Question about Kenwood Audio Players & Recorders
NEED A VOLUME CONTROL FOR KENWOOD KR-A5040
SOUND MISSES AT LOW VOLUME SETTINGS
2 Suggested Answers
  • 4234 Answers
SOURCE: sound problem
Try cleaning the volume control with an electronics switch cleaner spray. If that does not resolve the problem and it seems to happen at low volumes more than load volumes, then the output relay needs to be replaced. Keep us posted. Dan
Posted on Jun 12, 2009
I'm not getting any sound from my speakers Kenwood kr-a4030
You may need a repair on this tuner but a simple test you can perform is to hook up another set of speakers or even just one different speaker. Test and if you get volume it is your speakers.
Granted this is highly unlikely that you blew both speakers at the same time but it is worth testing. If the test does not change anything then you should get your KR-A4030 repaired.
Jan 17, 2016 | Kenwood Audio Players & Recorders
Kenwood kr 5050 volume stuck on high cant change
These days the circuit of the volume control is controlled by an IC in modern amps. These can go faulty preventing adjustment of the sound by the volume control. The only cure is to find the IC and replace it. You can start in the area where the volume control is located. If it's not mounted direct on the PC board, follow the connections to the board. Hopefully the board might have writing on it to indicate the area where the faulty IC is.
Aug 04, 2015 | Kenwood Audio Players & Recorders
How do i connect my Kenwood KR-A5040 to my PC?
you can use the headphone out from your computer (this will turn off computer speakers) using a mini headphone to male rca adapter cable, and connect the rca ends to ANY input on your reciever
Mar 01, 2013 | Audio Players & Recorders
Can the Kenwood KR-4600 connect to an ipod?
Hi,yes you can connect Kenwood KR-4600 to an ipod.
Instruction..
You will need an coolken_9.jpgRCA cable .
Connect the RCA (red and black to the input of the Kenwood KR-4600...You have options of inputs to use..
Either input at the back of the Kenwood KR-4600,or tape A and tape B..which ever you wan to use..
After connecting the red and black RCA to Kenwood KR-4600, then connect the other jack end to the ipod, and go the front of the Kenwood KR-4600 to activate the input selection knob to the desired input being selected at the back of the Kenwood KR-4600..
And don't forget to turn on the volume of the Kenwood KR-4600 and also the iPod volume..
And after that your done..
Good luck to you..
Aug 10, 2011 | Kenwood Audio Players & Recorders
Where on the Kenwood KR-V5580 do I connect a sub woofer
Wherever the unidentified subwoofer's manual recommends. As there are no volume-controlled pre-amp outputs it would have to be a model that accepts full-range speaker level input if you want to control its volume locally.
Jul 02, 2011 | Kenwood KR-V5580
Kenwood kr-v6030 master volume wont go down
To zyclon3, I've got a KR-V6030 that the volume knob some how got broke and had to take the receiver apart and get the knob out and play with it with the remote untill I got control. but I have to becareful cause it will go full blast if I'm not carefull going down in volume have to be especialy carefull since theres no stop.
Mar 08, 2010 | Kenwood Audio Players & Recorders
Sound problem
Jun 12, 2009 | Kenwood Audio Players & Recorders
Volume control for kenwood krv5580
I was able to get the volume control to work, but how do you get an amplifiter to hook up to it?
Jan 08, 2009 | Kenwood KR-V5580
Have a kenwood KR-V990D and can't seem to bring the volume up
kenwood has always showed negative numbers 00 is as high as it will go
Jan 06, 2008 | Kenwood KR-V990D Receiver
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
