Question about PfaFF Creative 7570
How to replace the threader on the 7570 - PfaFF Creative 7570
Needle threader won't work on my Singer 4423
The needle threader hook is very tiny and easily bent or damaged.
The needle threader is designed not to turn, if the needle is not at its most upper position to protect the threader - Turn hand wheel until needle reaches its highest position.
Needle not alining with threader hook - Replace needle.
Threader hook bent - Replace with new needle threader hook.
Hope this helps.
Read more from the link I attatched.
Good luck & have a nice day!
Automatic needle threader will not work
Jul 14, 2017 | Singer Sewing Machines
Needle threader on 830 operates but will not let go of thread
1. Try a high quality thread; usually embroidery. Your thread sounds like Walmart. Look at it at a light and see if there is fuzz. That's bad thread.
If this doesn't work you have a threader that is bent out of shape causing it to hang on. You can attempt to adjust the threader with small pair of needle nose pliers, maybe even tweezers. Careful, it is fragile. The cost of replacement and a repairman will be over $ 50 so it is worth the try at home.
Oct 05, 2016 | Sewing Machines
I need an automatic needle threader for a Brother NS30 Le
Fixya does not sell replacement needle threaders.
Aug 05, 2016 | Brother Sewing Machines
Auto threader wont thread
Move the needle to the top.
Loosen the screw on the threader.
Use the threader as if you are using it. You will have to adjust it to the side and up or down. Move it so the threader is in the needle hole.
Tighten the needle.
If it still doesn't work you may need to replace the threader.
Apr 18, 2015 | Sewing Machines
Automatic threader doesn't work
The automatic needle threader is very tiny and easily bent or damaged; however, it is designed not to turn if needle is not at its most upper position to protect the threader. Turn the hand wheel until the needle is at the highest position. If the needle is not aligning with the threader hook, you will need to replace it. And you can replace the needle threader hook if it is bent. I hope this helps!Jimmy
Mar 27, 2012 | Brother Sewing Machines
Janome 1860 needle threader
If the hook is bent, you might be able to straighten it, but I would go to my dealer and purchase a new threader. It is much easier to replace it.
Feb 06, 2012 | Janome Sewing Machines
Bernina virtuosa 155 solutions
Needle threader heads are actually easily replaced and should be replaced anyway every few years because they do wear-out. Get a magnifying glass and, having returned the needle to the top (use the foot controller, so that the machine stops it in the right place), pull the needle threader down until the head rotates towards the needle. Look with the magnifying glass to see if the small hooked part in the centre of the threader head (the light grey plastic part) goes through the eye of the needle - if not, you might be able to bend it VERY carefully so that it does - that should cure it. If the hook is a long way above or below the needle eye, dont try and bend it, the cam that rotates the threader has probably moved on the needle bar and will need adjustment by a service agent. If the hook is passing through the eye of the needle OK, but still not pulling the thread back through when you release it - i.e. the thread is just slipping-off, the hook has become rounded through normal wear and you'll have to replace the threader head. The threader head simply pulls off - you might need to carefully lever it off the round shaft. Replacing it is a matter of simply putting the new one on the shaft and pressing upwards firmly so that the grooves in the threader head go right up to the horizontal pin on the threader shaft.
Dec 12, 2011 | Bernina Virtuosa 160
I recently replaced the bobbin threader on my machine. When embroidering the bobbin binds causing the material to rip.
Hi Linda, if you mean the bobbin holder, sounds like the tension is too tight. Look in your manual for which screw to adjust, just turn it half a turn to the left, holding the bobbin case as it sits in the machine. Try stitching again, sorry no quick way to do this, normally they are factory set at the correct tension. If that doesn't work, only turn screw quarter of a turn, stitch again. If tthis doesn't work, I would check with your supplier that it is the correct part. The golden rule is Left loosens, Right tightens. Good luck. Ellie
Jan 09, 2011 | PfaFF Creative 7570
How do you thread a pfaff 7570
If only we could put video links in here! But here goes:
Raise the presser foot;
Turn the hand wheel until the take-up lever (the hook bit that goes up and down, above the needle ) has reached its highest position;
Remove the small spool holder from the horizontal thread holder that is under the lid. Put thread reel onto spool, replace spool holder;
Pull thread behind first thread guide - it is the cream flat plastic bit towards the back - about 1" x 3/4" (i.e. the thread takes the first exit at the back);
Bring it down the left-hand long slot on the front of the machine, back up the right-hand slot, over the hook of the take-up lever, back down the right-hand slot and pass it from the side between the thread guide (silver metal bit just above the needle - looks a bit like curled metal). I found this last guide the most difficult to figure out - tried to get the thread into the curled bit - but you don't do that - it just slips in behind;
Thread goes through the eye of the needle. You can use the needle threader or not. Instructions for needle threader:
Lower sewing foot (makes more room and clamps the thread in the upper tension discs so it is less likely to keep spooling off while you are trying to thread);
Turn handwheel until the needle is in highest position;
Pull the needle threader straight down and then twist it to the front so the tiny hook on the threader goes through the eye of the needle;
Take thread under the larger metal hook on the left, put your thumb on it to stop it coming off, thread goes back towards the needle and under the small hook that is poking through the needle from the back;
Twist the needle threader towards the rear, releasing the thread carefully and allow the threader to move upwards. There should be a loop of thread left in the eye of the needle and you can now pull it all through to the back.
That sounds really complicated but I find the Pfaff needle threader works really well, unlike that of some other machines. I also have a Husqvarna Designer 1 whose needle threader works great, but the one on my friend's Designer SE is useless. Go figure!
Feb 02, 2010 | PfaFF Creative 7570
Threading a pfaff creative 7570
Always thread the machine with the presser foot up. This keeps the tension disks open while you are threading. Open the lid on top. Put thread on spool holder. Go directly to your left and down the path on the farthest left. Go all the way to the bottom and bring the thread up on the path closer to the spool. Hook the thread through the metal piece that moves up and down while sewing. It should be in the highest position when threading. Run the thread down and clip into the small metal holder above the needle. Pull down needle threader, draw thread across front of it from left to right and pull through needle.
Jan 30, 2008 | PfaFF Creative 7570
Sewing Machines Logo
12 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
