Question about Home Security
Sentry v252 I need to change the combination on my V252
2 Suggested Answers
  • 7 Answers
SOURCE: I need to open a Sentry safe V252 and I don't have the combination?
get an oversized flat tip screwdriver and a hammer and slide the flart tip in the gap where it opens just above the combo and swing away it will break the lock loose and you will be able to open it
Posted on May 21, 2012
Testimonial: "Thank you very much:) "
Where is the key hole in a sentry V252
i answer if you cant see one there isnt one on it.
May 25, 2017 | Sentry Home Security
Where do you put the key
Lift the push button panel.
I need the factory unlock code for a Sentry Safe v252
I believe you can only get this from Sentry themselves. If not a lock smith is your best bet.
Jun 05, 2016 | Home Security
May 21, 2012 | Sentry Fireproof Safe
How do i change battery in v252 safe please
The plastic plate at the front of the V252 below the keypad has a small hole. Use a pen or paper clip to press into this hole and at the same time slide the plate to the right. This will reveal the battery container (4 x AA). The code will not be lost if you replace the batteries, and this can be done with the door shut
Jan 09, 2011 | Sentry Fireproof Safe
Unable to open electronic safe
Locksmiths say this is how to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Mar 06, 2010 | Sentry Fireproof Safe
Need to open a Sentry keyless combination safe
First, has the factory combination been changed? Sentry has the code for the factory combination that they can supply you.
If the factory combination has been changed to something else, then Sentry won't have it.
In that case you need to ask Sentry for a 'reset' code combination. There is (at least) one back door to your safe -- a reset code.
The reset code will not tell you what your combination is, it will simply reset the combination to the factory combination.
You can take it from there.
Now, this isn't as hard as it may sound. There is an actual department that handles this at Sentry because you aren't the only one that cannot open his safe.
They'll want some proof of ownership, some $$ for the service, the safe serial number, and probably a notarized form claiming that the safe is yours.
Get 'hold of Sentry on the web and the rest is just process.
BTW -- this is exactly what the locksmith would do.
Apr 10, 2009 | Sentry Fireproof Safe
Changing the combination
These sentry safes dial combinations are not built to be changed as they have no key change hole. Switching the order of the tumblers could be done by a trained locksmith. I would suggest buying the electronic sentry safes as these safes can be reprogramed.
Jan 04, 2009 | Sentry Fireproof Safe
SENTRY SAFE
Locksmiths agree the factory code is burnt into memory and can not be erased. When you buy a sentry safe you have to set a user code to give out as that code can be changed. program instructions
Jul 03, 2008 | Sentry Fireproof Safe
Home Security Logo
53 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
