Question about Maxtor DiamondMax Computers & Internet
Maxtor diamondmax 21320gb pata jumper settings
  • 86 Answers
SOURCE: maxtor 500 gig internal diamondmax 21
external USB hard drives do not need to be jumpered, if your computer does not recognize the ext. drive probably it is because the enclosure is defective, when you connect the USB cable you should get the "ding-dong" connection sound.
If you think that your computer recognizes the hard drive then jumper it as "secondary" or "cable select" and install it INTERNALLY, then transfer your data, that will prove that there's a problem with the ext. enclosure.
One more thing, maybe the USB port you use is malfunctioning, try one that you know that works (assuming that you have other USB devices that work).
Posted on May 07, 2008
SOURCE: Maxtor diamondmax 10 jumper settings
http://www.tacktech.com/display.cfm?ttid=379
or
http://www.tacktech.com/images/articles/379/mxo_ata_jumpers_2.png
Hope this helps ;-P
Posted on Sep 25, 2008
ODCaloney
  • 260 Answers
SOURCE: jumper setting for maxtor n256 diamondmax vl 40
There is usually a diagram on the drive showing the jumper configuration.
Posted on Mar 16, 2009
astrotheque
  • 4 Answers
SOURCE: what are the jumper setting for slave on maxtor diamondmax plus 9
This web page shows the jumper settings you require.
http://www.google.com/imgres?imgurl=http://www.seagate.com/staticfiles/images/support/en/us/mxo_ata_jumpers_rev.jpg&imgrefurl=http://forums.macrumors.com/showthread.php%3Ft%3D387061&usg=__oBf6Czrk9E5_4ovUuuyxJCl68fY=&h=411&w=850&sz=83&hl=en&start=3&itbs=1&tbnid=J_I6lp0cCbuIwM:&tbnh=70&tbnw=145&prev=/images%3Fq%3DJumper%2Bsettings%2Bold%2BMaxtor%26hl%3Den%26sa%3DG
Posted on Dec 01, 2009
yammy_alf
  • 666 Answers
SOURCE: jumpers for Maxtor HDD's
check with this configuration,
Posted on Apr 05, 2010
What is the jumper pin placement to make a slave of a DiamondMax Plus 9, 80GB hard drive?
The manual is linked below and section 3.3.1 covers jumper settings.
The slave setting shows the park position so you have a jumper on the drive so you can reconfigure it later.
A quick answer is that the slave setting is no jumper at all on the jumper pins.
DiamondMax Plus 9 Manual - DiamondMaxPlus 9.book
Feb 12, 2011 | Maxtor Hard Drive
What is the jumper setting to service (format) the diamondmax plus 9 disk?
This document might help you:
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/diamondmax_plus_9_manual.pdf
Oct 06, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
How to set jumper to slave mode on maxtor 6y080m0(picture pls)
These are the jumper settings for a Maxtor Diamond Max ATA hard drive.
Sep 23, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
Can I use a Maxtor DiamondMax Plus 60 (5T040H4) 40.9 GB like Slave?? Thank you
Of course you can use it. Put the jumper to set the configuration as "slave" and insert the a plug from the ide cable. If you put the put the jumper to "cable select", put the slave plug and it should work great.
Mar 15, 2010 | Maxtor DiamondMax Plus 60 (5T040H4) 40.9...
I have a quantum fireball lct20 40gb hard drive that I am attempting to install as a slave drive in a Dell Dimension 2400 desktop, and while it works in other computers, I keep getting the BIOS detection...
Maxtor CrystalMax 1080
Maxtor Fireball 531DX Ultra ATA 100
Maxtor DiamondMax 16
Maxtor DiamondMax 1750 Ultra ATA 33
Maxtor DiamondMax 1750A Ultra ATA
Maxtor DiamondMax 17 VL Ultra ATA 66
Maxtor DiamondMax 20 VL Ultra ATA 66
Maxtor DiamondMax 2160 Ultra ATA
Maxtor DiamondMax 2880 Ultra ATA
Maxtor DiamondMax 30 VL Ultra ATA 100
Maxtor DiamondMax 30 VL Ultra ATA 66
Maxtor DiamondMax 3400 Ultra ATA
Maxtor DiamondMax 36 ATA 66
Maxtor DiamondMax 40 ATA 66
Maxtor DiamondMax 40 VL Ultra ATA 100
Maxtor DiamondMax 4320 Ultra ATA
Maxtor DiamondMax 536DX
Maxtor DiamondMax 60 ATA 100
Maxtor DiamondMax 60 ATA 66
Maxtor DiamondMax 6800 Ultra ATA
Maxtor DiamondMax 80 ATA 100
Maxtor DiamondMax D540X-4D
Maxtor DiamondMax D540X-4G
Maxtor DiamondMax Plus 2500 Ultra ATA
Maxtor DiamondMax Plus 40 Ultra ATA 100
Maxtor DiamondMax Plus 40 Ultra ATA 66
Maxtor DiamondMax Plus 45 Ultra ATA 100
Maxtor DiamondMax Plus 5120 Ultra ATA 33
Maxtor DiamondMax Plus 5120 Ultra ATA 66
Maxtor DiamondMax Plus 60 Ultra ATA 100
Maxtor DiamondMax Plus 6800 Ultra ATA 66
Maxtor DiamondMax Ultra ATA
Maxtor DiamondMax Plus 8
Maxtor DiamondMax D540X_4K
Maxtor DiamondMax D540X_4L
Maxtor DiamondMax D740X
Maxtor Fireball 541DX
Maxtor Fireball LCT20
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball LCT15
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
Maxtor DiamondMax 10
Maxtor DiamondMax 11
Feb 22, 2010 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
What are the jumper setting for slave on maxtor diamondmax plus 9
Dec 01, 2009 | Maxtor DiamondMax Plus 9 120 GB Hard Drive
Jumper settings for a maxtor N256 master with slave
Select the maxtor HDD as master by setting the Jumper to the extreme left of the hdd; i.e. next to the data cable.
Remove all jumpers from the other HDD which you want to put as slave.
Sep 02, 2009 | Maxtor DiamondMax 80 (96147H6) 61.4 GB...
Jumper setting for maxtor n256 diamondmax vl 40 5400 rpm
Mar 16, 2009 | Maxtor Hard Drive
Maxtor 500 gig internal diamondmax 21
May 04, 2008 | Maxtor Hard Drive
Jumper settings for a Maxtor hard drive, Model 87000D8
Here's the chart that lists the jumper settings for all of the various models of Maxtor hard drives:
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
The first drive above is a DiamondMax 1750, and
the 2nd is a DiamondMax 4320
Feb 08, 2008 | Maxtor Hard Drive
Computers & Internet Logo
320 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
