Epson PowerLite HC 6500UB OEM Projector Lamp Logo
124 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
