Question about Canon ImageRunner C3480 Color Copier
Blurry prints on IRc3480 - Canon ImageRunner C3480 Color Copier
Error code 000025
Plz chek the hoper unit delivery & round motor. the moter has not running
Jul 24, 2014 | Canon ImageRunner Color 3480 | IRC3480 |
Can't print in color with both my computers
Check and compare the printer preference settings under Control Panel/ Printers and Faxes for the machine. You may find that one PC's default has been set to print B&W.
Jan 30, 2014 | Canon ImageRunner Color 3480 | IRC3480 |
E000804-000
804 for power supply cooling fan error, check and replace cooling fan for power supply
Jan 15, 2014 | Canon ImageRunner Color 3480 | IRC3480 |
Hp 5550dn prints text fine but pictures are blurry?
Don't replace but verify the condition of fuser assembly, if you found any cracks or folds on teflon roller or pressure roller causes the same thing, just verify get back to us...
Feb 01, 2012 | HP LaserJet 5550DN Printer
We have a canon IRC3480 copier and it keeps jaming. No matter what tray we use.
press *28* to enter service mode press copier then press jam this will give you more detail on your issue
Nov 25, 2009 | Canon Office Equipment & Supplies
Printing every few lines blurry, but not every line.
Printer head is clogged, be sure to clean it until you get the solid lines
Jul 11, 2009 | Epson Stylus R380 InkJet Photo Printer
Irregular paper size
This possibility is not provided. You should solve a problem only manual presenting or format close to your but standard, but then zoom to correct the size on standard format. Spasibbo. Good luck
Jun 06, 2009 | Sharp AR-5316 Advanced Digital Imager...
Prints blurry every other line with black color
Is it the ink cartridge contacts you already cleaned? If so, then you can also clean it using the tools menu from the printer panel:
-press setup menu, then go to tools
-select clean print cartridge and press ok
-it will print a test page. If the printout is good, you can try printing again.
I hope this helps.
Regards,
Feb 24, 2009 | HP OfficeJet 7410 All-In-One InkJet...
BLURRY PRINT OUTPUT
The head probably needs aligning.
An interum fix is to turn off bi directional printing in the preferences.
This could possibly solve the problem.
Jun 10, 2008 | Brother DCP 115C All-In-One InkJet Printer
Fuzzy page continious.
Yeah I just read a tip. There seems to be a problem with the wave amp board, I will send you the engineering note. Sometimes though that encoder needs replaced and cleaning is not the total fix. The encoder may need replaced, but I found this also.
I just received this, this morning.
Failed Wave Amp
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Historically blurry print was caused by oil on the drum encoder wheel. This can be caused by the wave amp board. A cracked capacitor on the board causes the wave amp to produce a malformed amplified wave signal to the printhead. This in turn causes the printhead to eject ink at the wrong times, so the prints look blurry.
You can generally distinguish a wave amp problem from an oily drum encoder. The wave amp problem will usually be an infant failure. The printer will start producing blurry prints soon after it is installed and running. With a failed wave amp all prints will be blurry with no improvement. The drum encoder, on the other hand, may produce good prints and then bad prints and then good prints. Blurriness changes depending on how the oil is interfering with the encoder.
May 05, 2008 | Xerox Phaser 8500/DN Printer
Canon ImageRunner C3480 Color Copier Logo
18 people viewed this question
old marine
old marine
