Question about Canon PIXMA MP210 Photo All-In-One Printer
My mp210 printer runs through the motions of printing while making a whining sound but only churns out blank pages .. I have unplugged and restarted everythingng with windows 7
It is set as my default printer I am using an Hp laptop and have encountered this problem before but have eventually made it work somehow
Nicolomd
  • 84 Answers
SOURCE: my printer go thru the motions of printing a doc but comes out blank,( it will print internet stuff)
tried to check printing connecting at another computer (not networking)? icq 475653626
Posted on Jan 04, 2008
  • 103 Answers
SOURCE: blank pages coming out of i850 with new printhead
Alarm / Power light flashes orange 7 times consecutively is a Print head error so it sounds like you did the right thing.
I would reseat the printhead along with each one of the ink cartridges. Make sure that you removed the tape from the bottom of each of the ink cartridges and try it again. After installing the new printhead, you should have run a printhead cleaning cycle immediately after installing.
Issue: Certain colors are missing or no ink prints on the paper
Solution: Install / replace the recommended ink tanks correctly i550 / i850
Untitled Document How to install / replace the ink tanks
The ink tanks suitable for the printer are as follows;
Black Ink Tank BCI-3eBK
Cyan Ink Tank BCI-3eC
Magenta Ink Tank BCI-3eM
Yellow Ink Tank BCI-3eY
Note: There are two ink tank label designs.
Operation procedures are shown with label design A.
labelsa.jpg Replacement Procedure
1. Check that the printer is powered on, and open the front cover. Wait until the print head moves to the center.
2. Remove the empty ink tank by pushing the tab on the ink tank.
Note: When doing this, do not remove the print head. When replacing multiple ink tanks, it is recommended to replace one at a time to avoid inserting them into the wrong slots.
(The image is an example using i850.)
3. Remove the new ink tank from its package. Pull the orange tape in the direction of the arrow to remove it completely, and remove the shrink-wrap film.
Note: Remove the orange tape completely. If the tape remains, printing may not be performed properly.
Confirm that the orange tape is completely removed from the ink tank, as shown in image 1. If the tape is similar to the sample in image 2, remove the remaining portion of the tape so that it looks like the sample shown in image 1.
(1): Correct
(2): Incorrect (where the arrow indicates)
4. Slowly twist the orange protective cap in the direction that the arrow indicates, and remove it. To avoid ink adhering to your fingers, brace the orange protective cap while removing it.
5. Insert the new ink tank to the print head by holding it at a slight angle.
Note: Confirm that the ink tanks are installed in the right order according to the labels on the print head.
6. Press down on the top of the ink tank until a click sound is made.
7. Close the front cover. The next time the printer performs printing, it will automatically start print head cleaning. The power lamp will flash while cleaning is performed. Until cleaning completes, do not perform other operations.
Posted on May 07, 2008
SOURCE: Canon MP210 with Mac OS X 10.4.11 problems with printing docs
Hi
I have OS-X 10.4.11 and had the same issue; any printing just spat out blank pages.
I installed the following driver which completely resolved the issue:
http://software.canon-europe.com/software/0029270.asp?model=
There's a similar one for 10.5 that I haven't tested, to be found here:
http://software.canon-europe.com/software/0028432.asp?model=
If you use 10.5 and this driver works for you, please let others know by posting here, too.
Good Luck
Draqul
Posted on Dec 22, 2008
  • 214 Answers
SOURCE: Print Head Alignment test produces only a blank page.
Yes head probably clogged. You can try cleaning head multiple times, I think this is a pigment ink machine, so get only these carts for it
Posted on Apr 25, 2009
SOURCE: Printing gives only blank pages...
Maybe you need performance a preventive maintenance if you know how great, if not you can call a Printer tech in your area.
Posted on May 27, 2009
My printer stopped printing? Canon Pixma 210 New
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator (You should be in this command C:\WINDOWS\SYSTEM32- If not type this command when you in the dos command prompt "CHDIR C:\WINDOWS\SYSTEMS32\ and press enter")
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
I hope it helps you
Apr 20, 2011 | Canon PIXMA MP210 InkJet Printer
Unit makes every noise and motion as if printing, but pages blank
First thing is if you haven't printed for while the ink may have dried in the print head. Run it through a few (lots) of print cycles and see if that starts to bring it back to life.
Check to make sure that you have the paper thickness set close enough.
My bet would be on the print head being clogged.
Apr 05, 2010 | Epson Stylus Color 740 InkJet Printer
My Dell 924 printer is printing blank pages
" Unplug the printer cable from the computer.
" Unistall the printer drivers from Device manager and also unistall the all the printer appications
" restart the computer
" try to download drivers from the website
" after installing drivers and software it will ask you to connect the printer.
" then you can connect the printer and and try to Print the test page.
Thanks
Thiru
Jun 17, 2009 | Dell 924 All-in-One InkJet Printer
Epson 9800 is printing blank paper
Sounds like a head issue. May need replaceing
Jun 05, 2009 | Epson Stylus Pro 9800 InkJet Printer
HP color laser 2550L prints only in yellow
Hi Mmgrafde,
Press the Go and Rotate Carousel buttons simultaneously. This will calibrate the printer. See if this works.
Otherwise....Remove all cartridges and drum. Switch off printer. Close the lid. Switch on printer and wait until any churning stops. Insert the drum and close the lid. Wait until any churning stops. Put in one cartridge at a time, closing the lid and wait till it stops churning each time. With the last cartridge put in, it will churning longer (calibrating). Try to print from your computer.
It could also be that the toner could actually have run out for the other colors.
Rgds
S88
Jan 01, 2009 | HP Color LaserJet 2600n Printer
Hi
Good Luck
Draqul
Nov 02, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Wont print
Replace Catridge and then Check.
Jun 17, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Printer keeps printing blanks...
We have found a reset that we use.
We unplug the printer and then we hold down the feed button and we keep holding down the feed button while we plug back in.
It goes through some sort of a reset and this sometimes works.
Jan 23, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
13 people viewed this question
old marine
old marine
