Question about Sharp EL-2196BL Calculator
New set up the 0.E will not go off, will not print
Brand new, cannot get it to print
We just put new ink in and it prints out fuzzy . how to fix it ?
Every time you replace ink you need to do an alignment. To do this follow these simple steps:
  1. Press the Ink or Ink Management key on the control panel.
  2. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set.
  3. Press the up or down navigation key to select ALIGNMENT and press Menu/Set or Set.
  4. Press Black (Mono) Start or Color (Colour) Start. The machine begins printing the Alignment Check Sheet.
  5. By reviewing this Test Sheet, you can determine if the alignment needs adjustment.
  6. Examine the 600 DPI and 1200 DPI test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1 (YES).
    If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
  7. Press Stop/Exit.
Mar 02, 2011 | Brother MFC 210C All-In-One InkJet Printer
Samsung CLP-300 refuses to acknowledge new toner. The toner is brand new from Samsung. Test page shows the colour being used perfectly in the Samsung logo. The light just continues to flash and the...
you may press and hold the button for 5sec and let go to print the supplier info.
If it still show @ 0% you may want to check with the shop you purchase to get an 1 to 1 replace.
Apr 08, 2010 | Samsung CLP 300 Laser Printer
The printer quit printing and the toner light came on. Replaced the toner with a brand new toner and its still not printing. Recommendations?
Is the printer still asking for a new toner..?
If it is the there is a gear that can be reset on the toner cartridge to tell the machine its a new toner cartridge. This is normally done by an engineer, but is quite easy to do if you know how. And I do :0
Mar 04, 2010 | Brother HL 5250DN Laser Printer
Printer prints blank page
Is this a brand new printer? What is the make and model of your printer? Are the ink cartridges brand new? Sometimes when the printer driver becomes corrupted it will print out blank page (page after page) I would reinstall the printer driver that goes to your printer and then restart your computer and try to print a new page.
http://en.allexperts.com/q/Printer-mechanical-problems-1024/HP-Printer-prints-blank.htm
http://techrepublic.com.com/5208-6230-0.html?forumID=101&threadID=207297&start=0
Feb 13, 2010 | Lexmark Office Equipment & Supplies
Printer Epson DX6000 ... all new cartridges .... will not print any text. I can print the head clean test page as well as the head alignment page ... but no text
You said all new cartridges.. But are they Epson Genuine Cartridges???? I had the same problem when I replaced with new, but generic cartridges.
After finally, going thru 2 sets of each, removed them and put in Genuine., and finally, everthing started printing fine. Weird , but true.
I suggested my answer problem below.
Good Luck :0)
Problem for Epson Stylus C84 InkJet Printer
Re: C84 I'm using generic ink, but the red
By mclamemo on Nov 12, 2009 re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't print at all.
Also now even the black every few lines prints the top half of the line or the bottom half of the line, or its smeared, etc...
Help!
Best Solution
posted on Nov 12, 2009
cns assoc
Rank: Wiz Expert
Rating: 84%, 22 votes
I have learned from experience, that Epson does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Had to go out and purchase a new printer.;
Good Luck :0(
Asker's Testimonial
" Thank you. Called Epson also and they didn't say it as directly, but advised real Epson ink too. Hope I didn't kill the printer! Generic ink for sale " - mclamemo
Comments:
Nov 12, 2009
- Funny. hahahahah,
Me too! I would say, about 2 dozen cartridges to be exact.
lol :0) :0) :0
Nov 15, 2009 | Epson Stylus C86 InkJet Printer
Program of c to find largest and second larhest number of given 50 numbers using array
This code generates some random number to test.
#include <limits.h>
#include <stdio.h>
#include <stdlib.h>
int main()
{ findLargest();
return 0;
int findLargest()
{ int someNumbers[50];
int i;
// to generate some numbers for us to test
for(i=0; i<50; i++)
// generate a random number between 0-100
someNumbers[i] = rand() % 100;
// for keeping track of numbers, set as smallest possible
int largest = INT_MIN;
int largest2 = INT_MIN;
// go through each item in the array
for(i=0; i<50; i++)
{ // if bigger than our previous max, set as new max
if (someNumbers[i] > someNumbers[largest])
largest = i;
// if it's not been set as new max, and is bigger than current 2nd largest
else if(someNumbers[i] > someNumbers[largest2])
largest2 = i;
// for printing all numbers in the array
printf("%d | %d\n",i, someNumbers[i]);
// print largest numbers and their position in the array
printf("largest %d (pos %d).\n2nd largest %d (pos %d)",
someNumbers[largest],
largest,
someNumbers[largest2],
largest2
return 0;
May 07, 2009 | Computers & Internet
Schiller AT-1 ecg not printing.
Turn on machine, wait a few seconds then press ALT-0-1-1
You will get a print out showing all the settings
Feb 16, 2009 | Schiller Welch Allyn Cardiovit At 2...
Brand new Canon MP210 wont print at all
Try going into Control Panel, Administrative Tools, Services and make sure that the print spooler is set to automatic.
Also make sure you have the latest drivers.
Click Here To Go To Canon Support
Sep 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Set Tax rate on a Casio HR-100TM
Press the CA button twice. Then push and hold down the %/set key until the 0 dissappearsd and reappears. Then type in your tax rate and the percent key (eg: 8.25%) and then press the TAX+ key. It should save the new tax rate.
Jan 05, 2008 | Casio HR-100TEPlus Calculator
Sharp EL-2196BL Calculator Logo
44 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
