Question about Samsung Refrigerators
Water slow out of fridge
Filtered water dispencer
the dr
  • 447 Answers
SOURCE: maytag mfd2561 water dispencer and ice maker issues
Most likely it is the High Voltage Control board located in the unit compartment (take off the back cover where the water lines are) i have had lots of them failing and doing all kinds of odd things, so far it has been that computer. Part number 12002608
Posted on Sep 29, 2007
catriver
  • 878 Answers
SOURCE: Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
  • 219 Answers
SOURCE: amana fridge water dispenser real slow
u m,ay have to change the filter tubing as well
Posted on Mar 19, 2009
SOURCE: water running slow out of fridge
i had that problem
so when we called the repair guy
he went in back uncloged some hose part that pulled out,also he cleaned dust inbetween the tin plates under the front bottom ,sort of look like the tin things around a pipe in oil baseboard heating systems
Posted on Jul 19, 2009
  • 53 Answers
SOURCE: water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Posted on Jun 18, 2010
Water dispencer from inside fridge isnt dispencing water. makes noise like it wants to but wont. can my water line be frozen? my fridge is usualy pretty bare and the temp is on 6.
It is very common for the water dispensing tube to become frozen if there is a slow drip coming from the water fill solenoid in the back of the refrigerator.
May 29, 2011 | Refrigerators
ED25DWXTN01 AFTER DISCONNECTING AND MOVING TO A NEW LOCATION I CANNOT GET WATER FROM DISPENSOR OR WATER UP TO THE ICE MAKER IS THERE A WAY TO BLEED THE SYSTEM?
In effect the only thing different is you moved the fridge and switched the water off. Make sure the water is getting to the fridge pipes connected to the fridge valves.(normally blue in colour.). If not rectify problem. If water is there, suggest you remove water filter in the fridge compartment and by pressing the water dispencer button see if water runs out at the filter adaptor. If not, there is an issue with the solonoid valve/s (very unlikely thougf) Could very possibly be the water is frozen and needs defrosting. Because there are variables that i havent been given, im surmising a lot. Normally when you depress any of the dispencing buttons,a clicking sound will be heard from the solonoids at the back. Simply the water should flow up the pipe to the filter then to the dispencer outlets. Most of the time, the water is either off or filter is blocked or limit switches at dispenser end is faulty. Very unlikely that both are defective at once so check the filter and water supply. If stuck, email me on terfou@imaginet.co.za
Sep 03, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have water running to the fridge and contact at dispencer by I cannot get water to ice maker or dispencer
Look on the backside of the fridge for a small shutoff valve which may be turned off. Also, if your fridge has provisions for a filter, check for a clogged or missing filter. In either case, you will have to replace the filter.
Jun 11, 2010 | Frigidaire PLHS267ZA Side by Side...
Water dribbling out of dispencer whirlpool american fridgefreezer
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
May 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
How to increase the water flow from water dispencer on a FLSC238DSO when getting water it takes for ever to fill a glass
If your fridge has a water filter, you should change it every 3 months. An old filter can cause slow flow problems.
But it will never come out as fast as the kitchen sink. Depending on the location of your fridge, you have 10 to 25 feet of 1/4" pipe between your water glass and the high-flow plumbing, and water just won't move very fast through that.
Sep 16, 2009 | Refrigerators
Kitchenaid fridge (ksrw25crss02)icemaker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispencer.
hi kev215,
welcome to fixya.com.
Huuum at your service.
You said, the ice maker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispenser.
The first thing I would ask is when did you last change your water filter in the fridge?
Or if it's an older fridge with an inline filter behind the fridge!
check the shut off valve for the water line that leads to you ice maker. under the sink or in the basement or where ever the line comes from. I've seen where someone turned the valve a little clockwise unbeknown to the home owner and stopped or slowed the water flow.
The water line should be checked too, for any kinking that may be running behind the fridge or some unseen place!
How old is the fridge??
Let me know,
Thank you Huuum
Sep 23, 2008 | KitchenAid Refrigerators
Icemaker and water dispenser not working GE GSS25JFPA stopped working and i thought it was water filters (have not changed in 4 years changed the internal filter and a aux one in basement in line no...
generic troubleshooting video: http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
as the video shows a kinked line may be the culprit. or
if your ice maker is making ice and it is your ice dispencer that is not working along with your water dispencer and when you press the dispencer button the light dims on the door. I would replace the main board. I experienced the same problem and the board fixed it This board is shared by many models and brands of fridges and the transformer goes bad from power surges this board powers the solenoid valves that open for your water
Apr 03, 2008 | Refrigerators
Maytag MFD2561HES
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Maytag mfd2561 water dispencer and ice maker issues
Refrigerators Logo
12 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
