Question about ION Audio ION PROFLASH LP USBPLATTENSPIELER Turntable
Very low right channel recording - ION Audio ION PROFLASH LP USBPLATTENSPIELER Turntable
    Novelist:
    Scholar:
  • 156 Answers
If it's not wiring, then a faulty cartridge can cause that.
Posted on Mar 01, 2015
Why does the channel up or down sometimes not work?
It sounds to me like you have a fault in the tuner circuit. I suggest you take it on for service.
Oct 23, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
How do I attach and play a technics record deck to a technics DV250 amplifyer?
The problem you are facing is that the record player audio outputs has a left channel, a right channel and an earth or grounding cable. If this grounding cable isn't attached, you are likely to get a hum sound. I would suggest buying a record player RCA (Ground simulating) cable or you will have to buy an inexpensive mixer that supports record players through which you can channel this record player. Once you have all these, just follow the white and red color coding to attache the right channel to the right socket.
May 10, 2014 | Technics SC-DV290 System
Behringer mixer Eurorack UB802 is losing partial stereo signal in one channel. When I record (audacity software) I can hear both channels but displays one channel. Is it my computer's audio jack t
Sounds like the output cable from the 802 is not correctly pinned to your input on the computer. Fred is on the right track but you may need to take it a bit further.
It may also be helpful to use a Pro USB audio interface such as the Digigram UAX220v2 (line level version).
If you wish to use the computer's on board sound card consider an IHF/Pro interface that converts balanced audio to unbalanced , and the proper cables. Two 3-wire balanced 1/4-inch from the 802 to the left and right inputs of the interface (XLR Male), then RCA (Red and White) to a 1/8-inch TRS Plug cable onto the the computers audio input.
Henry Engineering's Matchbox HD comes to mind.
Good Luck.
Apr 24, 2012 | Behringer Eurorack Ub802 - Ultra Low-Noise...
When I recorded a cassette, the problem is the stereo is going to mono either left or right channel, and also have low volume problem during recording.
This sounds like an recording pre-amp problem. Anything common to both channels problem faults are always connected with a device that has both channels going in and out of it. In this case I suspect a recording pre-amp IC.
Jul 07, 2010 | JVC TD-W254 Single Cassette Deck
Sound is to low on some of the channel or dvds
this problem occurs because of the channels and dvds itself.. because while recording the dvds or the telecasting the tv channels,,they keep a less sound and record it,, so as the result of it, you get a low sound in television and in some dvds.. thank u.. pla rate me...
Jun 28, 2009 | Sharp Televison & Video
Records on right channel only so only get music from right speake
If you are recording from an outside source check the connections are good. If it does it from both IE dubbing and external it is possibly that a wire has detached from the head of the record head. The other likely source is the record amp inside the deck. Trace the leads from the Tape head (recording one) and see if you can locate a switch, these can get dirt on the contacts and cut out channels (clean with Servisol video 40). It could also be the electronics especially the amp chip!
If not then the head itself may have gone.
Mar 19, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Quiet right channel when playing pre-recorded tape.
With the deck in play mode put your finger on the imput of the channel that is low. If it buzzers the same as the other then you may have a faulty head. If it does not there is something wrong in the amp stages of the deck. You can also reverse the leads from the head and if the sound goes down on the other channel it is the head. Try doing it where the leads join with the PC Board, it will be less messing than at the head itself.
Jan 28, 2009 | Audio Players & Recorders
AKG Perception Microphone ony recording in mono but want stereo.
I have similar problems with inputing stereo sound. How do you know your mic port on the PC is set for stereo? What kind of a cable are you using? If it is an XLR, the connection is pure mono. Maybe you need a TRS cable, which looks like a 1/4 inch jack but is really stereo. Maybe you need a stereo mini. Usually a cable mismatch is the problem. Is your phantom power supply passing stereo? All the ones I have seen are mono. You may need two. Is your sound capture set for stereo? Are the input level controls set correctly for equal volume on left or right channel? I would try the mic with a regular amplifier to insure both channels are working. Then trace the signal from mic to power supply and power supply to computer.
Dec 03, 2008 | AKG Perception 100 Microphone
Dmr-es10 dvd recorder - cant get the machine to record digital channels form tv
Channels 1-5 are I believe for Analogue reception. To record from my digital Freeview box, I'm plugged into SCART port 2 (bottom most port on right hand side of machine as you look at it from the front). Use your remote to change the channel to A2 with the <CH> rocker button just above the video+ button on the controller. This will then record whatever channel your freeview box is set to - the only pain is you can't watch a separate channel whilste recording.
Kind Regards
Brad
Apr 01, 2008 | Panasonic DMR-ES10 DVD Recorder
Samson G-track
It's supposed to only record on the left side. When it's in "INST/MIC" mode the left channel has your mic on it and the right channel has your instrument, so you can mix them separately. Just configure your recording software to put the left channel on one track and the right channel on another track.
Jan 10, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
ION Audio ION PROFLASH LP USBPLATTENSPIELER Turntable Logo
74 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Jose Ma DM.
Jose Ma DM.
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
