Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Have sony trinitron older tv no place for headphone jack
No place for headphone jack to put my headphone for tv canyou help
techman
  • 3130 Answers
SOURCE: Sony Trinitron TV will not turn on
First thing that comes to mind is that the horizontal driver transformer has bad solder connections on the primary and the secondary windings. Also a set this old could also have a defective regulator IC if you dont know wht m saying , b=est thing to do is find out how much an estimate is then go back to best buy and see what a new set cost cause man you got your moneys worth outa this one for sure!!!!! Good Luck
Posted on May 02, 2006
  • 1348 Answers
SOURCE: Sony Trinitron kv-27HFR blurry
the picture tube is gone.
i repaired 150 sony xbr and kv series with that problem.sony has a single gun not three and has a great pix,but burn out faster.
there is a main screen control that you can adjust ,but the tube is gone.
on the back of the crt there is 3 gun drives r g b .
turn the color all the way down so it is black and white.
if there is a green ore purple tint,one gun is out of balance.
ajdusting the r g b controls so that black and white is normal is what you want to do.
the crt board has the screen bias voltage 800volts on it so be very careful and use an insulated screwdriver to adjust the drive controls.
Posted on May 13, 2009
stonephoenix
  • 563 Answers
SOURCE: How to run laptop through tv
G'Day mate!
In order to send the picture from any computer to a TV screen, you must have a VGA input on the TV. You can't output your computer signal using s-video, HDMI, or component cables because they aren't designed for computer use. If you have a VGA connection on your TV, then you can use a standard VGA cable. If your TV doesn't have one, unfortunately you're out of luck.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. I hope I've earned a positive rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 02, 2009
alexander404
  • 276 Answers
SOURCE: Does Sony FD Trinitron WEGA
Yes it does have a headphone jack. Lift the plastic door at bottom front center of TV to expose jack.
Posted on Aug 15, 2010
ekcnoel
  • 998 Answers
SOURCE: When I turn on my Sony Trinitron (@ 2001) there is
you have the problem in the pre amp you should check it if its grounded or clean it first
Posted on Oct 09, 2010
How can i use headphones on a sony trinitron
If there is a headphone socet at the front panel of the TV, you can. If not, can't.
Jan 03, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How do I connect wireless headphones to my sony kv34hs510
Are your headphones blutooth or infra-red? Is your Trinitron Blutooth or infrared enabled to allow you to listen to it thru your headphones? If so, there must be an on/off switch that would actuate the Blutooth or infrared meachanism on the Trinitron itself. Otherwise, you WON'T be able to hear sound.
Sep 19, 2012 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Can i attach headphones to my sony wega tv
One may connect headphones amplifier here:
TV Rear Panel
hope these helps,
thanks for choosing Fixya for assistance!
Aug 15, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How to hook up a Sony Large Screen FD Trinitron WEGA stereo color TV (KV-36FS13) to a aiwa cx-na888
first of all i did fing the sony manual on sony's website http://www.docs.sony.com/release/KV36FS13.PDF
page 32 shows the audio out jacks , run the red and white wires to the inputs on the aiwa (i did not find a manual for the aiwa) if there are no input jacks on the aiwa then you can not connect it.
hope this helps
Thanks
Roety
Dec 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Does Sony FD Trinitron WEGA KV-21CL10 21" TV has a headphone jack?
Aug 15, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
How do i make additional speakers work on a sony trinitron wega
at the back there should be a jack for headphones, plug your speakers in..
Dec 31, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I was watching tv, turned the channel and the sound quit. I turned off the tv for awhile and still no sound, on any channel. Is there anything I can do to fix it or do I need to take it for repair? It is a...
the speaker may have quit working. or possibly if the t.v has a headphone jack something may be in the hole causing te=he t.v to send audio to the jack instead of the speakers. if that is not it if you do have a jack for headphones you can plug in an adapter to hook up your media to an external speaker device, the first place to look is this jack, if no sound will come through your headphones either thanyou have an internal problem
Apr 07, 2009 | Sony Televison & Video
Problem with headphone jack
it is very essential that you removed the plug otherwise the speaker will not work. inside the jack terminal is a sort of mechanical switch that whenever you put the plug it switches off the speaker and removing will returned to on position.
Mar 01, 2007 | Sony FD Trinitron WEGA KV-BT21M40 TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
