Question about Wahl Clip n Trim 21-Piece Clipper/Trimmer 79900B
My wahl hair clippers wont cut hair short enough on a number 1
Does not cut hair properly
geokohler
  • 304 Answers
SOURCE: wahl designer clipper
Have you been oiling the blades? If you ran out of oil you can use any light machine oil available at any hardware store. If you feel comfortable opening the unit you will be able to see the electromagnet inside and watch what is going on. If all else fails Buy a new set (the exact kind) and keep the receipt. Swap them out and return it from the store where you purchased it. You paid good money for them and they should not have died so quickly. The store will get full credit for it when they return it to the manufacturer so it is not that morally bad. The manufacturer should bare the burden because of the poor quality control that allowed your clipper to die in such a short period of time. Hope you find this solution helpful and the last option is a surefire fix...
George
Posted on Jul 25, 2008
  • 3 Answers
SOURCE: wahl 9765-301
sounds like you have very dull blades and need to replace or sharpen them also your blades may not be tight enough or your screws may be stripped enough as to not tighten down properly. does your clipper sound like the motor wants to slow down when you try using them for an extended time? if so replace the clippers. did you take apart the clipper housing and make sure it is free from all hair? sometimes hair will get into the motor area and cause the blades not to work properly.
Posted on Oct 14, 2008
philschneide
  • 448 Answers
SOURCE: Noisy wahl hair clippers
If your clippers are the magnetic type (rather than pivot or rotary) they should have a large screw on the side for adjustment (I think the screw you mentioned). The standard adjustment of the screw is to turn it in while the clipper is running until the sound of the clipper increases substantially. Then turn the screw back out, slowly, until the sound decreases again. Turn another 1/4 to 1/2 turn.
Unless something else is wrong, this should take care of the problem, along with proper oiling of the blades.
I hope this helps you.
Posted on Oct 12, 2009
  • 10 Answers
SOURCE: wahl hair clippers
lol This is unfortunate! I set these day in, day out, you have the right idea. Use the lever to push the cutter all the way forward, then push the comb down using your work surface, then use you free hand to tighten the screws. If your clipper is in factory condition this will have aligned them perfect. Give up? May or may not be wiorth it for you but try www.sheareaseltd.com Get postage details there, send your clipper to them (I work for them), pay the postage for them to get there, put a note in your box to Ash, asking me to align your blades, and I'll sort it for you but I'd have to charge return postage at £5!
Hope this helps!
Posted on Aug 03, 2010
brector3
  • 1624 Answers
SOURCE: I have purchased WAHL PREMIUM
If it is rated for 120V, you can't change the voltage. You may be able to use it with a voltage converter.
If you need 220V clippers, you will find some at shaveroutlet.com. See link below
http://shaveroutlet.com/grooming/hair-clippers-and-trimmers.html?power_source=44
Posted on Sep 19, 2010
My husbands clippers won't cut
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
https://www.youtube.com/watch?v=DX4Xc47F_IE
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
www.fixya.com/.../t3222969-clippers_hum_like_working_but_dont_cut
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers ยท 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
www.rapidedge.com.au/cat/maintclip.html
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
Dec 21, 2015 | Health & Beauty
Wahl clippers
The clipper was being held at too sharp of an angle
Oct 01, 2013 | Wahl Super Taper Hair Clipper 2000 Hair...
Is it easier to cut hair when its wet or dry?
It's definitely easier to comb and de-tangle hair when it's wet and you get a better sense of the natural fall of the hair when it's wet. It's just much easier to work with than dry hair, so even if you aren't going for a full hair wash at the salon, make sure you ask them to spray your hair wet when you get it cut.
Feb 14, 2013 | Health & Beauty
How do I reduce my clipper's rattling noise and still be able to cut properly?
The power screw is the correct way to adjust the problem you describe. If you have attempted to adjust it as instructed in the user manual and have not had satisfactory results, there may be a problem with the clippers.
Most Wahl clippers have a 1 year or longer warranty. You can call Wahl for warranty service at 1-800-334-4627
Nov 12, 2011 | Health & Beauty
How do I use Wahl hair clippers? How do I know
Hi I have been a hair stylist for 25 years each guard that clips on has a number on them the lower the number the more hair is clipper off start big like a number 8 will leave one inch of hair 7 leaves 7/8 of a inch 6 leaves 3/4 of a inch 5 leaves 5/8 of a inch 4 leaves a 1/2 inch of hair on the head 3 leaves 3/8 of a inch 2 leaves 1/4 of a inch and a 1 is just hair on the Scalp almost bald no days the color of guards are changing so your best bet is go with the size remember to start with the largest one first then you will know what you like the best and you can't go wrong and if you buy WAHL and you not A Hair Stylist You Can Purchase A Good Clipper at Sallys Good Luck
Jul 30, 2011 | Wahl Health & Beauty
How can I make my curly hair short but beautiful?
The best thing to do is to look at pictures of celebrities, http://www.stylelist.com has a lot of pictures and tips on how to get your hair cut, they have guides for how to get it cut depending on the shae of your face. Also here's a short guide on short curly hair: http://www.latest-hairstyles.com/curly/short.html
Good Luck
Apr 29, 2011 | Health & Beauty
Clippers have suddenly stopped cutting and seem to pull at the hair
Generally removing the two screws.. on the blade foot (don't do this over the sink unless the drain is closed!).. and taking the blade apart.. cleaning the trimmers with a small brush.. apply grease in the blade groove.. reassemble
Usually it's best to put those two screws back just get them in lose.. not quite snug..set the blade upside down on a flat surface..so it pushes the blade back away from the cutting end..level..then tighten those screws while you are pushing or holding down on the clippers cutting edge against the flat surface/table. ... oil the blade with the proper oil or a light mineral oil.
This usually will get them back to cutting properly..the blade should be oiled prior to each use...about two to three drops right along the visible part..or a light spray also hair should be clean.. dirty hair does not cut well at all..and the clippers will tug and pull rather than cut cleanly.
Lastly..if they see a lot of use. might be blade replacement time..
Best of luck!
Apr 13, 2011 | Oster 76076-010 Hair Trimmer
My newly bought WAHL hair clipper but it is not sharp enough to cut my hair. what can i do to solve this problem.
The only thing here you can do is, if you want your blades to be sharper you need to send them to a professional sharpening service. Manny's Sharpening can help you with that, We have a mail order service with includes Free return shipping. We only charge $8.00 per blade set.Check out my web page, we also included a shipping Label and order form. Manny's Mail Order Sharpening
Mar 13, 2011 | Wahl Magic Clip Clippers Hair Trimmer
I used the clippers to cut my dog... once finished I took it apart to clean out excess lubed parts and reassembled...I have done this many times before with no problems... I begin cutting and the blades...
Check your blade latch is working properly. If you took your clipper apart and your blades are not cutting it is one of 2 things. Your blade drive is not assembled properly or your blade latch is not holding the blade on the clipper. If you took your blade apart, check the blade alignment. The cutter blade needs to be slightly behind the comb blade.
Mar 11, 2011 | Andis AGC2 Hair Trimmer
Wahl Clip n Trim 21-Piece Clipper/Trimmer 79900B Logo
89 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
