Question about Honeywell HE220A1019 Whole House Humidifier Humidifier
I trying to install humidifier on duct board plenum, I can't use screws, so I used scotch tape with 20 lbs rating, unit is not holding on it. What would be proper way to hold 6 lbs humidifier on duct board plenum?
3 Suggested Answers
SOURCE: Can the humidifier's housing for
Hello Which came first the chicken or the egg?The unit will operate perfectly in the supply OR return as I have installed in both.If there is more room & easy service access put it in there.
Posted on Sep 14, 2010
  • 1033 Answers
SOURCE: I just installed a Honeywell HE 360 Humidifier I
Hello, in order to turn your humidifier on with the furnace the 120 volts coming from your humidifer you must hook it up to a step down transformer, then the transformer will provide 24 volts to you humidistat and solenoid valve. So you need a wire from the HUM on your control board to transformer primary side and a wire from neutral on the board to primary side of transformer. Then you need low voltage wire from secondary side of transformer to humidistat from humidistat to humidifier.
Posted on Feb 20, 2011
Only one fan working
There are two causes of your problems:
1. The fan needs you to manually turn it to start running.
Problem: The motor bearings both ends are dried out.
Solution:
1. Remove the motor/fan from the motor housing (there are two screws that hold the motor to the housing. The only way I know how to get to the screw is to bend one of the fan blade up and use a long screw driver to get to the screws.
2. Remove the two screws that hold the bearings to the motor.
3. Detach the bottom bearing (opposite of the fan end.) You might have to use a flat screw driver to pry the bearing off.
4. Use a Q-tip and soak it with motor oil or grease then lubri- cate the fan end shaft/bearing.
5. Use a Q-tip + alcohol to clean up the bottom bearing hole, then lubricate it with grease or motor oil.
6. Put the motor and bearings back together and make sure that the fan can turn freely now.
7. Install the motor/fan back into it housing.
The fan should turn on its own without you helping it.
If the fan won't turn, you have a bigger problem. See below.
2. The fan won't turn at all and is really tight even when you try to
turn it by hand.
Problem: The transformer coil(s) is/are burnt out. Chances are you let the fan run dry to a point that it squealed and started to smell like it was burning before it quit all together.
Solution 1:
1. Remove the filters and their housing on the bad fan side.
2. Duct tape a piece of plastic over the bad fan opening.
3. Run the humidifier with one fan. It works just as well.
Solution 2:
1. Buy a new humidifier.
2. Make sure you lubricate the bearings as soon as the motor begins to squeal.
Solution 3: You need knowledge of electricity
1. Take the motor/fan out from the housing.
2. Use a vote meter to check the resistance in both coil of the transformer; should read about 17 ohms. The coil(s) that has a high reading or if the meter shows 'OL' is bad. Remove the Yellow tape from the coil to see if you have a loose soldering joint between the coil wiring the electrical cord. If yes, solder the joint back together, check the resistance again to make sure you have about 17 ohms. If the answer is yes, put the yellow tape back on the coil and use electrical tape to secure the tape. Hopefully, the fan should work now. Good luck!
Feb 03, 2013 | Kenmore 14417 Humidifier
Where to install the humidifier
If the humidifier is a flow through bypass or fan powered it can be mounted in either the return air duct or supply plenum.
Nov 02, 2011 | Humidifiers
I just installed a Honeywell HE 360 Humidifier I purchased at Home depot. I replaced a Aprilaire model 110 . I have a 120v power duplex that is hot with the furnace blower motor, on so I assumed the sail...
Feb 20, 2011 | Honeywell HE360A1027 Whole House...
Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
Humidifier was installed on return duct on new trane gas furnace
you are ok. this way humidity will get to whole house if your supply duct splits off. done this way often.
Dec 29, 2008 | Aprilaire 700 Humidifier
Aprilaire 600 valve won't open?? help
hook one wire to the hum screw on the board if there is not a hum screw hook it to the green screw,go up to the humidifier then back down to the common screw on the board that should make the unit only come on when the fan is running. it sounds like the humidistat is not working correctly
Oct 14, 2008 | Aprilaire 600 Humidifier
Aprilaire 600 just installed and showing an error code
No, it is not an accurate statement.
These units have simple configurations They have a water supply similar to a ice making referigerator, an enclosure connected to your supply duct that houses a prop fan and media, a seperate humidistat and a drain for excess water. Your unit may also include fancy controls including an outside thermometer & humidistat to avoid over humidification that can cause problems during freezing weather. The humidistat looks a lot like a thermostat and is located in your living space or in the return duct. The prop fan in the box pulls air from the duct, through evaporation media and back to the duct. An electric solenoid valve releases water that pours over the media.
If the humidiy is below the humidistat seting and the AC/heater is running, the Aprilaire fan starts and the solenoid valve opens. I suspect the facier controls include the flashing warning light.
The warning light spells problem. Aprilaire's customer service should be able to provide guidance for the homeowner in the form of simple checks. I suspect your contractor is avoiding a warentee call and the trip it requires.
A word of caution. These humidifiers can be powered directly from your air conditioning unit control board from an auxiliary connection. If the control board isn't rated to carry the current required by the Aprilaire fan, valve and controls or the Aprilaire encounters and electrical problem, the board can be damaged. This can be avoided by using a relay. The AC board switches a low energy relay. 120 volt house power is connected to load side of the relay and runs the Aprilaire.
My board cooked at a location near this connection, but I can't be sure that the load from the humidifier caused it since four of our neighbors also lost their board. It failed the evening of a snow storm and required a costly emergency after hours service call. The next day a new board required a three hour drive. Fortunately a fan powered propane heater kept our pipes from freezing.
Aug 27, 2008 | Aprilaire 600 Humidifier
Motor turning real slow
THE MOTOR ONLY TURNS THE SPONGE DRUM AT MAYBE 10X'S PER MINUTE. THIS IS A BY-PASS TYPE HUMIDIFIER THAT RELIES ON YOU FURNACE BLOWER MOTOR TO SUPPLY AIR ACCROSS THE SPONGE MEDIA. NOTICE THE 5"-7" ROUND HOLE MUST BE DUCTED TO THE PLENUM OR RETURN AIR. (IF MOUNTED ON THE PLENUM, THE HOLE HAS TO BE DUCTED TO THE RETURN AIR, AND VISA-VERSA.) CAUTION!!!IF YOU HAVE CENTRAL AIR? A "DAMPER" MUST BE INSTALLED AND KEPT CLOSED THROUGH-OUT THE "COOLING SEASON". SERIOUS DAMAGE TO YOUR COMPRESSOR CAN RESULT FROM TOO COLD OF AIR ... CIRCULATING AND "BY-PASSING YOUR EVAPORATOR COIL".
Feb 13, 2007 | Honeywell HE120 Humidifier
Honeywell HE220A1019 Whole House Humidifier Humidifier Logo
Top Honeywell Humidifiers Experts
Dennis
jdthefixer
Bill Long
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
