Question about Thermador SC272T Electric Double Oven
Flashing F33 error code thermador double oven
F33 error code
    Champion:
  • Thermador Expert
  • 323 Answers
Either a bad oven sensor or a bad power relay board.
Posted on Feb 03, 2015
Master_Tech
  • 770 Answers
SOURCE: f7 error
F7= function key is stuck or shorted >> you can turn the breaker off to the unit then back on if it come back up it will have to be replaced
Posted on Jan 27, 2008
  • 1314 Answers
SOURCE: Thermador Convection Oven
well im not terribly familer with thermadors wiring but pull the top off and find the tech sheet then look for a device call a thermal fuse or tco thermal cut off most times they are on top or on the back of the oven yours should have one for each oven bet the one for the top is open can happen if there installed in to close a space
Posted on Jan 30, 2008
  • 5 Answers
SOURCE: thermador c302 door hinges
487746 is the part number for the 30 inch model and
487747 is the part number for the 27 inch model if this is the parts you recieved then the should fit there should not be much difference
Posted on Jan 15, 2009
  • 9 Answers
SOURCE: Lighting panel in my electric Thermadore double oven is dim.
The cap replacement worked....saving $250 (every 2 years !!!) I posted it on another site...now its making its way around the web....its the only value added thing I've done on the web (sadly!).
Posted on Feb 06, 2009
tunde007
  • 2382 Answers
SOURCE: Error code F64 on lower
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Posted on Nov 12, 2010
Why do I have error code F25 on my Thermador oven error codes
clean the touchpad control panel. Make sure the oven door closes properly to prevent excessive heating of the touchpad. If these don't resolve it, it calls for a replacement of BOTH the touchpad AND the relay board. EXPENSIVE!
Aug 23, 2014 | Thermador SC272T Electric Double Oven
I have a thermador oven x302xp getting code f33 on displ;ay
oven over temperature. replace oven sensor, replace relay board if repeats.
Dec 15, 2013 | Thermador C301U Electric Single Oven
CM302US Thermador Double Oven F34/64 Problems need schematic diagrams
air flow/fan issue. either bad fan motor, air flow switch or relay board.
Nov 29, 2012 | Thermador C302U Electric Double Oven
Thermador c272u double oven error code f33
over temperature. Check the oven sensor, if ok, replace the relay board for that oven (upper or lower)
Sep 16, 2012 | Thermador Ovens
F5 error code
F5 = EOC electronic control failure replace electronic control is stated in the service manual. If you have any further questions message me them back. Thank you
Rick
Nov 28, 2011 | Thermador SC302T Electric Double Oven
F33 CODE
this is uper oven over temperature while cooking , check sensor should read 1080 ohms, at room temp, if ok replace power relay board
Apr 20, 2011 | Thermador C301U Electric Single Oven
I have thermador double oven (I think it is model sec30 something-cannot read it) which i have had for 3 years with consistant problems with F33 displaying. Can you help me in telling me how I can reset...
In 30+ years of servicing I have replaced very few oven sensors due to failure. True, a sensor may need to be replaced, but there is also another possibility and a much cheaper solution at that.
If you look at the two soldered pins where the sensor wires attach at the oven relay board, you may find them to have heat fractures in the solder around one or both. These are very hard to see with the untrained eye, but any small fracturing will change the sensor reading to the main board. Therefore it is important to re-solder these pins at the relay board.
This is a job for a qualified service Tech and should not be attempted by the average DIYer.
Dec 04, 2010 | Thermador SMW272 Electric Double Oven
What is error code F34 on the thermadore built in double oven
If your Thermador was manufactured between 2004 and 2007, this may be due to a recall issue. I kept getting this error on my Thermador wall oven when I would run the self-cleaning feature, and when heating it over 375 degrees. After doing some research, I discovered that my oven was recalled. Apparently there are gaps in the insulation which could cause a fire. You can find out more on the Thermador website: http://www.thermador.com/safety-notices/7_oven-safety-recall-notice-expanded
Oct 15, 2010 | Ovens
My thermador oven tells me error code 14
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
May 12, 2009 | Thermador SMW272 Electric Double Oven
Thermador SC272T Electric Double Oven Logo
382 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
