Question about Mini5 Rhythm Battery Powered Amp with Rhythm
Compressor chorus flanger tremolo effects rotary dial seems to work on compressor setting best on VOX mini5 rhythm
Guitar amp effects rotary dial only works at compressor stage and volume level of other effects quite low
2 Suggested Answers
  • 5603 Answers
SOURCE: I have a VOX NT15.
You LIKELY have a bad filter capacitor. The additional load of the Triode load is probably dragging the supply causing flattopping and the power supply ripple frequency to come through. Have the unit serviced.
Posted on Jul 26, 2011
Testimonial: "OK"
Which is the best chorus pedal for a guitar?
According to me and many professional guitarists, the best chorus pedal is "MXR M234 Analog Chorus Guitar Effects Pedal"
It is durable and easy to use.
Some of its best points are:
? Volume is consistent
? Affordable price range
? Versatile tone and effect
You can check many other effects pedal at this link:
Best Chorus Pedal Top 5 Best Chorus Pedals for Your Guitar 2017
Feb 22, 2017 | The Music
User manual for DOD DFX9 DIGITAL DELAY GUITAR PEDAL
Can't find a manual but can still explain. Delays, chorus, flangers, and reverbs are all the same effect except the different names of them will allow you different adjustments. Chorus usually has a width control which controls pitch shifting. Flangers and delays will have a feedback control which simply means, how many times you hear the echo. On reverb units, room size means how long of echo(even though it;s short) you want. Delay is the same with much longer echo, feedback is the same as on flangers except the flangers time is very short meaning the effect is at almost the exact time resulting in feedback causing a metalic sound. I probaly just confused you but good digital delays usually have all the features and will usually do all 4 effects depending on how you set them. If you want delay, set width on 0 and adjust time and feedback. For flanging, adjust width and speed and feedback. Chorusing, adjust time, width, and speed. Reverb, adjust time, set width on 0, and feedback. I see it has a level(mixture, how much effect you hear), and a replay(feedback, how many times you hear it), and a delay knob,(how long the echo will be) The range/mode switch allows for settings of diferent time lengths and INF setting allows for infinite repeat. Hope this helps.
Mar 09, 2013 | Applause MAE148 AcoEle Mandolin Natural...
Hot rod deluxe squeals terribly with either overdrive box or distortion box. seem fine with tremolo or chorus box.
I have had this problem at least two times and the fault was a bad hi voltage filter capacitor. With the back of the amplifier removed, it's the grey cap near the top right side. Warning: very dangerous voltage there!!
Jul 20, 2011 | Fender Hot Rod Deluxe Guitar Combo...
I have a problem with my roland jw50 keyboard,,, i dont really know the cause ,,, any key i press makes only a single tone and it is distorted.. thank you..
Check the setting for your envelope ,attack, decay, and release
Check Effects settngs reverb/delay chorus/flanger
you probably have one or a couple of these setting way off
May 16, 2011 | Music
How To Use The effect Loop?
The effect loop is to use exteernal effect module... It is NOT to use guitar pedals !!!! The signals are line levels, NOT guitar type levels. An example of a device might be an Alesis Quadraverb. You take the effect send jack and run it into the inout of the effects module and the output of the effects module into the effects return jack. Many try to use guitar pedals and massive distortion results because levels are too high for the pedals.
May 12, 2011 | Peavey 6505+ 112 Combo Amp Combo
I'm a solo performer using mp3 backing tracks, a korg mutli effects for rock soloing and 1 mic for vocals all going through a mixer then outputed to Bose L1 Model 1. i. whats the best guitar effects...
You have several questions here and I'll do my best to help. While I'm not familiar with the "Bose" system I am performer that uses effects, mixers and etc. so....
1. Best effects to use. I would choose a small amount of guitar chorus and maybe a short digital echo, this is totally a matter of your choice, but in my experiecne, use as little as possible, you don't want to muddy up your sound
2. If your getting clipping, you have to much gain coming in, if you can you might try changing the settings on the "compressor" if you have such adjustments., or just turn down the output from your effects box a bit.
3. You didn't say what kind of mixer you are using, but typically your best off running your mic through the mixer, run the output of the mixer into a channel on the bose that has the graphic eq set to 0 or "flat", use the mixer to control treble, middle and bass rather than the bose amp.
4. Variation in volume of your backing tracks is an issue that you need to take care of before you play out. When you record your tracks, you need to either use equipmennt that will make the levels all the same, or sit with the system while it records and control the volume (with a mixer) as they are recorded, nothing ruins a performance more than profound changes in volume that override or dimish your main performant, (e.g. your vocals or lead riffs)
Let me know if you have further questions. good luck and Keep on Rockin
Mar 14, 2011 | Bose T1 ToneMatch Speaker PA System
How to set up foot switch in order
Personally I recommend the following set up:
Distortion>Effects>Compression/Noisegates/Sustain
This will ensure that the signal won't have any odd hiccups due to an odd pedal setup. But if you play around with different orders, you can end up with some very interested sounds.
Nov 24, 2009 | Boss Mt 2 Metal Zone Effects Pedal
The correct order for Effects pedals.
Personally, I like to have all "tone effects", such as wahs, distortions and equalizers in front of "time effects" such as phasers, chorus, flangers and delays. See my set up in the photo. Guitar input is from right to left, starting with the wah pedal.
Tom, 30yr player
May 15, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Tascam 2488 Recorder
if the multitrack doesnt have built in effects you need to but an extrenal vocal effects processor that you can wire up to it. try lexicon products, they offer really good realistic vocal effects rack units.
Dec 26, 2007 | Tascam 2488 Portastudio Multitrack...
Problem with playback
Hi, I have the same audio interface. Alright, make sure that all of your effects are turned off. you probably (and most likely) have the "fx voice", "amp drive", "chorus" and "delay" effects turned on (bottom row). There is no way you should have distortion with tremolo & reverb on playback all the same time without the effects being turned on. the pop ticking could be produced by the buffer size. If youre using Sonar LE, you should tweek the buffer size until playback sounds smooth. I hope I helped! Good luck!
Aug 14, 2007 | Edirol UA-4FX External Sound System
Mini5 Rhythm Battery Powered Amp with Rhythm Logo
16 people viewed this question
Top VOX Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a VOX Vehicle Part and Accessory Expert? Answer questions, earn points and help others
