Question about Sharp EL-2630P Calculator
Printing too light to read
I put in a new ribbon, but the digits still print to light to read.
3 Suggested Answers
  • 50269 Answers
SOURCE: No answer on why or how to correct light print on tape from Sharp EL 1197piii. Ribbon is new, just changed. Help!!!
Try another new tape . they do go bad in the package at times
Posted on Sep 18, 2015
  • 108 Answers
My first thought is that the numbers being "hammered" against the paper are not reaching far enough. Test this theory by putting two layers of paper into the paper feed, (Fold the end of the roll over onto itself) and try printing again. It could be designed for a thicker paper.
Alternatively the new ribbon may also have dried out. Rub the ink ribbon with a paper, or pencil eraser and see if the ink readily comes off, perhaps use a pencil eraser to press it against the paper being fed through the machine.
These are diagnostics to find the error. Further investigation might be to see if there is any particles in the machine preventing it from hammering the numbers against the paper. Something might be in the way of the moving parts, something about the size of a paper hole punch paper, or pencil shaving. Shaking it vigorously upside down might solve this problem.
Good luck ;)
Posted on May 17, 2016
I cannot get the calculator canon MP121-DH to print on the paper roll. Any suggestions
This paper will only print on one side. Try flipping the roll over so that it tries to print on the opposite side.
Oct 29, 2014 | Office Equipment & Supplies
Why does my Canon MP49D calculator print light?
Could it be you are using old ribbons? Are you using the correct ribbons?
did you put in the ribbon correct and is the ribbon transported, while it is printing, or is it stuck in the calculator. Just some questions to check out.
May 06, 2014 | Canon Office Equipment & Supplies
Print is very light and I put in a new ribbon. This printer is hooked to a parallel port on an AVAYA phone system terminal. I don't believe there is an option to download drivers. Not sure why the new...
Hi
Check if the ribbon is seating correctly, the Avaya PBX does not have a driver for this that is correct also some printers have a "draft"setting make sure this is off as the printer will only go once over the print in draft
Sep 29, 2009 | Panasonic KX-P2130 24-Pin Impact Printer
Put new ribbon cartridge in ibm wheelwriter 3 not printing now
If the ribbon is lifting up you probably have a cracked print solenoid plunger cap. They are available but a little tricky to install.
DickyO
Feb 10, 2009 | IBM Wheelwriter 30 Typewriter
Can hardly read print after putting on new ribbon
You have to make a platen adjustment (on the left side move it back).
Jan 23, 2009 | IBM 4247 A00 Matrix Printer
Bad print out
I would recomend checking the ribbon cartride fitted in the pritner. Ensure the ribbon is correctly mounted on the ribbon drive shaft.
Ensure the ribbon is not jammed.
Ensure the print head gap is not set to close the ribbon is becomming jammed
Try changing the ribbon cartridge for a new one.
Dec 30, 2008 | TallyGenicom 2348 24WIRE 480CPS Draft 136...
My print out cat read some line very light and some line very dark priner is tally genicom 2348
I would recomend the following;
  1. Check the ribbon is seated correctly in the printer
  2. Check the ribbon is not jammed or tight to move
  3. Check the print head gap, ensure this is not trapping the ribbon
  4. Change the ribbon for a new one
  5. Check the ribbon drive is ok
Fax copies come in too light to read
I don't want to be 1 of them to say is it a generic ribbon. Ribbon transfer fax's are touch ie on melting the print on the ribbon on to the paper. tried selling the ginaric ribbons did not work well.
If it is a brother ribbon then the blue latch levers my be creaked if the print is only on 1 1/2 of the paper.
hope this helps
Dec 08, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
New ctg. change problems
In the printing preferences there is an auto detect ribbon button . you should select it.
Your ribbon will be updated. Also if printer asks you if the ribbon is correct select yes. The printer will then print on whatever ribbon you have intalled. This doesnt work with test prints
Dec 26, 2007 | Fargo Persona C30 Thermal Card Printer
Sharp EL-2630P Calculator Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
