Question about Sega Dreamcast Console
PROTEO25967 OVERLOAD IN MI SEGA DREAMCAST
  • 152 Answers
I need you to explain more about your problem. Explain how your Sega Dreamcast is behaving. I'll be more than glad to help you.
Posted on Nov 07, 2007
I was given a sega dreamcast everything works but when it says install disc i put the disc on the wheel close the door and the cd wont stay on the wheel
If I recall the Sega Dreamcast wheel is a clasp type wheel. You need to push the disk down onto the wheel and you will hear it secure itself onto the wheel. Then close the wheel and you should be good to go. Don't just place it on the wheel... push it down until you here that little clicking sound and it should stay on the wheel.
Aug 10, 2011 | Sega Dreamcast Console
Hi, my sega dreamcast console won't spin disc, please help!
try this youtube guide here http://www.youtube.com/watch?v=3rizeLEQyzs&feature=related, during the video the person will talk about a black plastic leave that gets pushed back by the dreamcast lid. if that lever is not being pushed back the drive will not spin. you can try the suggestion in the guide also.
Hope this helps,
Omeil
Oct 23, 2010 | Sega Dreamcast Console
My control wont work
did you tested another dreamcast control...you had the same problem...so you have to check the protection Fusistor inside your dreamcast conector controller board....it seems like a blue or green normal resistor...marked as F1 on the board..change it with a simple fuse or an smd fusistor...Good Luck!
Nov 23, 2009 | Sega Dreamcast Console
When i am in the middle of playing a game on my Sega Dreamcast it will cut out on me sometimes and go to the Dreamcast menu,with the controller and music stuff in background and then it tries to reload the...
Your Dreamcast sounds like it's overheating.
I had the same thing, and the cooling fan was worn out and needed to be replaced. I did this, and now it works like a charm.
Apr 14, 2009 | Sega Dreamcast Console
Freezing problem with Games
The Dreamcast is no longer supported because it was to easy to copy the games, but there are still a loyal few who keep the scene alive. I have no idea how much you want to put into fixing the problem, but the only way to fix your problem is flashing the Dreamcast BIOS.
Modification 101:
http://www.youtube.com/watch?v=v7v8cEU1I50
The Dreamcast is basically a computer; with the right programming you can do anything; and having a Dreamcast Keyboard is nice.
Other links you should check out...
DreamChip and 4 in 1 Connector
Another Dreamcast Mod Chip
The Ultimate Dreamcast Survival Guide
Sega Dreamcast VGA Mod
Modified Dreamcast BIOS
www.dc-scene.net
Nov 27, 2008 | Sega Dreamcast Console
Sega Dreamcast console problem
First off, NEVER store a game console on top of a subwoofer. It is like a giant magnet, and electronic devices do not handle magnetics. I don't think i've ever heard of a VGA box, Sega brand or not, killing a console. Millions use aftermarket AV cables and adaptors on all consoles without problem. I think it likely died from being on top of the sub. Relocate it and you should be fine. Running it for a few hours isnt likely either unless you had the vents entirely blocked.
To the guest who's drive isnt spinning, I would say your drive motor has burnt out. This doesn't indicate a defect in Dreamcasts, per se, it just means bad luck or excessive dust which killed it. Either buy a different Dreamcast or see if you can find a drive replacement.
Hope this helps.
Feb 28, 2008 | Sega Dreamcast Console
Dreamcast Loading problem
you can get disks relayered at game stores.
there was a long period where this happened to me.
some games worked for a while, some didnt.
its the dreamcast.
you might wanna get anew power cable or just clear out the dust because that is the main problem with the dreamcast.
try playing with the console upside down
it sounds crazy but it worked for me.
Dec 18, 2007 | Sega Dreamcast Console
Sega Dreamcast screw
The Disc drive has a connector on the bottom that has to mate up with the opposite gender connector on the top of the motherboard. you have to press the Drive down first then put the screws in.
Nov 06, 2007 | Sega Dreamcast Console
Sega Dreamcast Disk-reading piece
cripes I think you may have mixed your screws up?
1 it sounds like you are using a self tapping screw (it has a greater distance between each layer) rather than the tight screws which are for fitting the circuits together.
2 I believe there are three screw holes for the disc reading part of the dreamcast and you really only need two to keep the disc player in place, so also try another hole.
3 and one last thing to check you haven't put a screw underneath the board already?
Sega Dreamcast Console Logo
75 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
