Question about Kenmore Dryers
He5 elite dryer 110.8772
After i did an annual clean. I must have crossed wires on the heating element. in short when i turned the dryer back on I blew the Thermal Fuse blew. In fact it blew the contact legs clean off. Is there a wiring diagram to show me how to reconnect the wires to the the thermal fuse and the thermostat which are all mounted to the side of the heating element housing. its a model 110.8772
ronpar
  • 27 Answers
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Posted on Jun 29, 2008
TheMobilian
  • 8220 Answers
SOURCE: Kenmore Dryer Model 110
If all of the components are reading ok then you need a timer. Touch your 2 leads together. 0 ohms rght. That means you have a complete circuit.If you get the 0 reading then the element must be otay. Bad timer. Take that fancy meater of yours and atttach one of them leads to the timer leg marked RH. Yank the wire off the terminal beore you test. Move the timer around. You should get the famous 0 reading along the way. If you don't then that means you have the bad timer.
Posted on Feb 05, 2009
protek480
  • 1714 Answers
SOURCE: whirlpool leb6000pq1 not heating
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer' circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
Posted on Jul 12, 2009
SOURCE: Maytag Performa PYE2200AYW Dryer Heats intermittently
i had the same problem with my dryer and i installed the wrong thermal fuse for gas dryer which calls for a pink thermal fuse in which i installed and it works fine also check the lint in the front of your dryer. also my dryer which is the same make as yours seems will run on the fluff cycle until i replaced the right thermal fuse. my dryer run exceptionally hot and eventally shut down and it only run on the fluff cycle for any length of time.
Posted on Sep 22, 2009
jumptrout51
  • 3361 Answers
SOURCE: Whirlpool Dryer not heating
The motor has to be running for voltage to exit the motor going to the heater. With the back off the dryer and the motor running you should read 220 volts at the heater if all safetys and thermostats are good.
There is a thermal cut out relay on the heat canister. It must read continuity also.
Remember you must remove at least one wire from each component being tested to get a true open or closed reading. If a wire is left connected you get a false reading.
The heating element could be broken and part of the heater wire touching the canister. This would cause a continuity reading and still no heat.
Finally, yes,the centrifugal switch in the motor could be bad and not sending power to the heater on the red wire.
Posted on Oct 18, 2009
Testimonial: "I did determine it to be the cetrepetal switch..specifically the slide for the weights was heavily gummed up with dryer belt dust. It works now."
Elite HE5. What and where is the P4 connector?
open the back and with an OHM meter check for an open element . have power unplugged first
Jan 15, 2016 | Kenmore Dryers
Replace the heating element
here are some results I found on youtube one might help you see how it's done
http://www.youtube.com/results?search_query=Kenmore+HE5+Electric+Dryer+Replace+the+heating+element
Nov 24, 2014 | Kenmore HE5 Electric Dryer
Thermal fuse keeps going out in my Kenmore elite HE5 Dryer, I have checked the vent from the dryer to the outside and it is all clear. Any Suggestions?
You need to check the venting inside the appliance? may have a build up around blower and motor? check the rest of ur thermostats as well and the heating element with a multi-meter u may have a short somewhere? may have a bad hi-lo or cycling thermostat?
Sep 06, 2014 | Kenmore Dryers
Where is heating element located in a ken more elite dryer he5
After you unplug the dryer, take the back off. There should be a long black tube that contains the heating element. Either remove the element or the tube then remove the element. These cost somewhere around $35-40. Just be careful and replace the wires as they were taken apart.
Jun 10, 2014 | Dryers
My gas dryer runs but with no heat
Most likely you need to replace the heating element that ignites the gas.just turn off the gas line unplug the dryer and remove the front cover then you will see on the bottom right there Is a heating element bolted to the gas valve with one single quarter inch bolt.You can either remove it and inspect it for little hairline cracks or check for continuity with a multimeter.If you see a crack or have no continuity replace the ignighet
Apr 15, 2014 | Kenmore HE5 Steam 7.5 cu. ft. Electric...
Where do I get a repair manual for my He5?
http://www.searspartsdirect.com/partsdirect/user-manuals?sidPSx20071217x00001a&ibp-adgroupsearch_brand_manuals&ibp-keyword%2Bkenmore%20%2Bmanual&ibp-matchtypeb&gclid=CJrxyOv3wrwCFaxxOgodF24A2Q
Feb 10, 2014 | Kenmore HE5 Electric Dryer
Heat turns off while clothes still wet
change the gas coils on the gas valve by removing the 2 screws holding the bracket for the coils,remove the wire harnesses to each coil,dont worry one coil has 2 wires the other has 3 so quite hard to reverse
Jun 16, 2012 | Kenmore HE5
The black wire (as opposed to the red, green, and white wires) on my Kenmore Elite He5 dryer plug shorted out at the connection to the dryer... what would cause this? And, is this something I should...
Hello. I recommend that you replace the entire plug and cord with a new one. The one that shorted is one of the two hot wires. It could be that the plug was faulty or had a weak spot in it. Joe
Jun 10, 2010 | Kenmore HE5
73952 / 73954 / 73956 Gas Dryer: my kenmore elite HE5 110.8772 is not heating. My...
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Kenmore 73952 Gas Dryer
My Kenmore Elite HE doesn't heat
Generally when a dryer does not heat, there is some problem with the heater, either it has shorted because some metalic thing like a coin or pin ( or in our case the under wire of a bra) from the clothes managed to get to the back and short circuit the heating element or the fuse is blown, I am not sure u can take the dryer apart to be able to check with a meter , when it is the heating element. You need diagrams of the dryer to be able to know how to take it apart and to know which screws and parts come off first. Please disconnect the power before attempting any of this
Jan 19, 2009 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
83 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
