Question about MicroBoards Computers & Internet
Microboard copywriter won't close disc
Both the master drive are slow to open. When I finish recording sometime it won't finalize and close the disk. It won't even eject the disk. The only way to retrieve the disk is to turn off the machine but then the recording is lost.
PcExpert
  • 293 Answers
SOURCE: BenQ DQ60 DVD RW Dual Layer Burner drive won't open
Just replace the Belt it is located on the Motor. Dont clean the tray for it has Grease on it needed for lubrication just brush off dust that will do. This link will help you more http://images.google.com.ph/imgres?imgurl=http://an.hitchcock.org/repairfaq/sam/pcap.gif&imgrefurl=http://an.hitchcock.org/repairfaq/sam/cdfaq.htm&h=373&w=311&sz=38&hl=tl&start=7&tbnid=bwh4xXxvWjUylM:&tbnh=122&tbnw=102&prev=/images%3Fq%3Dcdrom%2Bbelt%26gbv%3D2%26svnum%3D10%26hl%3Dtl
Posted on Sep 18, 2007
  • 46 Answers
SOURCE: dvd burner won' eject dvd
On the front of the burner there is a pin hole. Take a paperclip and unfold it so it's a point. Stick it in the hole and it should open the tray. This should FixYa!
Posted on Jan 27, 2009
fixit0909090
  • 44 Answers
SOURCE: Liteon LVW-5005 DVD Recorder. Disk drive door will not open.
give it a tap on the bottom as you press the button, this will force it to release the disc,
Posted on Sep 27, 2009
dwane4444
  • 219 Answers
SOURCE: Panasonic SW-9571-CYY Ejects DVD RAM Cartridge.
Hi, I don't know if you ever solved this problem - but I had the same thing on my SW9571CYY. The solution is to replace the small drive belt inside the drive ( It is very thin and doesn't seem up to the job it has to do). Just remove the two screws on the rear, then the seven screws holding the plastic cover with the springs on it (don't worry - everything stays in place). Lift the disk tray out and the little belt is towards the front. I used an old belt from a broken LG GSA-5163D that was lying around. I think it would be difficult to find the correct spare so some people have even used a "O" ring with a slightly smaller diameter than the original belt.
Hope this helps Dwane4444
Posted on Oct 27, 2009
  • 10406 Answers
SOURCE: drive won,t play discs and sometime won,t reconize that a disc is
If the "bad" disks work fine in some other DVD-player, then it's time to spend $40 and buy a new DVD-writer.
Or, if your current DVD-player is under the manufacturer's warranty, exercise the warranty, to get it repaired/replaced.
Posted on Dec 28, 2009
I have a technics SL-CH505 compact disc but it will not play burnt CD;s any suggestions my other technics SL PG 400A plays them noproblem
The Optical Pickup(laser) may be weak. It takes much more power to record than play, which I guess it works.
Oct 13, 2014 | Technics Audio Players & Recorders
How to copy anything else on finalised DVD or - to HDD on samsung HR 755
If the disk is finalized you can't normally write anything else.
The words "Finalizing" and "Closing" are used interchangeably by most recording applications. To "Finalize" or "Close" a disc means that no additional data can be written to it. This is done when the last session's lead-in is written. The option to close a disc is usually selected after all of the data that will be written has been placed in the project window, and the user knows that no more data will be added to the disc in subsequent recording sessions. The next writable address on the disc is not recorded in that lead-in, so the CD recorder, in subsequent attempts to write, has no way of knowing where to begin writing.
Mar 09, 2008 | Televison & Video
When I power up my LG RHT397H the DVD tray opens, it will not accept any discs. If I press CLOSE the tray closes then re-opens. The fault only affects the DVD drive - the unit records on the hard disk, and...
Sounds like possibly the Spin Motor is bad and not spinning up the disc's. That's usually what I've found, if it were the optics assembly, it would take a long time before it finally gives up and say's something like "No Disc", "Disc Err", etc.
Jun 12, 2010 | Televison & Video
Recorder fails during 92% finalizing.
The free CDBurnerXP Pro is supposedly able to close unclosed disks, but I have never figured out how to do it. Maybe you'll be luckier than me or the newer version is more user friendly.
Sep 16, 2009 | Lite On LVW-1107HC1 DVD Recorder
Can not get the 'Finalize Disc' option on the
Do not worry about no Finalize Disk option. You may have it under another guise.
A recording session can be specofied as open ( Default ), or closed. If closed DATA cannot be appended to the disk.
No matter how many sessions have been written, if the last session is closed no more can be written. Your software automatically finalizes each session, in fact must.
Feb 23, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
Ilo dvdr04 records but will not "finalize" disc. I
Make sure after you are done recording the disk you push the stop botten Twice befofre going to the menu to finalize disk...now that option should open dor you!
Dec 11, 2008 | iLO DVDR05 DVD Recorder
Finalizing
IF THAT DISC WAS RECORDED ON AND THEN REMOVED BEFORE FINALIZING IT WILL NOT FINALIZE. THE CAMERA LOOSES THE MAIN INFORMATION TABLE FOR THAT RECORDING. ONLY THING TO DO NOW IS, IF THE DISC CAN STILL PLAYBACK ON THE CAMERA THEN CONNECT IT TO A DVD RECORDER VIA THE AV PORT AND RECORD.
Mar 30, 2008 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Unreadable disk error
The laser in 5101 could be defective or maybe just dirty.Try cleaning with a commercial cleaning disc,put a drop of rubbing alcohol on cleaning brushes.When this happens sometimes it will still be a usable disc but not always.Try putting in another dvd player or recorder or your PC if it plays dvds,the readers in PC are of a better quality and will often read discs that those cheap dvd readers can't.
R+ or R- discs need to finalized after recording RW+and RW- discs do not.It is always a good policy to finalze the second your recording is finished otherwise it may not play in other players or recorders.
When you make a recording in a dvd recorder an it doensn't recognize the disc it just recorded it quite often has a defective laser.This particular model has been plagued with early laser failure.
Mar 14, 2008 | Lite On LVW-5101 DVD Recorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Won' record
Check your wire they could be damage
Apr 04, 2007 | LG ADR-620N CD Player
Computers & Internet Logo
Top MicroBoards Computers & Internet Experts
Rick Moore
Rick Moore
 Grubhead
Grubhead
Are you a MicroBoards Computer and Internet Expert? Answer questions, earn points and help others
