Question about Dell (7130CDN) Laser Printer
Dell 7130CDN fuser warning wont come off even though it was replaced
Dell 7130CDN Chattering along with lines in color image.
Pay him
and let him fix with new items
you might end up destroying the whole machine
Jan 14, 2016 | Dell 7130cdn Printer
How do you reset maintenance count on a dell 3130?
You don't. You can't.
When you install a replacement Transfer belt (it has it's own counter chip) that resets the transfer belt pagecount, and as a result clears any transfer belt life related warnings/errors.
When you install a REPLACEMENT Fuser (that has it's own counter chip) that resets the fuser pagecount, and as a result clears any fuser life related warnings/errors.
PLEASE NOTE - The fuser supplied with the DELL 3130 when new DOES NOPT have a counter chip - the fuser life warnigs are triggered by the printer pagecount. Installing a fuser from another printer (even if it has a ZERO pagecount WILL NOT reset the fuser pagecount (because the 'ship with' fuser has no counter chip.
Aug 27, 2014 | Dell 3130cn Color Laser Printer
Hp lj 4100 50.2 error
is this error on a lj4100 or on a cm1017?
if on a 4100- then the complaint is that the fuser has not reached the required temperature in the allocated time- replace fuser kit with CORRECT fuser ( lm4100MKIT) and not a 4000 fuser which is not the same even though they look like each other.
if its a cm1017 then the error is poor communication with the thermal resistor measuring the fuser temp. again replace fuser kit to resolve
Dec 17, 2013 | HP LaserJet CM1017 MFP All-In-One Color...
Hi there, My Dell 1815dn printer makes a clicking sound when I turn it on, and displays an error message "fuser door open", even when the door is closed. I have removed the fuser and turned...
There is a switch that should "close" when the door closes.
But, that switch either is damaged, or it is not sending the "now closed" signal to the printer.
Check that there is no obstruction blocking that switch, nor any dust plugging it up.
Jun 08, 2011 | Office Equipment & Supplies
I have a Dell 1700n that prints just fine, except that the toner is not fused to the paper. If I blow on the paper the toner all blows off. How do i determine which part is failed.
The fuser is bad, check inside for paper wrapped around the fuser roller because normally the printer will shut down if there's not enough heat at the fuser or the lamp is burned out. The fuser is just before the paper exit and has heat warning labels attached.
Jan 05, 2010 | Dell 1700n Laser Printer
Clear fuser life warning C524
Replacing the fuser
When 80 Fuser life warning appears on the operator panel, replace the fuser soon. Make sure one is on order. See
Ordering a fuser for more information.
When 80 Replace Fuser appears on the operator panel, replace the fuser immediately.
......From the Lexmark users guide.....
Dec 23, 2009 | Lexmark C524 Laser Printer
Dell 1600N Multifunction printer problem.
Fuser issues - if problem is reoccuring then you are looking at more expense, are all vents free of obstructions (folders leaning on machine sides/rear) is machine being flogged, is power supply consistent, maybe even fuser bought was faulty, many options, try doing a warranty claim on fuser or replace again, even better get another printer, welcome to our throw away world!
Oct 31, 2007 | Dell 1600n All-In-One Laser Printer
Dell (7130CDN) Laser Printer Logo
44 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
