Question about Canon PIXMA iP2000 InkJet Printer
Print head not working
Print head not being found
Printing blank pages
Hi, it might be the laser head is faulty or hvps is faulty. Try do an test print from the printer by press and hold the buttun for 5 sec or so. If it doesn't print. Try to clean the laser head which is able to be found under the printer with 3 screw. Do not power on the printer and look at the laser head this might cause blindness. After clean place back the laser head and test print. If same issue, try with a new sets of toner. If this still don't work you have to engage an technicians to either replace the laser head or hvps.
Oct 13, 2013 | Samsung CLP320 AllInOne Laser Printer
Are the ink cartridges just a few copies, I have new copier and print is very faint
You need to clean the print head and insert the cartridge and check, whether it is working at fine because a dirty printer header will not allow the right formulation of the basic cyan, magenta, and yellow to print and comes up with the yellow color and not red.
If you still face the problem after cleaning print head then you need to check for a clogged nozzle. Clean the nozzle and then try printing it will work fine now.
To clean the print head from the Utility section found in the printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. Furthermore, you can clean the print head by Using a cotton Q-Tip & Isopropyl Alcohol and gently rub the print head with alcohol.
Hope this helps.
If you still have any queries, please feel free to ask us.
Shane
Mar 03, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
My canon i560 printer won't print. I get an error message. The error message says to cancel print and press the resume button. This doesn't work. The yellow light is blinking 5 times then the green...
I got the same problem. I researched and found out it's the print head, you know the thing that moves side to side that releases the ink onto the paper. You either have to replace the print head( which costs around $50.00) or buy a print head cleaning kit because it might have dried ink in it. Hope this works for you( the kit didn't work for me, had to get a new print head)
Jan 21, 2011 | Canon BubbleJet i560 InkJet Printer
I have an Epson Artisan 800 Printer with a bad print head. This print head is beyond any more attempts at cleaning it and I would like to find out where I could find a replacement. I have found that this...
ihave found a solution that you only have to insert vinaigar...? alcool in the ink line wait about 30 to 60 min and it's done.
Some cies sold cleaner for printing heads
Louis
Aug 24, 2010 | Epson Artisan 800 All-In-One InkJet...
BJC-85 Not printing. New BC-10 and BCI-10. Paper loads normally
The problem you are having is with the print head and not the printer. Unfortunately, with these canon print heads, they are not dated, so it is possible to install a print head that was bought new and sealed, but is still dried out because it is old.
Try running the print head through one deep cleaning cycle, this sometimes will start to get an old print head flowing.
Deep cleaning cycle can be found by going to PRINTERS , right clicking on the BJC icon, selecting PROPERTIES from the drop down menu, and then selecting the MAINTAINENCE tab.
Check to make sure that the ink tank in the print head isn't dry. Even a new print head can have a dry tank if it's old.
Jan 10, 2010 | Canon BJC-85 InkJet Printer
Canon MP360 not printing
You probably need a new purge assembly, it draws some ink to both clean and prime the printhead. When it stops working you won't get any ink to the paper.
Jul 19, 2009 | Canon SmartBase MP360 All-In-One InkJet...
After being abroad for 3 months i can home to find printer not printing correctly i replaced the 5 ink cartridges but only 2 working Black and cyan
The ink has dried in the print head. If the print head comes out, remove it and apply rubbing alcohol or water with a paper towel to the nozels to disolve the ink. Once the ink seems to be fluid, replace the print head and ink cartridges, do a head cleaning and try printing again.
If the print head cannot be removed, get a childs medicine syringe, draw in some rubbing alcohol. Remove the non printing carts and apply a couple of small drops of alcohol to each ink port on the print head. apply some more drops to the ink port of the carts and replace and try a head cleaning and print.
If this does not work, continue to ask for help. The aim is to save the print head, not buy a new printer.
May 29, 2009 | Brother DCP 115C All-In-One InkJet Printer
My Canon mp390 printer doesn't print
I had this problem several times, had to buy new print head until I found that to clean it you should use ammonia. It really worked for me. You should really try ammonia it does work.
Apr 22, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Canon ip5000 won't print black
try taking the cartridge out and cleaning it then replace it after that unplug it for a couple minutes and then plug it back in and let me know what happens
Jan 17, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Ink cartridges are full, won't print in red, other colors work
Head wasn't clean, I found an old soft toothbrush, sprayed it lightly with windex and brushed lightly.
Prints great now.
Dec 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA iP2000 InkJet Printer Logo
old marine
old marine
