Question about RCA Lands Phones
Is there a reset button on rca - RCA Lands Phones
Rca 10.1 tablet rct6303w87dk with 5.0 lollipop. How do I factory hard reset?
Follow the detailed instructions below on how to completely reset your RCA Android 5.0 tablet.
Applicable models: RCT6773W22B, RCT6203W46KC, RCT6213W87DK and RCT6303W87DK
Step 1. With your tablet off, press and hold the volume up (+) button and power button until you see the RCA splash screen with Nipper and Chipper. Release both buttons to reveal the Android bot on his back with a caution symbol above him.
Step 2. A new screen will appear asking you to use your volume up/down keys to move and the power button to select.
Step 3. Use the volume down (-) button to highlight "wipe data/factory reset." Once highlighted, select using the power button.
Step 4. A new screen will appear asking you to confirm your selection. Use your volume down (-) button to highlight "Yes -- delete all user data." Press the power button to select once highlighted.
Step 5. Once the tablet is finished wiping data, you may press the power button to select "reboot system now." This will restart your tablet.
Step 6. The system will begin to reboot and once again display the RCA logo with Nipper and Chipper. The next "Welcome" screen will prompt you to select your language of choice. Scroll through the options using your finger and press start when finished. Congratulations, you have successfully reset your RCA 7 Voyager tablet.
How to completely reset your RCA Android 5 0 tablet
Nov 19, 2015 | Tablets & eReaders
Rca RCA model 20F514TD
You need to reset it give me 2 mins I will post the solution here
Mar 28, 2008 | Televison & Video
I boughr my daughter a rca tablet model rct6773w22 she put a pattern lock on it and.dont remember what the.pattern to unlock.it is how.do.i reset it so it can be.used
you dont,thats why you write down those patterns,now you have to hard reset and lose your info,but,here ya go,
Follow the detailed instructions below on how to completely reset your RCA Android 7 Voyager (RCT6773W22) tablet.
Apr 27, 2015 | Tablets & eReaders
RCA 7 inch table says no command
You may have to reset it. let if charge for about 24hrs, 10hrs may work fine too and With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset.
Mar 03, 2014 | RCA 7 DUAL TABLET DVD SYSTEM
I need to reset my password on my rca HD52W55
Hello
If your RCA tv has locked or you want to reset your password you can opt any one of the followinf option to unlock it without any passcode nd can reset it after.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won
May 06, 2011 | RCA Televison & Video
Where is the reset button on an rca model#p46924 46" projection screen tv?
Hello
Reset button is on its remote control itsef. You can locate it at the bottom right side. Point it towards TV, and reset the setting you want to. OK.
Apr 22, 2011 | RCA P46924 46" Rear Projection Television
I can`t find the reset button on my rca opal m4001 mp3 player
Some models have reset switches some do not.
Look on the back of your mp3 there should be a tiny hole there.
That is the reset switch for most opal. Other way to reset is hold power button down for 15 seconds.
If you cant find it you will have to go to the RCA website and download the latest firmware.
Jan 11, 2009 | RCA OPAL M4001 MP3 Player
Reset button
Use Windows Media Player to delete the songs you do not like - resetting will not delete your unwanted files.
-Tha Mp3 Doctor
Dec 24, 2008 | RCA OPAL M4001 MP3 Player
Rca hd56w66
reset? i know of no reset button on this set what are you trying to reset... whats your complaint on your set. I repair about 10 of these a week at the shop. so let me know if i can talk you through it. leaveing the set unpluged for 30 minutes is standard reset
Sep 05, 2008 | RCA HD56W66 56" HDTV
Rca rp5640 unresponsive buttons
I have the same problem. Not much luck finding help at rca. Will keep looking.
Feb 25, 2008 | RCA CD Player/Clock Radio (RP5640)
Lands Phones Logo
21 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
