Question about Nilfisk Vacuums
Nilfisk bravo hepa 2000 red light on and bag is not full
Red light on and bag is not full
5 Suggested Answers
SOURCE: When vacuuming dust does not go into bag but goes all over the place.
Used an elastic band to tighten bag onto nozzel.
Posted on Sep 28, 2008
  • 430 Answers
SOURCE: Nilfisk Family Vacuum - Strong Awful Odor
Not sure what a bacteria smell is perhaps you mean a mildew type smell.
If you have picked up something wet, start at the front of the vac and work your way to the exhaust.Change the front most filter first. Baking soda may help to eliminate some of the odor.
Personally as an allergy suffer, which you may be given the Brand I would remove all and let them and the tank air outside. Meanwhile install a fresh set.
Posted on Sep 13, 2009
#1 Taper
  • 1040 Answers
SOURCE: Need directions on how to remove old cotton filter
This link should help:
http://www.fixya.com/search.aspx?cstm=0&_s=Nilfisk+GM%2FGS+80+instruction+manual
Jim
Posted on Dec 03, 2009
  • 389 Answers
SOURCE: red when bag is not full
The red light will also come on when there is a blockage in the pipes leading to the bag compartment. To test that the light is working correctly, you can unplug the flexible hose from the top of the bag compartment then switch the machine on. The red light should be off, but will come on if you block the hole with your hand. If that test shows the light is working, you need to search for a blockage - which is most likely to be in the flexible hose, but can be in the rigid plastic tube or in the base of the machine (turn it over and look in the little trap-door). Clearing a blockage from the hose can be difficult - you are more likely to be successful if you can devise a way to pull it out rather than trying to push it (as with a broom handle, for example), because pushing may just compact it. Good luck!
Posted on Apr 03, 2010
Why is red light on my Nilfisk Orbit vacuum cleaner on ?
[PDF]Nilfisk GM80 and GM80i Vacuum Cleaner User Manual ...
www.sylvane.com/media/.../nilfisk-gm80-vacuum-cleaner-user-manual.p...
Troubleshooting. Loss of Power. 5. 6 ... CAUTION: This Nilfisk vacuum cleaner or any other vacuum cleaner is not to be used in explosion-hazardous areas, as ..
Sep 19, 2015 | Nilfisk Vacuums
What is the right bag for sebo x4
  1. First, pull out the hose, turn the unit on, check for an obstruction in the hose. (unclog and obstruction)
  2. Separate the body from power nozzle. Check for obstruction in the air hole passage.
  3. Pull and clean both filters in the unit. The inside white long carriage and the exhaust filter located above indicator panel. (nozzle body)
  4. If this is not working. think about where and how dirt is carried or passes from the front floor nozzle or through the hose.Somewhere in the unit the it is clogged. The red light censers a full bag (we know that's not the issue) or an obstruction to the normal air flow.
  5. Last Resort contact http://www.sebo.us/contact_us.aspx
  6. In closing: I've been selling and repairing vacuums for over 30 years. Of all the 5 major brands that I sell. Sebo is by far the, best product on the market.
Aug 23, 2014 | Sebo X4 Bagged Upright Vacuum
Looking for details for fitting dust bag in nilfisk king hoover
Hi There, I have made a quick video showing how to check the filters and also how to change the Nilfisk King Vacuum Bag. Take a look and you should be able to work it out.
Aug 30, 2011 | Nilfisk GDF2040 Vacuum
How do you change the dust bag on the Nilfisk King 505?
Press the middle rectangular Nilfisk button in the top centre of the machine. The front cover will fold down. There is a greay retaining bracket which clips forward off the top of the old bag. Fold that forward, replace the bag, clip the holder back on, and then close the lid.
May 20, 2010 | Vacuums
Will not suction Checked Hepa filter, hose, and removed brush pan/cover.
How full is the bag? If equipped with a light, did your full bag light come on?
Feb 06, 2010 | Vacuums
I took the filter assembly apart, now I can't get it back together. There's a silver medal ring, a big cotton back, an inner plastic seal and an outer plastic seal. Somehow, they all fit back together....
The cotton bag wraps around the hepa filter - the blue plastic part will not be visible once the bag is in place. The silver ring sits inside the cotton bag to hold the sides of the bag against the sides of the vacuum top-half. DON'T pull the plastic inner seal and outer seal apart. They snap together and snap onto the lip of the vacuum top-half. It's a bit of a struggle snapping the seal back onto the lip.
Jan 11, 2010 | Vacuums
Need directions on how to remove old cotton filter and install new one and same for HEPA filter on Nilfisk GM/GS 80.
Jim
Dec 03, 2009 | Nilfisk Family Vac Bagged Canister Vacuum
Sep 13, 2009 | Nilfisk Family Vac Bagged Canister Vacuum
When turned on the sound is like its screaming. It appears to be coming from the filter compartment. It all seems to work ok.Thanks
I suggest checking the filter. If it's coming from the HEPA filter area, the filter might be out of position or possibly you have the wrong kind of filter. Miele uses 2 different types of HEPA filter so that could be the problem.
Aug 23, 2009 | Miele Cat Dog Plus S511 Bagged Canister...
Sep 27, 2008 | Nilfisk Vacuums
Vacuums Logo
102 people viewed this question
Top Nilfisk Vacuums Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Thatvacguy.com
Are you a Nilfisk Vacuum Expert? Answer questions, earn points and help others
