Set color on my LCD TV/monitor
I connected my LCD TV to my PC to use as a monitor.  It is a Citizen LT2010 20" TV.  It is working but it has a black and white screen color.  How can I change it to color?
Thanks,
A. Turmon
  • 1 more comment
  • kathienew Mar 31, 2008
    same problem?
  • Anonymous Jul 19, 2008
    Using Motorola DVR with same problemd
  • mikespqr Nov 13, 2008
    when i hook my satalite or my Xbox 360 to my component 2 hook ups on the back of my TV i get no color on the screen, it is black and white, but when I hooked them up to the Component 1 hook ups I have color. Is there something wrong with my Component 2 hook ups?
I have a lg lcd.
and it colour scheme is very high
please give me suggestion for his colour setting
Posted on Dec 16, 2008
My Hyundai tv 74 cm The color it not show good
Nice big screen but CRTs are getting old So, if you can't set correct colors with your Hyundai it might have some serious issue with tube. Probably replacement might cost you more then a new new 27" Flat Panel. See some tutorial and info about bad color of CRT
Fix your own CRT Television Color Problem
How To Diagnose Bad CRT or LCD Monitor
http://www.electronicrepairguide.com/monitor-color-problem.html
LG M2762D 27 Inch Widescreen 1080p LCD TV Monitor Black
LG Electronics LG M2762D 27 FLATRON LCD TV widescreen 1080p FullHD HDTV...
RCA F27440 27 CRT TV
Samsung TXN 2798HF 27 Tantus CRT TV 1080i
Aug 02, 2015 | Televison & Video
My 42 inch tv when it turns on half is black then color lines show up and down then I'll just tap it slow on top and picture comes on like something is loose inside some times it doesn't work
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Feb 04, 2015 | Televison & Video
Why my screen says please wait then goes black
- Flickering screen
- Dim screen
- Slow start
May 05, 2014 | Dynex DX-LCD32-09 LCD TV
Black cloud like fogged on Sharp Aquos 37"tv
- Flickering screen
- Dim screen
- Slow start
Apr 13, 2014 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Screen is too dark and unreadable fix it
The screen on what make and model device?
Jul 10, 2013 | Computers & Internet
My monitor's color is messed up, when i start the computer all the icons and background are colored normally, after a few seconds it all goes to just about black and white. im sure it has to be settings of...
your monitor's backlite circuit board is gone, it's not able to sustain the signal from the PC
change the monitor and checkm else connect the faulty monitor to another PC and check.
because if it's settings, then the setting reside inside the HD of the PC, so if you change PC then the monitor should pick up the setting from the new PC and vice versa.
Dec 06, 2009 | Sony SDM M81 18.1" LCD Monitor
LCD Monitor pixels that should be black are white
The contrast of the monitor is very low. reset the monitor settings using the menu button in the monitor.
Apr 17, 2017 | Sony STYLEPRO SDM-S71R/B (Black) 17" LCD...
Monitor black with green light on
did you changed frequency of that monitor? if it is out of factory setting that could be the problem, try to connect it again as secondary and set Hz to default, if that does n't work try same settings on both monitors? i have connected two monitors i had same problems , my secondary monitor was clone for tv if you are using secondary monitor for clone to ty (with s-video or whateever) if tv is old it must be 60HZ 800x600...
Apr 27, 2009 | Computers & Internet
Have a Synkmaster 510n with problem
Confirm this is a monitor problem by connecting toanother working Pc.Also try starting in safe mode and see if you get stable image.If in safe mode you get image your image settings may need to be readjusted.
Samir
Mar 07, 2008 | Samsung 510N 15" Flat Panel LCD Monitor
Televison & Video Logo
701 people viewed this question
Top Televison & Video Experts
